Introdução
This guide shows how to remove and replace the loudspeaker or lower speaker in your iPhone 16 Pro Max.
If the sound coming through your iPhone's bottom speaker is faint or crackling, your loudspeaker may need to be replaced.
You'll need replacement back glass adhesive to complete this repair.
O que você precisa
Unplug any cables from your iPhone.
Hold the power and either volume buttons, and slide to power off your iPhone.
If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
Use a P2 pentalobe driver to remove the two 7.4 mm-long screws on either side of the charge port.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Ferramenta utilizada neste passo:iOpener$14.95
Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
A delicate cable connecting the back glass to the iPhone, right next to the volume up button. Don't insert your pick here to avoid slicing the cable.
Multiple spring contacts around the perimeter of the iPhone.
Slide the opening pick along the bottom edge to slice the adhesive.
Leave the opening pick in the bottom-left corner to prevent the adhesive from resealing.
Use a hair dryer or heat gun to heat the left edge of the back glass until it's hot to the touch.
Insert a second opening pick into the bottom-left corner, close to the existing pick.
Slide your pick along the left edge to separate the adhesive and release the metal clips.
Leave this pick inserted in the top-left corner to prevent the adhesive from resealing.
Use a hair dryer or heat gun to heat the top edge and top-right corner of the back glass until it's hot to the touch.
Insert a third opening pick into the top-left corner.
Slide the opening pick along the top edge and around the top-right corner, stopping above the volume up button.
Leave this pick inserted to prevent the adhesive from resealing.
Use a hair dryer or heat gun to heat the right edge of the back glass until it's hot to the touch.
Insert a fourth opening pick into the bottom-right corner.
Slide the opening pick around the corner and up the right edge, stopping below the volume down button.
Swing open the back glass to the right of the iPhone to separate the remaining adhesive.
Support the back glass with a clean, sturdy object.
Use a tri-point Y000 driver to remove the three screws securing the battery connector cover:
Two 1.3 mm‑long screws
One 1.0 mm‑long screw
Use the point of a spudger to pry up and disconnect the battery press connector.
Use a tri-point Y000 driver to remove the four screws securing the back glass connector cover:
Two 1.0 mm‑long screws
Use the point of a spudger to pry up and disconnect the back glass connector.
Use a Phillips screwdriver to remove the three screws securing the Taptic Engine cover:
One 2.9 mm‑long screw
One 1.3 mm‑long screw
One 2.4 mm‑long screw
Use the point of a spudger to pry up and disconnect the lower assembly cable from the logic board.
Use a Phillips screwdriver to remove the 2.1 mm‑long screw securing the Taptic Engine.
Remove the four screws securing the loudspeaker:
One 1.7 mm‑long Phillips screw
One 1.5 mm‑long Phillips screw
One 4.1 mm‑long standoff screw
One 1.3 mm‑long tri-point Y000 screw
Angle the bottom edge of the loudspeaker towards the frame.
Press the loudspeaker into its recess.
Ferramenta utilizada neste passo:Tweezers$4.99
Use blunt nose tweezers or your fingers to remove large pieces of adhesive from the frame perimeter.
Use a spudger to scrape the adhesive residue off of the frame.
Ferramenta utilizada neste passo:Microfiber Cleaning Cloths$3.99
If you're reusing your back glass, apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to a microfiber or lint-free cloth and wipe around the perimeter to prepare the surface for new adhesive.
Wrap a lint-free cloth or a coffee filter over the point of a spudger and apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to it.
Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
Lay the adhesive sheet over the frame to determine its proper orientation.
Use your finger or a spudger to press and connect the battery press connector onto the logic board.
Align the back glass connector cover by its screw holes and lay it in place.
Use your fingers or a spudger to peel away all perimeter liners, exposing the adhesive.
Check the frame and back glass for any stray liners and remove them. There should be no liners remaining.
Lower the back glass onto the frame, beginning with the top edge.
Press along the edges of the iPhone until the back glass sits flush against the frame.
Use a hair dryer, heat gun, or an iOpener to heat the back glass perimeter until it's slightly too hot to touch.
Use your fingers to firmly squeeze around the perimeter of the iPhone.
Use a P2 pentalobe driver to install the two 7.4 mm-long screws on either side of the charge port.
