Ir para o conteúdo principal
Dell Inspiron 1420 14.1" laptop, released in June 2008. Identified as the 1420 on the bezel above the keyboard, available in 8 different colors.
How can I fix my VGA problem?
Mostly when ever i power on there is no display of dell monogram but screen is on
Esta é uma boa pergunta?
Pontuação -1
1 comentário
How do you know that the screen is on? what do you see when it is not displaying the "dell monogram" What OS are you using and what have you tried to fix it?
por
Adicionar um comentário
2 respostas
Solução escolhida
Here is a link for downloading the service manual for your computer. Good luck.
ftp://ftp.dell.com/Manuals/all-products/...
Esta resposta foi útil?
Pontuação 1
Related Parts and Tools
First try using it with an external monitor by connecting via VGA cable, if it works fine in such way then the problem is surely with your LCD connecting cable. However you can first try to locate if there is any lose contact of on board connectors which shall might help.
Pontuação 0
Adicionar a sua resposta
shahid será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 678
