Ir para o conteúdo principal
Display second digit not working; some buttons not working
The second digit in the GE JES1384SF Microwave display is not working, so that 4:30 reads as 4: 0. The defrost and the cup buttons do not work. Otherwise, microwave works fine.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
The microwave just needed to be unplugged and plugged back in. I didn't realize that, but we had a power failure and now it works fine again.
por
Adicionar um comentário
1 resposta
Solução escolhida
Main Control Board
If the microwave display is not working the main control board is most likely defective and will need to be replaced.
Display Board
If the display has gone out the display board might be defective. If the display goes out completely the problem can be either the display board or the main control board. If the display goes out partially the problem is usually the display board.
JES1384SF is a partial model number for a GE Microwave. To see specific parts for your Microwave, please add the last few figures.
Esta resposta foi útil?
Pontuação 2
1 comentário:
What about my buttons that also don’t work
por
Adicionar a sua resposta
TomND será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Ao todo: 1,593
