Ir para o conteúdo principal
iPhone 6s Plus Logic Board Replacement
O que você precisa
  1. iPhone 6s Plus Logic Board Replacement, Pentalobe Screws: passo 1, imagem 1 %32
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm Pentalobe screws on either side of the Lightning port.
    Pergunte ao FixBot
    Comentar
  2. iPhone 6s Plus Logic Board Replacement, Anti-Clamp instructions: passo 2, imagem 1 %32 iPhone 6s Plus Logic Board Replacement, Anti-Clamp instructions: passo 2, imagem 2 %32 iPhone 6s Plus Logic Board Replacement, Anti-Clamp instructions: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Pergunte ao FixBot
    Comentar
  3. iPhone 6s Plus Logic Board Replacement: passo 3, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 3, imagem 2 %32 iPhone 6s Plus Logic Board Replacement: passo 3, imagem 3 %32
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Pergunte ao FixBot
    Comentar
  4. iPhone 6s Plus Logic Board Replacement, Opening Procedure: passo 4, imagem 1 %32
    Clampy - Anti-Clamp
    $24.95
    • If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
    • Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
    • Heat softens the adhesive securing the display, making it easier to open.
    Pergunte ao FixBot
    Comentar
  5. iPhone 6s Plus Logic Board Replacement: passo 5, imagem 1 %32
    • Opening the display on the 6s Plus separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
    • Apply a suction cup to the lower left corner of the display assembly.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    Pergunte ao FixBot
    Comentar
  6. iPhone 6s Plus Logic Board Replacement: passo 6, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 6, imagem 2 %32
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
    Pergunte ao FixBot
    Comentar
  7. iPhone 6s Plus Logic Board Replacement: passo 7, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 7, imagem 2 %32 iPhone 6s Plus Logic Board Replacement: passo 7, imagem 3 %32
    • The safest place to pry from is the notch in the front panel above the headphone jack.
    • While still maintaining pressure on the suction cup, insert the flat tip of a spudger into the gap, directly above the headphone jack.
    Pergunte ao FixBot
    Comentar
  8. iPhone 6s Plus Logic Board Replacement: passo 8, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 8, imagem 2 %32
    • Twist the spudger to widen the gap between the front panel and the rear case.
    Pergunte ao FixBot
    Comentar
  9. iPhone 6s Plus Logic Board Replacement: passo 9, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 9, imagem 2 %32 iPhone 6s Plus Logic Board Replacement: passo 9, imagem 3 %32
    • While firmly pulling up on the suction cup, slide the edge of the spudger under the bottom left corner of the display.
    Pergunte ao FixBot
    Comentar
  10. iPhone 6s Plus Logic Board Replacement: passo 10, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 10, imagem 2 %32
    • Slide the tip of the spudger up the left side of the phone, between the front panel and the rear case.
    Pergunte ao FixBot
    Comentar
  11. iPhone 6s Plus Logic Board Replacement: passo 11, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 11, imagem 2 %32
    • Insert the flat tip of the spudger under the right edge of the display.
    • Slide the spudger up the right side.
    Pergunte ao FixBot
    Comentar
  12. iPhone 6s Plus Logic Board Replacement: passo 12, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 12, imagem 2 %32
    • Use a plastic opening tool to hold down the rear case while pulling up the suction cup to open the phone.
    • Do not remove the display completely, or you will damage the data cables connecting the display near the top edge of the iPhone.
    Pergunte ao FixBot
    Comentar
  13. iPhone 6s Plus Logic Board Replacement: passo 13, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 13, imagem 2 %32
    • Pull up on the small nub on the suction cup to remove it from the display.
    Pergunte ao FixBot
    Comentar
  14. iPhone 6s Plus Logic Board Replacement: passo 14, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 14, imagem 2 %32 iPhone 6s Plus Logic Board Replacement: passo 14, imagem 3 %32
    • Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Don't open the display more than 90º—it is still connected to the top of the phone by the display, digitizer, and front camera cables which can tear easily.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to support the display.
