Ir para o conteúdo principal
O que você precisa
Ferramentas
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua GD Midea FT30-3D, use o nosso manual de serviço.
  1. GD Midea FT30-3D Teardown, Bottom Base: passo 1, imagem 1 %32
    • Locate and remove the 14.5 mm Phillips #1 screw on the bottom of the fan base.
  2. GD Midea FT30-3D Teardown: passo 2, imagem 1 %32 GD Midea FT30-3D Teardown: passo 2, imagem 2 %32
    • Locate the gray base support release tabs found on either side pictured in the first image.
    • There are release tabs on each side of the base.
    • Press both release tabs in with the tip of your fingers and pull the gray base support until the tabs are cleared.
  3. GD Midea FT30-3D Teardown: passo 3, imagem 1 %32
    • Continue removing the gray base support by pressing your thumb into the circular opening in the base and pulling with your figures on the back side.
    • Notice that on the internal front tip of the base there is a tab. Because of this tab the back end will pivot off at that point.
  4. GD Midea FT30-3D Teardown: passo 4, imagem 1 %32
    • After the base has separated more it will be easy to fully remove it. Continue pulling the back edge of the gray base support, rotating it around the front tab until it comes off completely.
  5. GD Midea FT30-3D Teardown: passo 5, imagem 1 %32
    • Remove the following five 14.5 mm Phillips #1 screws found on the bottom.
    • All of the screws are recessed by 17.5 mm, so ensure your screwdriver can reach that far.
  6. GD Midea FT30-3D Teardown: passo 6, imagem 1 %32
    • Once all five screws have been removed the base cover should fall right off with out any effort.
    • When putting the base cover back on; be careful to make sure that none of the wires are pinched.
    • Free the power switch from the base housing. Remove 2 screws.
    • Release the power cord by removing part #20 by removing 2 screws.
    • Remove the wire fastener(#6) by removing screw #5 to free the main wire bundle from the fan base housing.
    • Remove the switch. To pull the wires out of the switch gently push a screwdriver into the same hole the wire enters and the wire should slide out.
    • Remove the bolt that holds the fan's upper assembly from the fan body.
    • Remove oscillation pin by removing the screw that connects to the oscillator.
    • Remove front fan guard by locating and releasing 3 clips that hold it to the rear fan guard.
    • Remove fan blades by removing part #12. When reassembling make sure the notches in the fan blade's center line up with the perpendicular protrusions on the metal shaft.
    • Remove rear fan guard by removing part #13; it comes off like a screw.
    • Remove front fan motor housing by removing 4 screws.
    • Remove main fan motor housing by removing a single screw in the back.
    • Remove the capacitor by removing the screw that holds it to the fan.
    • Remove oscillation mechanism by removing the screw that connects it to the rocker arm. Push the rocker arm down and pull the oscillator off.
    • Remove the plug and the screw that lies beneath it.
Alan Su
Membro desde: 10/03/12
810 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 24-28, Regan Fall 2012 Membro de Cal Poly, Team 24-28, Regan Fall 2012
CPSU-REGAN-F12S24G28
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 1,933
