Ir para o conteúdo principal
The 2008 Nerf N-Strike Recon CS-6 is a customizable, manual, clip-fed dart blaster sold by Hasbro.
How do I remove the magazine?
Instructions for removing the magazine from the gun.
Esta é uma boa pergunta?
Pontuação 6
Adicionar um comentário
10 respostas
Pergunta mais útil
To remove the magazine there are two buttons located on each side of the gun. Use both hands to pull back both buttons at the same time, and then the magazine should simply fall out.
Esta resposta foi útil?
Pontuação 5
2 comentários:
yeah bro its easy
por
Which side are the buttons on
por
Gear Up For Future Repairs
Yellow model: Pull the grey slide mechanism back. Open the black hatch. Push down on the magazine while sliding the two orange unlock buttons.
Pontuação 4
2 comentários:
works for recon mkII as well
por
This is the answer I was looking for! Thank you! Just pulling the release buttons did not work
por
Pull the slide back and pull the orange release next to the magazine
Pontuação 2
How do I remove the magazine if the slider is broken and cannot slide back?
Pontuação 1
3 comentários:
Try firing the gun
por
smash it on your sofa like a madman
por
If the cover of the sliding mechanism comes off, use a long thin screwdriver and push it through the holes in the long slits, and then pull that back. If the slide wont pull back, try firing the gun and then pulling back. If that doesn't work, open up the blaster (please record what you're doing it as you're doing it in case you cant easily re assemble it) and try and see if its jammed.
por
I have placed my darts of my recon cs-6 accidentally but i cannot open it because it is too hard i cant use the opener
Pontuação 1
1 comentário:
:o its jammmedso hard?
por
https://www.youtube.com/watch?v=pU5waRnk... Watch this and see
Pontuação 0
The orange button near the trigger will release the magazine
Pontuação 0
my slider is broken and i cant release the magazine
Pontuação 0
1 comentário:
me either it is soooo jammed that i am poop
por
You have to pull the reloading trigger on the top and push the button on one. the pusher)
Then take out the mag.
Pontuação 0
My magazine won't come out of the
Pontuação 0
Adicionar a sua resposta
Asad Qureshi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 24
Últimos 30 dias: 76
Ao todo: 35,260
