Ir para o conteúdo principal
iPhone 15 Screen Replacement
O que você precisa
  1. iPhone 15 Screen Replacement, Prepare your phone for disassembly: passo 1, imagem 1 %32 iPhone 15 Screen Replacement, Prepare your phone for disassembly: passo 1, imagem 2 %32
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
    Pergunte ao FixBot
    Comentar
  2. iPhone 15 Screen Replacement, Tape over any cracks: passo 2, imagem 1 %32 iPhone 15 Screen Replacement, Tape over any cracks: passo 2, imagem 2 %32
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
    Pergunte ao FixBot
    Comentar
  3. iPhone 15 Screen Replacement, Mark your opening picks: passo 3, imagem 1 %32 iPhone 15 Screen Replacement, Mark your opening picks: passo 3, imagem 2 %32 iPhone 15 Screen Replacement, Mark your opening picks: passo 3, imagem 3 %32
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Pergunte ao FixBot
    Comentar
  4. iPhone 15 Screen Replacement, Remove the pentalobe screws: passo 4, imagem 1 %32 iPhone 15 Screen Replacement, Remove the pentalobe screws: passo 4, imagem 2 %32
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
    Pergunte ao FixBot
    Comentar
  5. iPhone 15 Screen Replacement, Heat the bottom edge: passo 5, imagem 1 %32
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    Pergunte ao FixBot
    Comentar
  6. iPhone 15 Screen Replacement, Insert an opening pick: passo 6, imagem 1 %32 iPhone 15 Screen Replacement, Insert an opening pick: passo 6, imagem 2 %32 iPhone 15 Screen Replacement, Insert an opening pick: passo 6, imagem 3 %32
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
    Pergunte ao FixBot
    Comentar
  7. iPhone 15 Screen Replacement, Screen information: passo 7, imagem 1 %32
    • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
    • There are two delicate cables connecting the screen to the phone, one just above the mute switch, and the other about halfway between the volume down button and the bottom of the phone.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
    Pergunte ao FixBot
    Comentar
  8. iPhone 15 Screen Replacement, Separate the bottom edge adhesive: passo 8, imagem 1 %32 iPhone 15 Screen Replacement, Separate the bottom edge adhesive: passo 8, imagem 2 %32 iPhone 15 Screen Replacement, Separate the bottom edge adhesive: passo 8, imagem 3 %32
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
    Pergunte ao FixBot
    Comentar
  9. iPhone 15 Screen Replacement, Heat the right edge: passo 9, imagem 1 %32
    • Heat the right edge of the screen until it's hot to the touch.
    Pergunte ao FixBot
    Comentar
  10. iPhone 15 Screen Replacement, Position the opening pick: passo 10, imagem 1 %32 iPhone 15 Screen Replacement, Position the opening pick: passo 10, imagem 2 %32 iPhone 15 Screen Replacement, Position the opening pick: passo 10, imagem 3 %32
    • Don't insert your pick deeper than 5 mm along the right edge.
    • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
    • Rotate your pick so the flat edge is under the screen.
    Pergunte ao FixBot
    Comentar
  11. iPhone 15 Screen Replacement, Release the right clip: passo 11, imagem 1 %32 iPhone 15 Screen Replacement, Release the right clip: passo 11, imagem 2 %32 iPhone 15 Screen Replacement, Release the right clip: passo 11, imagem 3 %32
    • Hold the pick with one hand and twist it to increase the gap between the screen and the frame and release the right clip.
    • Insert a second opening pick to the right of the first one.
    Pergunte ao FixBot
    Comentar
  12. iPhone 15 Screen Replacement, Separate the right edge adhesive: passo 12, imagem 1 %32 iPhone 15 Screen Replacement, Separate the right edge adhesive: passo 12, imagem 2 %32 iPhone 15 Screen Replacement, Separate the right edge adhesive: passo 12, imagem 3 %32
    • Slide the first pick back to the bottom right corner of the screen.
