Ir para o conteúdo principal
Freezes during boot from HDD and DVD
Hello,
my PowerBook G4 1.67 GHz with 2 GB RAM freezed during the boot process after I foreced shoted down by pressed the powerbotten. It always stops at the white screen with the Apple logo and the spinner. The same thing happened while I trying to boot from the Install Disc. The Hardware Test also can´t work.
When I connet it to a mac mini under firewire connection. HD can be detected but hard to read.
I need to replace HD first?? or some serius problem happen?
Does anyone have useful clues?
Best regards
jyer
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Sounds like a failing hard drive if it's hard to access in target mode. From target mode, back up your user data. Run Disk Utilities and if you can't repair it, reformat and reinstall the system from the Mac Mini if it is not a Intel processor machine. That failing, replace the hard drive. Here's how to do it:PowerBook G4 Aluminum 15" 1.5-1.67 GHz Hard Drive Replacement
Here's some hard drives that will work for you: http://www.ifixit.com/Mac-Parts/PowerBoo...
Esta resposta foi útil?
Pontuação 2
1 comentário:
+ Ralph
por
Gear Up For Future Repairs
Shop all
Try reseating the RAM, and also try to see if you can verify/repair the drive in any way.
Pontuação 0
Adicionar a sua resposta
Sheing Jye chen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 1,173
