Ir para o conteúdo principal
iPhone 16 Battery Replacement
O que você precisa
  1. iPhone 16 Battery Replacement, Before you begin: passo 1, imagem 1 %32 iPhone 16 Battery Replacement, Before you begin: passo 1, imagem 2 %32
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 16 Battery Replacement, Tape over any cracks: passo 2, imagem 1 %32 iPhone 16 Battery Replacement, Tape over any cracks: passo 2, imagem 2 %32
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 16 Battery Replacement, Remove the pentalobe screws: passo 3, imagem 1 %32 iPhone 16 Battery Replacement, Remove the pentalobe screws: passo 3, imagem 2 %32
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
  4. iPhone 16 Battery Replacement, Mark your opening picks: passo 4, imagem 1 %32 iPhone 16 Battery Replacement, Mark your opening picks: passo 4, imagem 2 %32 iPhone 16 Battery Replacement, Mark your opening picks: passo 4, imagem 3 %32
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - Responder
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - Responder
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - Responder
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - Responder
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - Responder
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - Responder
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - Responder
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - Responder
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - Responder
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - Responder
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - Responder
  5. iPhone 16 Battery Replacement, Secure the screen: passo 5, imagem 1 %32 iPhone 16 Battery Replacement, Secure the screen: passo 5, imagem 2 %32 iPhone 16 Battery Replacement, Secure the screen: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • The next four steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down four steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • The Anti-Clamp applies suction to both the screen and the back glass. To open only the back glass, you need to secure the screen with tape. You can also check out the full instructions on how to use this tape.
    • Cut two strips of tape, apply them along the long edges of the phone, and fold them over the screen to secure it.
    • Make sure the tape is only securing the screen and not the back glass.
  6. iPhone 16 Battery Replacement, Secure an Anti-Clamp: passo 6, imagem 1 %32 iPhone 16 Battery Replacement, Secure an Anti-Clamp: passo 6, imagem 2 %32 iPhone 16 Battery Replacement, Secure an Anti-Clamp: passo 6, imagem 3 %32
    • Pull the Anti-Clamp's blue handle backward to unlock the arms.
    • With the back glass facing up, slide the arms over the right edge of your phone, with one suction cup on the back glass and the other on the screen. Center the suction cups near the bottom edge.
    • Support your phone so it rests level while between the Anti-Clamp's arms—a small box works well.
    • Squeeze the cups together to create suction.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  7. iPhone 16 Battery Replacement, Create a gap under the back glass: passo 7, imagem 1 %32 iPhone 16 Battery Replacement, Create a gap under the back glass: passo 7, imagem 2 %32 iPhone 16 Battery Replacement, Create a gap under the back glass: passo 7, imagem 3 %32
    • Pull the blue handle forward to lock the arms.
    • Turn the handle one full turn (360 degrees) or until the cups start to stretch.
    • As the cups stretch, make sure they stay vertically aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
    • If you don't have tape, you may warm up the suction cups to help them stick.
  8. iPhone 16 Battery Replacement, Insert an opening pick: passo 8, imagem 1 %32 iPhone 16 Battery Replacement, Insert an opening pick: passo 8, imagem 2 %32
    • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    • Wait up to a minute for the adhesive to separate and a gap to form between the back glass and the frame.
    • If a gap doesn't appear after one minute, apply more heat and rotate the handle a quarter turn. Let the Anti‑Clamp and time do the work for you.
    • Insert an opening pick into the gap.
    • Remove the Anti-Clamp using the pull tabs on the suction cups.
    • Skip the next two steps.
  9. iPhone 16 Battery Replacement, Heat the bottom edge: passo 9, imagem 1 %32
    iOpener
    $12.99
    • You can also use an iOpener to heat the back glass. Follow these instructions to heat and apply the iOpener properly.
  10. iPhone 16 Battery Replacement, Insert an opening pick: passo 10, imagem 1 %32 iPhone 16 Battery Replacement, Insert an opening pick: passo 10, imagem 2 %32 iPhone 16 Battery Replacement, Insert an opening pick: passo 10, imagem 3 %32
    • Apply a suction handle to the bottom edge of the back glass.