    • Slide the second pick to the top right corner of the screen to separate the adhesive.
    • Leave these picks inserted to prevent the adhesive from resealing.
    Pergunte ao FixBot
    Comentar
  13. iPhone 15 Screen Replacement, Heat the top edge: passo 13, imagem 1 %32
    • Heat the top edge of the screen until it's hot to the touch.
    Pergunte ao FixBot
    Comentar
  14. iPhone 15 Screen Replacement, Separate the top right corner adhesive: passo 14, imagem 1 %32 iPhone 15 Screen Replacement, Separate the top right corner adhesive: passo 14, imagem 2 %32 iPhone 15 Screen Replacement, Separate the top right corner adhesive: passo 14, imagem 3 %32
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Insert a third opening pick in the top right corner, just above the previous pick.
    • Slide your pick around the top right corner and along the top edge until you feel it stop against the top left screen clip.
    Pergunte ao FixBot
    Comentar
  15. iPhone 15 Screen Replacement, Release the top edge clips: passo 15, imagem 1 %32 iPhone 15 Screen Replacement, Release the top edge clips: passo 15, imagem 2 %32 iPhone 15 Screen Replacement, Release the top edge clips: passo 15, imagem 3 %32
    • Rotate your pick so its flat edge is under the screen.
    • Twist your pick to release the top left screen clip.
    • Slide your pick to the top left corner.
    Pergunte ao FixBot
    Comentar
  16. iPhone 15 Screen Replacement, Heat the left edge: passo 16, imagem 1 %32
    • Heat the left edge of the screen until it's hot to the touch.
    Pergunte ao FixBot
    Comentar
  17. iPhone 15 Screen Replacement, Separate the left edge adhesive: passo 17, imagem 1 %32 iPhone 15 Screen Replacement, Separate the left edge adhesive: passo 17, imagem 2 %32 iPhone 15 Screen Replacement, Separate the left edge adhesive: passo 17, imagem 3 %32
    • Don't insert your pick deeper than 3 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Slide your pick around the top left corner of the screen and along the left edge to release the clips and separate the adhesive securing it.
    Pergunte ao FixBot
    Comentar
  18. iPhone 15 Screen Replacement, Swing open the screen: passo 18, imagem 1 %32 iPhone 15 Screen Replacement, Swing open the screen: passo 18, imagem 2 %32 iPhone 15 Screen Replacement, Swing open the screen: passo 18, imagem 3 %32
    • Gently swing open the screen over the left edge of the phone.
    • If the screen feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    Pergunte ao FixBot
    Comentar
  19. iPhone 15 Screen Replacement, Unfasten the front sensor connector cover: passo 19, imagem 1 %32
    • Use a tri-point Y000 driver to remove the 0.9 mm-long screw securing the front sensor connector cover.
    Pergunte ao FixBot
    Comentar
  20. iPhone 15 Screen Replacement, Remove the cover: passo 20, imagem 1 %32 iPhone 15 Screen Replacement, Remove the cover: passo 20, imagem 2 %32 iPhone 15 Screen Replacement, Remove the cover: passo 20, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to lift the cover to a 90-degree angle.
    • Unhook the cover from its slot in the logic board.
    • Remove the cover.
    Pergunte ao FixBot
    Comentar
  21. iPhone 15 Screen Replacement, Disconnect the front sensor: passo 21, imagem 1 %32 iPhone 15 Screen Replacement, Disconnect the front sensor: passo 21, imagem 2 %32
    • Use the tip of an opening pick to pry up and disconnect the front sensor press connector.
    Pergunte ao FixBot
    Comentar
  22. iPhone 15 Screen Replacement, Unfasten the screen connector cover: passo 22, imagem 1 %32
    • Use your tri-point Y000 driver to remove the 0.9 mm‑long screw securing the screen connector cover.
