Ir para o conteúdo principal
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
SSD of early 2013 MBP Retina upgradable?
I got a early 2013 Retina MBP, 2.8GHz processor, 16G RAM(have the logic board replaced with the same model) and as it known to all, Sandisk SSD(512G) which lead to a annoying fan issue. Tried to replace the SSD with a Samsung 768G one, but it turned out the Mac cannot boot with the bigger size, Samsung SSD. I search the Q&A and found everybody said the SSD is upgradable. So how can my situation happened and anybody knows how to fix it?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
AFAIK the only 700+GB option is OEM at the time of order. In a while OWC may have SSD upgrades larger than 480GB (their current max) visit them and watch/ask. Until then, purchasing a display damaged 768GB unit might be your only other DIY option.
If this Answer is helpful please remember to return and mark it Accepted.
Esta resposta foi útil?
Pontuação 2
7 comentários:
What do you mean by purchasing a display damaged 768GB unit? I've already tried to replace it with a 768GB one but didn't boot at all.
por
So the case is 512GB cannot upgrad to 768GB right?
por
Apple said the upgrade would not be 3rd party compatible (they always say that - but at least at this time it's true, see my OWC link). You didn't say that you'd tried to swap out a 768GB SSD from a damaged '013 Retina (is that what you did?)
por
Oh, yeah, I forgot to say, it is a Apple customized Samsung 768GB SSD, used originally in RMBP, but the Mac couldn't boot.
por
Then the "drive" may be damaged too.
por
Exibir mais 2 comentários
Adicionar a sua resposta
Yang Wang será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 2,547
