Ir para o conteúdo principal
Permission issues on recovered user data
I got in a A1226 with a failing hard drive. It also has a bad optical drive. The machine would not fully boot. Put it in Target mode with a 2009 A1278 and tried to repair the drive. Disk utilities reports it's unable to repair and to back up the data. I get a new Seagate Momentus XT and hook it up to the A1278 using a universal adapter, format the drive and use SuperDuper to clone the drive. Use another adapter to hook up the bad drive. The user folder is massive with to many corrupt files to use drag and drop or migration asst. So I use a combination of dragging the Desktop file and documents and later Mig. Asst. to get most of the User folder. Put the new drive in the A1226 create a user with the old name. All works well when logged into the migrated user except the things that were drag and drop. Again the Target Mode with the A1278 I'm told I don't have permission to open those using Disk Utilities. I can't run repair permissions because the disk is set to ignore ownerships. Any ideas?
Esta é uma boa pergunta?
Pontuação 2
2 comentários
How come when I ask a question, no one really gives an answer ;-)
por
Nothing personal... for me the first time I saw this was a few minutes ago.
por
Adicionar um comentário
1 resposta
Solução escolhida
Try Batchmod or a similar app to alter the permissions on the folder/disk... it claims to be able to recursively make the changes and is GUI in place of UNIX.
Esta resposta foi útil?
Pontuação 2
2 comentários:
This looks like what I need but it wants me to give them my credit card number to download. They say I will not be billed. So why the *&*(&((* do they need my credit card?
por
Try using the finder to manually change the permissions on that folder so that you own, or can read/write to them. You can do this a few files at a time, OR create a folder put all your files in the folder, change the permissions and click the drop down arrow to the right of the +- line (bottom of information window) to select "apply to enclosed items". and it should recursively change them-unless they are locked too. If they are locked you should be able to select a group and unlock them from the same finder info window.
por
Adicionar a sua resposta
mayer será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 186
