Ir para o conteúdo principal
The PowerShot SD1000 Digital Elph is a digital camera with a 7.1 Megapixel a 3x optical zoom
"No Memory Card Error" What next?
Hello Everyone. I am new here so bare with me.
I tried all the "WONDERFUL' toothpick tricks and what not, to no avail. I still do not have successful results.
I disassembled the camera completely.
I am attaching some pictures to see if anyone sees something that I am missing. Something I am overlooking. Also, is there an option to fix the memory card slot…ie. Soldering or replacing it?
Your comments are welcomed and appreciated
Thanks
Esta é uma boa pergunta?
Pontuação 1
1 comentário
I assume that you originally tried more than one card, just to rule that out as the cause. You can replace the card reader, as long as you find a proper replacement. This one should be a standard one, so I would try to scrounge a broken camera and replace it. the soldering will be somewhat tricky and will require a bit of practice :-) but it can be done.
por
Adicionar um comentário
2 respostas
Solução escolhida
One of the contact pins are probably bent or mashed in.
The way SD card slots are soldered to the PCB makes it nearly impossible to replace. Machines, not man solders this stuff together when it's made.
Your best bet is to get a good main PCB from a junker SD1000 camera on eBay.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thank you very much for responding.
I went ahead and purchased a new PCB on Ebay.
I really wanted to try to replace the memory card slot but as you said, it can be really tricky and besides, I did not have the correct solder pin.
por
Mission Accomplished.
What shall I get myself into next?
Pontuação 1
2 comentários:
Excellent, great job.
por
Thank you very much. It was interesting.
por
Adicionar a sua resposta
Janet será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Ao todo: 2,191
