Ir para o conteúdo principal
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
Pergunta encerrada
Can it boot from SSD in optical bay caddy?
Has anyone tried if SSD will be bootable being installed in optical bay via caddy? Otherwise, this upgrade will be useless for me. Thanks.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Did you try it? Does booting from the SSD in 21,5 late 2009 work? Thanks!
por
Adicionar um comentário
1 resposta
Pergunta mais útil
While I haven't personally set my iMac up like this yet I can say with confidence that it SHOULD work as the startup disk location is set in the OS.
Apple has a KB article detailing how to change/select a startup disk for your Mac to boot from. Assuming you've already installed the secondary drive and installed an operating system to that drive, these will help you boot using that drive:
  1. Power the Mac on while holding the "option" key on your keyboard
  2. After a few seconds a gray screen should appear with one or more hard drives visible. Any attached hard drive that has a bootable operating system will show here.
  3. Select the desired hard drive and click "return"
  4. Once the Mac boots to the operating system, open System Preferences
  5. Open Startup Disk
  6. Select your desired startup disk
  7. Click restart to finish the process
Your Mac should now default to the specified startup disk. If you need to change it in the future you can use the "option" key method to temporarily do so or the System Preferences method to permanently do so.
Hope that helps!
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks for your answer!
I heard about startup disk procedure, but wasnt not sure if an older mac wouldn't have smth against using non-oem ssd and in optical bay.
Guess, i ll have to try it.
por
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 2,486
