Ir para o conteúdo principal
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
Sim card not recognized
Hi. Some day ago my ipad2 wifi+3G (european) stopped to recognize the sim card. I tried everything, iTunes reset, dfu reset, removing sim card, activating and deactivating airplane mode. Nothing...the sim card is ok on my phone so seems to be a hardware related issue and I'm out of warranty since march 1st (%^%%!!).
There's something I can do myself? Thanks!!
Michele
Esta é uma boa pergunta?
Pontuação 5
2 comentários
It happened the same to me on my ipad 2 3g (and the warranty expired two months ago!!!!!!!!! ) The wifi mode is still working but the ipad is not recognizing the SIM card and it appears "No SIM".
Apple is not settling it and they offer me to change the whole ipad, paying like 270€! for another ipad 2 (not new, but repaired from others..).
I'm so angry!!!!!!!
por
Yes it work for me thank you
por
Adicionar um comentário
4 respostas
Pergunta mais útil
There is a solution to the fix but it involves taking it apart and soldering. Not sure if you have the skills
http://i1266.photobucket.com/albums/jj52...
Esta resposta foi útil?
Pontuação 2
5 comentários:
Hi YoloRepair, please post the repair for this so long.
por
http://imageshack.us/photo/my-images/835...
Look at the picture and check those pins for continuity using a multimeter. Once you find the line that's broken you have to solder a jumper wire directly to the test point. Make sure you isolate the wire so that it doesn't short at all.
From what I've seen the red line is usually broken but check them all to be sure.
por
Hi YoloRepair ca,
I tried clicking the link to your photo but it doesn't work. Little help, please.
por
Ryan can you email me - email should be in my profile. Been having some issues with ifixit lately.
por
I'm getting no luck lately with ipad's. I have now encountered this NO SIM issue on an iPad 2. Replaced the SIM reader twice just incase of faulty 'new' hardware. Checked the photobucket picture shown above and have no continuity on the red wire from SIM reader to GSM board. Whats the best method of running a jumper. I don't have a board view of that part of the card.
por
Gear Up For Future Repairs
Shop all
Same issue, here is what works for me:
  1. Powering it off sometimes help.
  2. Toggling airplane mode also helps.... after doing it MANY times
Apple products is only a fashion statement, in the real world they don't have durability.
Pontuação 1
1 comentário:
Airplane mode method worked first time! Thanks!
por
Found out a method from cleaning coins, that applies to SIM-Cards. I had the same problem. I've cooked the sim-card in salty water with a bit of aluminium foil in it --> This takes away the oxidation from the metal on the chip. I've put the chip back in and it was instantly recognised! Hope that helpts
Pontuação 1
2 comentários:
thnx dude that helps :D and works like a charm but i didnt cooked it just clean it up with w knife :P and it's ok
por
it worked i just scrub it thankis
por
NO SIM problem can happen to iPhone and iPad. It happen because the sim card is not connected to it place.
This method is worked for me. And i Hope it work for All of you too.
Here's the method:
1. Remove the sim card
2.Remove the Touchscreen, LCD and LCD Shield Plate.
3. Push down firmly at sim card slot. (Like pushing a button)
4. Insert the sim card, and see.
Pontuação 1
Adicionar a sua resposta
Michele Pighi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Ao todo: 15,541
