Ir para o conteúdo principal
The Honeywell Cool and Refresh Mini Tower Fan is a two-speed fan paired with a Febreze scent cartridge that cools the air and helps eliminate bad odors.
3 Perguntas Visualizar todos
The fan blades won't spin--how to fix?
I can hear the motor whirring inside when I first turn it on but it takes awhile for the fan blades to actually start spinning. How can I fix this?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
The fan blades could be damaged. You can replace the blades, or see if there is anything blocking their movement. There could also be a problem with the motor as a whole. Use this guide to check the fan blades and replace the motor.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Armando Jacob Espinoza será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 12,776
