Ir para o conteúdo principal
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
20 Perguntas Visualizar todos
5k iMac with SSD want to add HDD
I ordered new 5k iMac with the 256GB SSD option. Does iFixit (or anyone) sell the HDD bracket and cable required for me to add a large HDD?
I suspect it will be nearly identical to the 2639 build. Does anyone have any knowledge on what Apple leaves for HDD if SSD is only selected build option? It would be nice if they had bracket and cables w/ screws just taped in place; I am assuming that's not the case.
Big Thanks,
-Natahn
Esta é uma boa pergunta?
Pontuação 5
1 comentário
This question was migrated from http://meta.ifixit.com/Answers.
por
Adicionar um comentário
1 resposta
Solução escolhida
From the two teardown's it does look like the same parts would be needed.
From the Late '12 parts manual Apple doesn't see the carrier as a spare. It does offer the needed HD/power cable P/N: 923-0312
Esta resposta foi útil?
Pontuação 4
Adicionar a sua resposta
nathan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Ao todo: 3,299
