Ir para o conteúdo principal
Introdução
Ir para o passo 1
This is the full teardown of Digia, Qt (Formally Trolltech) Linux based phone.
O que você precisa
Ferramentas
Exibir mais…
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Trolltech Greenphone, use o nosso manual de serviço.
  1. Trolltech Greenphone Teardown, Trolltech Greenphone Teardown: passo 1, imagem 1 %32 Trolltech Greenphone Teardown, Trolltech Greenphone Teardown: passo 1, imagem 2 %32
    • here is the Qtopia green phone.
  2. Trolltech Greenphone Teardown: passo 2, imagem 1 %32 Trolltech Greenphone Teardown: passo 2, imagem 2 %32
    • first, remove the mini-SD card from the side of the phone.
  3. Trolltech Greenphone Teardown: passo 3, imagem 1 %32 Trolltech Greenphone Teardown: passo 3, imagem 2 %32 Trolltech Greenphone Teardown: passo 3, imagem 3 %32
    • then, remove the battery from the phone
    • Unlocking the switch for the battery cover is a little difficult.
  4. Trolltech Greenphone Teardown: passo 4, imagem 1 %32 Trolltech Greenphone Teardown: passo 4, imagem 2 %32 Trolltech Greenphone Teardown: passo 4, imagem 3 %32
    • when the battery is removed, remove the pencil from the device
  5. Trolltech Greenphone Teardown: passo 5, imagem 1 %32 Trolltech Greenphone Teardown: passo 5, imagem 2 %32 Trolltech Greenphone Teardown: passo 5, imagem 3 %32
    • this picture shows the two black plastic clips wich you want du unlock if you would like to reach deeper into the interiors of this phone.
    • the 2e pikture show how to place the slotted pan head screwdriver
    • to unlock them you have to turn the screwdriver around its own axe.
    • when you unlocked both, go with an ipod opening tool around the 3 other sides to unlock several other plastic clips, wich shold be easy to do
  6. Trolltech Greenphone Teardown: passo 6, imagem 1 %32
    • now your phone should look like this.
    • there is one seperate little silver plastic switch for the camera lense.
    • don't lose that
  7. Trolltech Greenphone Teardown: passo 7, imagem 1 %32 Trolltech Greenphone Teardown: passo 7, imagem 2 %32 Trolltech Greenphone Teardown: passo 7, imagem 3 %32
    • now remove the only 4 screws in this froggy device.
    • the both on the upper part
    • and at the both at the bottom part
    • and see them lie next to the device
  8. Trolltech Greenphone Teardown: passo 8, imagem 1 %32 Trolltech Greenphone Teardown: passo 8, imagem 2 %32 Trolltech Greenphone Teardown: passo 8, imagem 3 %32
    • now insert an ipod opening tool between the (green) front and the black stripe in the center of the phone
    • be careful, the front is fragile
    • as you are gone around its sides, you can simply disassemble the front panel without disconnecting anything.
  9. Trolltech Greenphone Teardown: passo 9, imagem 1 %32 Trolltech Greenphone Teardown: passo 9, imagem 2 %32
    • now you are able to put the mainboard (the one and only), display and buttons (it appears that this is one huge part) and the black back/mid frame from each other
    • its easy to remove the speaker/antenna and some plastic parts from the back panel
    • the camera is glued on the board, but connected with an usual camera connector.
    • all EMI shields are brazed onto the bord.
  10. Trolltech Greenphone Teardown: passo 10, imagem 1 %32
    • this was the whole thing. thank you for reading this far.
    • fancy phone this is!
lon
Membro desde: 03/19/11
2.873 Reputação
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 3,821