    Pergunte ao FixBot
    Comentar
  15. iPhone 6s Plus Logic Board Replacement, Battery Connector: passo 15, imagem 1 %32
    Magnetic Project Mat
    $19.95
    • Remove two Phillips screws securing the battery connector bracket to the logic board, of the following lengths:
    • One 2.9 mm screw
    • One 2.3 mm screw
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
    Pergunte ao FixBot
    Comentar
  16. iPhone 6s Plus Logic Board Replacement: passo 16, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 16, imagem 2 %32
    • Remove the battery connector bracket.
    Pergunte ao FixBot
    Comentar
  17. iPhone 6s Plus Logic Board Replacement: passo 17, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 17, imagem 2 %32 iPhone 6s Plus Logic Board Replacement: passo 17, imagem 3 %32
    • Use a spudger or a clean fingernail to disconnect the battery connector by prying it straight up off the logic board.
    Pergunte ao FixBot
    Comentar
  18. iPhone 6s Plus Logic Board Replacement: passo 18, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 18, imagem 2 %32 iPhone 6s Plus Logic Board Replacement: passo 18, imagem 3 %32
    • Bend the connector back to ensure it doesn't make contact and power the iPhone on while you're working on it.
    Pergunte ao FixBot
    Comentar
  19. iPhone 6s Plus Logic Board Replacement, Display Assembly: passo 19, imagem 1 %32
    • Remove the following Phillips screws:
    • Three 1.3 mm screws
    • One 1.6 mm screw
    • One 3.0 mm screw
    • During reassembly, it's critical to place this 3.0 mm screw in the top-right corner of the bracket. Placing it anywhere else may damage the logic board.
    Pergunte ao FixBot
    Comentar
  20. iPhone 6s Plus Logic Board Replacement: passo 20, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 20, imagem 2 %32
    • Remove the display cable bracket.
    Pergunte ao FixBot
    Comentar
  21. iPhone 6s Plus Logic Board Replacement: passo 21, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 21, imagem 2 %32
    • Be careful to only pry up on the connector itself and not the socket on the logic board.
    • Use a plastic opening tool to disconnect the front-facing camera and sensor cable connector.
    Pergunte ao FixBot
    Comentar
  22. iPhone 6s Plus Logic Board Replacement: passo 22, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 22, imagem 2 %32
    • Use a plastic opening tool to disconnect the digitizer cable by prying it straight up from its socket on the logic board.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
    Pergunte ao FixBot
    Comentar
  23. iPhone 6s Plus Logic Board Replacement: passo 23, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 23, imagem 2 %32
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Disconnect the home button/fingerprint sensor cable by prying it straight up from its socket on the logic board.
    Pergunte ao FixBot
    Comentar
  24. iPhone 6s Plus Logic Board Replacement: passo 24, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 24, imagem 2 %32
    Pergunte ao FixBot
    Comentar
  25. iPhone 6s Plus Logic Board Replacement, iSight Camera: passo 25, imagem 1 %32 iPhone 6s Plus Logic Board Replacement, iSight Camera: passo 25, imagem 2 %32 iPhone 6s Plus Logic Board Replacement, iSight Camera: passo 25, imagem 3 %32
    • Peel up any tape covering the iSight camera bracket screws.
    Pergunte ao FixBot
    Comentar
  26. iPhone 6s Plus Logic Board Replacement: passo 26, imagem 1 %32
    • Remove the following Phillips screws over the camera bracket:
    • One 1.9 mm screw
    • One 2.4 mm screw
    Pergunte ao FixBot
    Comentar
  27. iPhone 6s Plus Logic Board Replacement: passo 27, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 27, imagem 2 %32
    • Remove the iSight camera bracket.
    Pergunte ao FixBot
    Comentar
  28. iPhone 6s Plus Logic Board Replacement: passo 28, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 28, imagem 2 %32
    • Disconnect the iSight camera connector from its socket on the logic board.
    • Be sure to pry up only the connector and not the socket on the logic board.
