Ir para o conteúdo principal
Introdução
Ir para o passo 1
This is a guide to take apart the Honeywell HF-910 Fan. This guide will allow you to clean the fan or replace broken parts.
O que você precisa
Ferramentas
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Honeywell HF-910 Fan, use o nosso manual de serviço.
  1. Honeywell HF-910 Fan Teardown, Removing fan cage: passo 1, imagem 1 %32 Honeywell HF-910 Fan Teardown, Removing fan cage: passo 1, imagem 2 %32 Honeywell HF-910 Fan Teardown, Removing fan cage: passo 1, imagem 3 %32
    • First, locate 6 screws along the cage of the fan
    • Remove these 6 screws with phillips head screwdriver
    • Remove cage of fan
  2. Honeywell HF-910 Fan Teardown, Removing Fan Blade: passo 2, imagem 1 %32 Honeywell HF-910 Fan Teardown, Removing Fan Blade: passo 2, imagem 2 %32
    • The fan should now look like the first picture
    • Locate the two phillips head screws behind the blades
    • Remove these screws
  3. Honeywell HF-910 Fan Teardown, Removing Motor: passo 3, imagem 1 %32 Honeywell HF-910 Fan Teardown, Removing Motor: passo 3, imagem 2 %32
    • Remove the two screws that are circled in the photo
    • The motor becomes loose with only the wires holding it in place
  4. Honeywell HF-910 Fan Teardown, Accessing Speed Control Connection: passo 4, imagem 1 %32 Honeywell HF-910 Fan Teardown, Accessing Speed Control Connection: passo 4, imagem 2 %32
    • Remove the screw that is circled in the first picture to access the speed control wires
    • The wires connecting to the speed controller are shown in picture #2
  5. Honeywell HF-910 Fan Teardown, Remove Power Supply: passo 5, imagem 1 %32
    • Remove the circled screw in order to access the power supply
  6. Honeywell HF-910 Fan Teardown: passo 6, imagem 1 %32
    • To reassemble device, follow these instructions in reverse order.
Jonathan Wood
Membro desde: 11/17/19
133 Reputação
Autoria de 1 guia
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 54
Ao todo: 4,822
