Ir para o conteúdo principal
Ajuda
1911A1 45 Cal Teardown
Editando passo 3 —
Tipo de Passo:
Arraste para reorganizar
Push the Barrel wrench down over the barrel bushing, pressing the recoil spring retainer down to unlock the bushing, and rotate clockwise.
Spring is under alot of pressure, ensure you keep firm pressure on the retainer as you rotate and slowly lift up to avoid retainer from flying across the room or in your eye!
Set retainer aside and rotate counter-clockwise on barrel bushing (its loose now) until locking tab is pointing at the spring, then lift it out.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