    Pergunte ao FixBot
    Comentar
  29. iPhone 6s Plus Logic Board Replacement: passo 29, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 29, imagem 2 %32
    • Insert the flat end of the spudger between the iSight camera and rear casing.
    • Gently pry the camera out from its housing.
    Pergunte ao FixBot
    Comentar
  30. iPhone 6s Plus Logic Board Replacement: passo 30, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 30, imagem 2 %32
    • Remove the iSight camera.
    Pergunte ao FixBot
    Comentar
  31. iPhone 6s Plus Logic Board Replacement, SIM Tray: passo 31, imagem 1 %32 iPhone 6s Plus Logic Board Replacement, SIM Tray: passo 31, imagem 2 %32
    • Insert a SIM eject tool into the hole in the SIM tray.
    • Press to eject the SIM tray.
    Pergunte ao FixBot
    Comentar
  32. iPhone 6s Plus Logic Board Replacement: passo 32, imagem 1 %32
    • Remove the SIM tray.
    • When reinserting the SIM tray, be sure to orient the tray such that the SIM eject hole is on the bottom.
    Pergunte ao FixBot
    Comentar
  33. iPhone 6s Plus Logic Board Replacement, Logic Board: passo 33, imagem 1 %32
    • Remove the single 1.4 mm Phillips screw holding the NFC bracket in place.
    Pergunte ao FixBot
    Comentar
  34. iPhone 6s Plus Logic Board Replacement: passo 34, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 34, imagem 2 %32
    • Remove the NFC bracket.
    Pergunte ao FixBot
    Comentar
  35. iPhone 6s Plus Logic Board Replacement: passo 35, imagem 1 %32
    • Remove the two 2.7 mm Phillips screws securing the audio control cable bracket to the logic board.
    Pergunte ao FixBot
    Comentar
  36. iPhone 6s Plus Logic Board Replacement: passo 36, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 36, imagem 2 %32
    • Remove the audio control cable bracket.
    Pergunte ao FixBot
    Comentar
  37. iPhone 6s Plus Logic Board Replacement: passo 37, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 37, imagem 2 %32
    • Disconnect the audio control cable by prying its connector straight up from its socket on the logic board.
    Pergunte ao FixBot
    Comentar
  38. iPhone 6s Plus Logic Board Replacement: passo 38, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 38, imagem 2 %32
    • Disconnect the cellular antenna cable by prying its connector straight up from its respective socket on the logic board.
    Pergunte ao FixBot
    Comentar
  39. iPhone 6s Plus Logic Board Replacement: passo 39, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 39, imagem 2 %32
    • Disconnect the Wi-Fi diversity antenna cable by prying its connector up from the logic board.
    Pergunte ao FixBot
    Comentar
  40. iPhone 6s Plus Logic Board Replacement: passo 40, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 40, imagem 2 %32
    • Disconnect the power button flex cable from its socket on the logic board.
    Pergunte ao FixBot
    Comentar
  41. iPhone 6s Plus Logic Board Replacement: passo 41, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 41, imagem 2 %32
    • Disconnect the antenna cable by prying it up from the logic board.
    Pergunte ao FixBot
    Comentar
  42. iPhone 6s Plus Logic Board Replacement: passo 42, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 42, imagem 2 %32
    • Use the flat end of a spudger to disconnect the Lightning connector flex cable from the logic board.
    Pergunte ao FixBot
    Comentar
  43. iPhone 6s Plus Logic Board Replacement: passo 43, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 43, imagem 2 %32 iPhone 6s Plus Logic Board Replacement: passo 43, imagem 3 %32
    • Deroute the antenna cable from the two clips on the right edge of the logic board.
    Pergunte ao FixBot
    Comentar
  44. iPhone 6s Plus Logic Board Replacement: passo 44, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 44, imagem 2 %32
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the following screws:
    • One 1.3 mm Phillips screw
    • One 2.6 mm Phillips screw
    • One 2.2 mm standoff screw
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    Pergunte ao FixBot
    Comentar
  45. iPhone 6s Plus Logic Board Replacement: passo 45, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 45, imagem 2 %32
    • Remove the bracket.
