O que você precisa
Ferramentas
Remove these items by lifting up on the lever until it pops out of place. The spring should come out easily.
Remove the small black screw that is holding the circuit board in place.
Remove the power cord from the power port of the Waver by holding the port with one hand and pulling on the cord with the other hand.
Remove the two metal cylinders by sliding them down the length of the inner soft cylinders.
Remove the plastic cylinder holders by lifting them up and along the length of the cylinder.
Similar to step 4, remove the back metal plate by sliding down the length of the intern cylinder.
Gently lift the circuit board and tilt it to the side.
Lift the dial straight up from the circuit board. It should come off easily.
