Ir para o conteúdo principal
Model number 9022291415 / 3.2 Megapixel CCD digital camera.
Flash de-synchronized from camera trigger
Flash light seems to be de-synchronized from the trigger of the camera.
When taking a picture in dark, the flash activates one or two seconds too late. Thanks for help.
Esta é uma boa pergunta?
Pontuação 5
1 comentário
Excellent question. I have looked and looked around, but cant seem to find anything on that.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
You might have a bad flash capacitor, in some cameras it is used to build and store a charge that is released to power the flash. I'll have to look into this further.
Esta resposta foi útil?
Pontuação 2
4 comentários:
You may also want to check the settings, or select the "factory reset" option, if it has one.
por
I think its more then that... unless you shoot the moment after you turn on the camera. The fact that it shoots means that the capacitor works, its the trigger that shorts it (to flash) is.. delayed.
por
This question has been around forever, and I cant seem to find anything documenting, nevermind fixing it, anywhere online.
por
did you find an answer? seems as if you're on the correct path...thank you
por
Gear Up For Future Repairs
Adicionar a sua resposta
Yragael será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Ao todo: 1,270
