Ir para o conteúdo principal
Introdução
Ir para o passo 1
What's in side this ball-shaped camera?
O que você precisa
Ferramentas
Exibir mais…
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Logitech Circle, use o nosso manual de serviço.
  1. Logitech Circle Teardown, Not a Single Screw in Sight!: passo 1, imagem 1 %32 Logitech Circle Teardown, Not a Single Screw in Sight!: passo 1, imagem 2 %32
    • The Circle camera has no external screws. The first step to get in requires a plastic spludger: the dark colored ring is held on with double sticky tape.
    • Note: the ring is made of infrared transparent plastic, and includes lenses to help direct the night vision LEDs.
  2. Logitech Circle Teardown, A Peek Inside: passo 2, imagem 1 %32
    • It's all screws from this point out: a lot of them. Consider using bags to hold groups of screws together for reassembly.
    • Unscrew the four screws circled in order to remove the first ring.
  3. Logitech Circle Teardown: passo 3, imagem 1 %32
    • Remove the next ring by continuing to unscrew the screws in the circled locations.
  4. Logitech Circle Teardown: passo 4, imagem 1 %32 Logitech Circle Teardown: passo 4, imagem 2 %32
    • Finally, remove the last set of screws to access the inner parts of the circle.
    • Gently pull out the lens/battery assemble -- it's attached to a flexible ribbon cable that can rip, so be especially careful.
  5. Logitech Circle Teardown, Inside the Ball: passo 5, imagem 1 %32 Logitech Circle Teardown, Inside the Ball: passo 5, imagem 2 %32
    • Take care not to damage the flexible cable. On the connector, flip up the black plastic cam to release the cable. You can then remove the camera / battery assembly from the ball.
    • Note the extensive use of heat sinks and thermal interface (TIM) materials. This camera is delicately balanced thermally.
  6. Logitech Circle Teardown, Hidden USB Connector: passo 6, imagem 1 %32 Logitech Circle Teardown, Hidden USB Connector: passo 6, imagem 2 %32 Logitech Circle Teardown, Hidden USB Connector: passo 6, imagem 3 %32
    • Ho! What's that? Under a soft spot in the base is a hidden USB connector, presumably used for firmware loading in production.
    • To disassemble the base find 3 screws under the soft spot, punch through using a screwdriver, and remove the screws. After that both parts can be easily separated.
  7. Logitech Circle Teardown, Optical Chain: passo 7, imagem 1 %32 Logitech Circle Teardown, Optical Chain: passo 7, imagem 2 %32
    • The outer ring has lenses to focus IR light, and a hole for the camera lens.
    • The six infrared LEDs are on a thick board, with an aluminum heat spreader, and a connection to two solid metal blocks attached to the sensor board.
    • The lens is manually focused and secured with what looks like hot melt glue (this may cause focus issues over time).
    • There is just one piece of filter glass, flipped in place for day mode (higher end cameras use separate glass for day and night mode).
    • The optical sensor is at the bottom of the stack. It's surrounded by a clear plastic sticker (if you know why, post in the comments!).
Bryce Nesbitt
Membro desde: 11/30/14
1.206 Reputação
Autoria de 8 guias
25Comentários do guia
any ideas where get a replacement ribbon cable? I dropped the camera when opening the box and the base and camera separated (ribbon cable tore). I was able to disassemble with this guide, but now I need a new cable and Logitech is no help (I asked).
Thanks
David
David Ludder - Responder
We just had it fall off the table it was on and it did exactly the same thing... the base and camera separated (ribbon cable tore).
bradowenco -
I emailed the manufacturer of the cable to see if they can help, will let you know if they answer.
any word from them?
bradowenco - Responder
Nothing yet, I'll have to send another email.
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 89
Ao todo: 9,342
