Ir para o conteúdo principal
Ajuda
1911A1 45 Cal Teardown
Editando passo 11 —
Tipo de Passo:
Arraste para reorganizar
Pull the hammer back. Now pull the thumb safety out of the frame.
You'll need to wiggle it between safe and fire to release it from the hammer spur. The hammer must be pulled back to get this part out.
The pin that holds the safety in position is under alot of pressure. it WILL fly out, so hold your hand next to it to stop it from flying out the window at the house next door. Plus this part is tiny, you lose it, you may not find it again.
See above
Once the thumb safety is removed, the grip safety will come out easily.
These 2 pins can be removed with finger pressure. The bigger one is for the trigger, and we'll take that out first.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
