Ir para o conteúdo principal
Boot from External Drive and New HDD
Hello everyone, I've basically 2 questions, so first I going to introduce you my trouble (My english fail sometimes : D)...
1- I've one MBP and one iMac Mid 2010 (like this http://support.apple.com/kb/SP588?viewlo...), and the second started to crash, something like S.M.A.R.T problem. So I search in interwebz about this and I saw that isn't a way to fix it. So the first question is Can I buy this HDD "Seagate 3.5" ST2000DL003 2000GB 5900 RPM SATA 6.0GB/s Desktop Hard Drive" to replace (in Apple Care). The size's right and this RPM is ok?
2- I installed a ML version in my external drive (connecting in my MBP) and It booted fine, for a moment I was a glad guy, so I restarted the OS in original MBP HDD and ejected the "External Mountain Lion" to plug in iMac and try to use. But when I try, It doesn't boot, just Apple loading screen, but I can access the 10.8.2 recuperation application (both, original from HD and the External too...), moreover I've a Bootcamp partition running win 7 perfectly. So I don't understand how can I start the recuperation application and win7 bootcamp, boot the External ML in my MBP, and I cannot boot the "External Mountain Lion" from external drive in iMac?
Esta é uma boa pergunta?
Pontuação -1
2 comentários
I'm confused--if you have Apple Care on item 1 you should take it to an Apple dealer for a free repair.
por
sorry was my fault, I mean Apple Support
por
Adicionar um comentário
1 resposta
Solução escolhida
1st Answer: NO you need/want SATA II or a 3GB/sec transfer speed. No need to pay for more, and some that claim they are "backward compatible" don't really play well at the slower speeds.
2nd Answer: I think something in the install of 10.8.2 for the MBP omitted drivers or extensions needed for the iMac... updating (repair/reinstall) the while connected to the iMac should fix that issue.
If this answer was helpful please remember to mark it accepted.''
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Ramon Villain será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 601
