Ir para o conteúdo principal
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
Exchange of keyboard (only) possible? (US->German layout)
I'd like to know if its possible to exchange the keyboard (only - not the whole topcase) of the "Late 2013" MacBook Pro 15''.
I heard some rumors that a lot of parts are glued together in this series and it might not work.
In this case: Has anyone ever exchanged the keyboard by removing ALL the single caps and replacing them?
Are Keys from older versions compatible to the "Late 2013" series?
Update
I found a solution that works quite perfect for me: KB keyboard covers! The can be bought for several languages and keyboard styles for about 25$.
Thanks for the help!
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
It's possible but, very advanced and you must locate/create small screws to replace the pins that the OEM uses.
If this answer is acceptable please remember to return and mark it.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Richard Friedrich será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 443