    • While supporting the frame with one hand, pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
  11. iPhone 16 Battery Replacement, Back glass information: passo 11, imagem 1 %32
    • As you slice the adhesive securing the back glass in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
    • A delicate cable connecting the back glass to the phone, right next to the volume down button. Don't insert your pick here to avoid slicing the cable.
    • Multiple spring contacts around the perimeter of the phone.
  12. iPhone 16 Battery Replacement, Heat the right edge: passo 12, imagem 1 %32
    • Use a hair dryer or heat gun to heat the right edge of the back glass until it's hot to the touch.
  13. iPhone 16 Battery Replacement, Separate the bottom right adhesive: passo 13, imagem 1 %32 iPhone 16 Battery Replacement, Separate the bottom right adhesive: passo 13, imagem 2 %32 iPhone 16 Battery Replacement, Separate the bottom right adhesive: passo 13, imagem 3 %32
    • Don't insert your pick deeper than 3 mm to avoid damaging the spring contacts.
    • Slide your pick around the bottom right corner and to the volume down button to separate the adhesive and release the metal clip.
    • Don't slide past the volume buttons to avoid damaging the wireless charging cable.
    • You'll hear and feel the metal clip release as you pass it.
    • Leave this pick inserted to prevent the adhesive from resealing.
  14. iPhone 16 Battery Replacement, Heat the left edge: passo 14, imagem 1 %32
    • Use a hair dryer or heat gun to heat the left edge of the back glass until it's hot to the touch.
  15. iPhone 16 Battery Replacement, Separate the left adhesive: passo 15, imagem 1 %32 iPhone 16 Battery Replacement, Separate the left adhesive: passo 15, imagem 2 %32 iPhone 16 Battery Replacement, Separate the left adhesive: passo 15, imagem 3 %32
    • Insert a second opening pick at the bottom edge.
    • Slide the second pick around the bottom left corner and along the left edge of the screen to separate the adhesive and release the metal clips.
    • You'll hear and feel the metal clips release as you pass them.
    • Leave this pick inserted at the top left corner to prevent the adhesive from resealing.
  16. iPhone 16 Battery Replacement, Heat the top edge: passo 16, imagem 1 %32
    • Use a hair dryer or heat gun to heat the top edge of the back glass until it's hot to the touch.
  17. iPhone 16 Battery Replacement, Separate the top right adhesive: passo 17, imagem 1 %32 iPhone 16 Battery Replacement, Separate the top right adhesive: passo 17, imagem 2 %32 iPhone 16 Battery Replacement, Separate the top right adhesive: passo 17, imagem 3 %32
    • Slide your second opening pick around the top left corner and along the top edge to separate the adhesive and release the metal clips.
    • Continue sliding your pick around the top right corner until you reach the Action button.
  18. iPhone 16 Battery Replacement, Reposition the back glass: passo 18, imagem 1 %32 iPhone 16 Battery Replacement, Reposition the back glass: passo 18, imagem 2 %32 iPhone 16 Battery Replacement, Reposition the back glass: passo 18, imagem 3 %32
    • At this point, the back glass should be free from the frame. If the back glass feels stuck, go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
    • Swing open the back glass to the right of the phone to separate the remaining adhesive.
    • Support the back glass with a clean, sturdy object.
    • Remove the opening picks before continuing.
  19. iPhone 16 Battery Replacement, Remove the middle connector cover screws: passo 19, imagem 1 %32 iPhone 16 Battery Replacement, Remove the middle connector cover screws: passo 19, imagem 2 %32
    • Use a tri-point Y000 driver to remove the two 1 mm‑long screws securing the middle connector cover.
  20. iPhone 16 Battery Replacement, Remove the middle connector cover: passo 20, imagem 1 %32 iPhone 16 Battery Replacement, Remove the middle connector cover: passo 20, imagem 2 %32 iPhone 16 Battery Replacement, Remove the middle connector cover: passo 20, imagem 3 %32
    • Insert the point of a spudger in either cutout on the middle connector cover.