    Pergunte ao FixBot
    Comentar
  46. iPhone 6s Plus Logic Board Replacement: passo 46, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 46, imagem 2 %32
    • Deroute the upper left cellular antenna cable from the first logic board clip by nudging it out from under the clip, towards the battery.
    Pergunte ao FixBot
    Comentar
  47. iPhone 6s Plus Logic Board Replacement: passo 47, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 47, imagem 2 %32 iPhone 6s Plus Logic Board Replacement: passo 47, imagem 3 %32
    • Continue derouting the cellular antenna cable from the second and third logic board clips.
    • Use the pointed tip of a spudger to gently pry the cellular antenna cable from the middle logic board clip.
    • Don't try to remove it by pulling on the cable, as it will tear easily.
    • In order for the cable to reach its socket on the logic board, you must route it above the logic board and underneath the audio control flex cable, as shown in the first photo.
    Pergunte ao FixBot
    Comentar
  48. iPhone 6s Plus Logic Board Replacement: passo 48, imagem 1 %32
    • Remove the final 2.0 mm Phillips screw directly below the SIM card reader.
    Pergunte ao FixBot
    Comentar
  49. iPhone 6s Plus Logic Board Replacement: passo 49, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 49, imagem 2 %32 iPhone 6s Plus Logic Board Replacement: passo 49, imagem 3 %32
    • Carefully raise—but do not remove—the logic board, lifting it from the bottom edge nearest the Lightning connector.
    Pergunte ao FixBot
    Comentar
  50. iPhone 6s Plus Logic Board Replacement: passo 50, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 50, imagem 2 %32 iPhone 6s Plus Logic Board Replacement: passo 50, imagem 3 %32
    • Tip the logic board up to a vertical position to expose the single antenna connector on the underside, near the top edge of the board.
    • Do not attempt to fully remove the logic board yet, as the Wi-Fi/Bluetooth antenna is still connected to the underside of the board.
    Pergunte ao FixBot
    Comentar
  51. iPhone 6s Plus Logic Board Replacement: passo 51, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 51, imagem 2 %32
    • Gently lay the logic board upside-down, with the top portion resting against the rear case of the iPhone.
    • Use the flat end of the spudger to disconnect the Wi-Fi/Bluetooth antenna cable from its socket on the back of the logic board.
    Pergunte ao FixBot
    Comentar
  52. iPhone 6s Plus Logic Board Replacement: passo 52, imagem 1 %32
    • Remove the logic board.
    Pergunte ao FixBot
    Comentar
Conclusão
87 outras pessoas executaram este guia.
Dante Mazzanti
Membro desde: 07/13/15
36.634 Reputação
Autoria de 26 guias
24Comentários do guia
Great guide thanks. I just want to ask: Does screw length include the head or not? If not, what's the best way to measure those tiny screws? I have digital calipers but measuring them is quite awkward.
AMT - Responder Compartilhar
Measurements are for the entire length of the screw, including the head. Putting the whole screw into a digital caliper should give you a reading very close to what you see here.
Jeff Suovanen - Responder Compartilhar
Hi there! Great guide. Thank you. I was wondering if you ever removed the metal shields? If yes, how? I want to try to fix a water damaged phone.
Thanks!
LexiiCarrillo - Responder Compartilhar
Hey so I'm having a Problem with my iPhone 6s plus it won't respond to my Finger touch> i cleaned it , i Hold Lock and Home Button and nothing still same thing, i also Restored cause that what apple Suggested to do if none of those steps worked. Please Guys i need help on this one i really don't wanna pay a whole 500$ for a new iPhone.
Vick - Responder Compartilhar
i would replace the main logic board, make sure the board comes with the touch ID, as they are programed to work with the board. You will see main logic boards cheaper without the Touch ID. don’t buy that. I had to replace mine, and all is good now. If you are not good with working with installing the main logic board, buy one and have someone help you that knows how to do that.
Scott C - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 45
Últimos 30 dias: 204
Ao todo: 97,920
