O que você precisa
Ferramentas
Exibir mais…
Heat the back with a heat gun at 130C to loosen the adhesive.
Pry the side opposite the connector area from the strap latch
Pry the top and bottom near the connector. There are small plastic pins.
TI 14WP6JP AFE4500 - Texas Instruments Ultra-Small, Integrated AFE for Bio-Impedance Analysis, Electrical Biosensing and Optical Bio-sensing
TI13AD5R8 BQ25156 - Texas Instruments BQ25 series 1S battery charger
121 2624 C72S - Unknown
Pry from the sides of the battery to lift out. There is some adhesive/foam between the battery and case
You will have to cut the flex cables to the capacitive touch buttons on either side
271617 unbranded battery. Marked as 65mAh
Mine tested at 24mAh, after a few years of use
761EJ1U1 - Mitsumi MC3761 series protection IC with integrated MOS-FET for protection of the rechargeable Lithium-ion or Lithium-polymer battery
A temp sensor somewhere
The can pops off easily with a razor blade starting at the corners
Hi Morgan 👋
2M AMA4B 212501 HADD - Ambiq Micro, Inc. Apollo4 Blue Lite SoC
QUAM V14 - Looks like a custom branded Fitbit chip
12110 U25A - Unknown
NXP 100TB2 VC95122 037-080 - Unknown
Is this the GPS receiver? (if not, where is it?)
Heat the screen to 130C
Push it out from inside
As the screen pushes out slightly, it should reveal 3x PH000 screws to undo (I ended up just cutting the metal tabs)
