Ir para o conteúdo principal
iRobot Roomba 890 Motorized Wheel Module Replacement
Dustin Staples
Dustin Staples e 4 outros colaboradores
Última atualização em September 11, 2024
5 - 10 minutos
Fácil
Introdução
Ir para o passo 1
The iRobot Roomba 890, Model #R890020, is an autonomous robotic vacuum cleaner that is intended to make cleaning more accessible and convenient. If your Roomba 890 wheels become blocked with hair or dust, it is a good idea to replace them. This guide will teach you how to remove and replace the Roomba's two motorized wheel modules, which will help prevent floor damage. There are no specific needs or prerequisites for understanding and implementing the procedures outlined in this guide.
O que você precisa
Ferramentas
A iFixit ganha comissão quando você compra por estes links.
  1. iRobot Roomba 890 Motorized Wheel Module Replacement, Motorized Wheel Module: passo 1, imagem 1 %32 iRobot Roomba 890 Motorized Wheel Module Replacement, Motorized Wheel Module: passo 1, imagem 2 %32
    • Use a Phillips #2 screwdriver to remove the 7.7 mm screw securing the side brush-head.
    • Remove the yellow brush head.
  2. iRobot Roomba 890 Motorized Wheel Module Replacement: passo 2, imagem 1 %32
    • Place the Roomba with its bottom facing toward you.
    • Use a Phillips #2 screwdriver to remove the four 11 mm screws.
  3. iRobot Roomba 890 Motorized Wheel Module Replacement: passo 3, imagem 1 %32 iRobot Roomba 890 Motorized Wheel Module Replacement: passo 3, imagem 2 %32
    • Remove the battery by pulling directly up on the grey pull tabs.
  4. iRobot Roomba 890 Motorized Wheel Module Replacement: passo 4, imagem 1 %32
    • Lift off the baseplate.
  5. iRobot Roomba 890 Motorized Wheel Module Replacement: passo 5, imagem 1 %32 iRobot Roomba 890 Motorized Wheel Module Replacement: passo 5, imagem 2 %32
    • Remove the collection bin by pressing the release button on the top side of the Roomba and pulling straight out.
  6. iRobot Roomba 890 Motorized Wheel Module Replacement: passo 6, imagem 1 %32 iRobot Roomba 890 Motorized Wheel Module Replacement: passo 6, imagem 2 %32
    • On the underside of the Roomba, use a Phillips #1 screwdriver to remove the three 15.5 mm screws.
  7. iRobot Roomba 890 Motorized Wheel Module Replacement: passo 7, imagem 1 %32
    • Grip both sides of the casing and pull it straight out.
Conclusão
Dustin Staples
Membro desde: 03/28/22
339 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 16
Ao todo: 580