    • Slide the cover towards the left edge of the phone and release its hook from its slot on the logic board.
    • Remove the cover.
  21. iPhone 16 Battery Replacement, Disconnect the battery: passo 21, imagem 1 %32 iPhone 16 Battery Replacement, Disconnect the battery: passo 21, imagem 2 %32
    • Use the point of a spudger to pry up and disconnect the battery press connector.
  22. iPhone 16 Battery Replacement, Disconnect the wireless charging coil: passo 22, imagem 1 %32 iPhone 16 Battery Replacement, Disconnect the wireless charging coil: passo 22, imagem 2 %32
    • Use the point of a spudger to pry up and disconnect the wireless charging coil press connector.
  23. iPhone 16 Battery Replacement, Remove the back glass: passo 23, imagem 1 %32
    • Lift the back glass off the frame and remove it.
  24. iPhone 16 Battery Replacement, Separate the silver tab: passo 24, imagem 1 %32 iPhone 16 Battery Replacement, Separate the silver tab: passo 24, imagem 2 %32
    • Use an opening pick, or a clean fingernail, to peel up the silver tab at the bottom edge of the battery.
  25. iPhone 16 Battery Replacement, Assemble the VoltClip: passo 25, imagem 1 %32 iPhone 16 Battery Replacement, Assemble the VoltClip: passo 25, imagem 2 %32
    • Plug the VoltClip's barrel connector into the USB-C elbow.
    • Don't connect the VoltClip to a power source just yet. The loose alligator clips may accidentally touch each other and cause an electrical short.
  26. iPhone 16 Battery Replacement, Attach the alligator clips: passo 26, imagem 1 %32 iPhone 16 Battery Replacement, Attach the alligator clips: passo 26, imagem 2 %32
    • Attach the red alligator clip to the silver tab.
  27. iPhone 16 Battery Replacement: passo 27, imagem 1 %32 iPhone 16 Battery Replacement: passo 27, imagem 2 %32 iPhone 16 Battery Replacement: passo 27, imagem 3 %32
    • Attach the black alligator clip to the grounding screw.
  28. iPhone 16 Battery Replacement, Connect power to the VoltClip: passo 28, imagem 1 %32 iPhone 16 Battery Replacement, Connect power to the VoltClip: passo 28, imagem 2 %32 iPhone 16 Battery Replacement, Connect power to the VoltClip: passo 28, imagem 3 %32
    • Make sure the red alligator clip isn't touching any stray metallic surfaces.
    • Connect a powered USB-C cable to the USB-C elbow and wait 90 seconds for the adhesive to loosen.
  29. iPhone 16 Battery Replacement, Disconnect the VoltClip: passo 29, imagem 1 %32 iPhone 16 Battery Replacement, Disconnect the VoltClip: passo 29, imagem 2 %32 iPhone 16 Battery Replacement, Disconnect the VoltClip: passo 29, imagem 3 %32
    • Disconnect the USB-C cable from the elbow, then disconnect the alligator clips.
  30. iPhone 16 Battery Replacement, Remove the battery: passo 30, imagem 1 %32 iPhone 16 Battery Replacement, Remove the battery: passo 30, imagem 2 %32 iPhone 16 Battery Replacement, Remove the battery: passo 30, imagem 3 %32
    • Your adhesive should be fully loosened at this point. If your battery doesn't budge during the step, reconnect the alligator clips for an additional minute and try again.
    • Grip the silver tab and lift the battery out of the frame.
    • Alternatively, you can use a suction handle to pull the battery out. If the battery doesn't come out easily, don't force it—repeat the previous step.
Conclusão
After your repair, run Apple's Repair Assistant. Navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Answers Community for help.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
162.011 Reputação
Autoria de 769 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.415 guias
Um comentário
Thats some crazy stuff going on with the battery. Gonna need the same method to loosesn the back glass somehow. Maybe a hidden Positive and negaitve terminal in the sim slot where a special insert would loosen the glue with power being sent through it
Sebastian Wilmer - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 65
Últimos 7 dias: 442
Últimos 30 dias: 1,907
Duração total: 11,814
