Ir para o conteúdo principal
Ajuda
Dell Latitude E6400 Teardown
Editando passo 8 —
Tipo de Passo:
Arraste para reorganizar
Open your laptop so the display is perpendicular to the upper case.
Place your opened laptop on a table as pictured.
While holding the display and upper case together with your left hand, remove the two 4.8 mm Phillips screws from the display brackets.
Grab the upper case with your right hand and rotate the display slightly away from the upper case. Lift the display away from the upper case, minding any brackets or cables that may get caught.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