    Pergunte ao FixBot
    Comentar
  23. iPhone 15 Screen Replacement, Remove the cover: passo 23, imagem 1 %32 iPhone 15 Screen Replacement, Remove the cover: passo 23, imagem 2 %32
    • Use tweezers to lift the cover and unlatch it from its hook on the logic board.
    • Remove the cover.
    Pergunte ao FixBot
    Comentar
  24. iPhone 15 Screen Replacement, Disconnect the screen: passo 24, imagem 1 %32 iPhone 15 Screen Replacement, Disconnect the screen: passo 24, imagem 2 %32
    • Use the tip of an opening pick to pry up and disconnect the screen press connector.
    Pergunte ao FixBot
    Comentar
  25. iPhone 15 Screen Replacement, Remove the screen: passo 25, imagem 1 %32
    • Remove the screen.
    Pergunte ao FixBot
    Comentar
  26. iPhone 15 Screen Replacement, End of disassembly: passo 26, imagem 1 %32
    • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
    • When reconnecting press connectors, align the connector carefully over its socket and press down with your fingertip or spudger—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
    Pergunte ao FixBot
    Comentar
  27. iPhone 15 Screen Replacement, Remove the screen adhesive: passo 27, imagem 1 %32 iPhone 15 Screen Replacement, Remove the screen adhesive: passo 27, imagem 2 %32 iPhone 15 Screen Replacement, Remove the screen adhesive: passo 27, imagem 3 %32
    • Be careful not to damage any of the spring contacts as you clean the frame.
    • This is a good point to test your repair before sealing up your phone. Connect the screen, power on your phone, and make sure it works as expected. Power it back down and continue reassembly.
    • The adhesive remaining on your phone is difficult to remove and leaves residue. If you have trouble removing the adhesive, apply some heat using a hair dryer or heat gun.
    • Use a spudger to push the screen adhesive up until you can grab it with a pair of tweezers.
    • Use a pair of tweezers, or your fingers, to remove the adhesive around the entire perimeter of the iPhone.
    Pergunte ao FixBot
    Comentar
  28. iPhone 15 Screen Replacement: passo 28, imagem 1 %32 iPhone 15 Screen Replacement: passo 28, imagem 2 %32 iPhone 15 Screen Replacement: passo 28, imagem 3 %32
    • Any leftover residue will compromise your iPhone's seal. Be sure to clean the frame thoroughly.
    • Wrap a microfiber or lint-free cloth around the pointed end of a spudger and apply a few drops of high-concentration (greater than 90%) isopropyl alcohol to the cloth.
    • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
    • Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
    Pergunte ao FixBot
    Comentar
  29. iPhone 15 Screen Replacement, Ambient light sensor information: passo 29, imagem 1 %32
    • The ambient light sensor is located behind the screen, directly beneath the cut‑out for the Face ID sensors.
    • Check if the replacement screen comes with one installed. If it does, skip to this step.
    Pergunte ao FixBot
    Comentar
  30. iPhone 15 Screen Replacement, Remove the ambient light sensor bracket: passo 30, imagem 1 %32 iPhone 15 Screen Replacement, Remove the ambient light sensor bracket: passo 30, imagem 2 %32
    • Use a Phillips screwdriver to remove the 1.3 mm‑long screw securing the ambient light sensor bracket.
    Pergunte ao FixBot
    Comentar
  31. iPhone 15 Screen Replacement: passo 31, imagem 1 %32 iPhone 15 Screen Replacement: passo 31, imagem 2 %32
    • Use a pair of tweezers or your fingers to lift and remove the ambient light sensor bracket.
    Pergunte ao FixBot
    Comentar
  32. iPhone 15 Screen Replacement, Heat the ambient light sensor: passo 32, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  33. iPhone 15 Screen Replacement, Pry up the ambient light sensor: passo 33, imagem 1 %32 iPhone 15 Screen Replacement, Pry up the ambient light sensor: passo 33, imagem 2 %32
    • Use a spudger to pry up the ambient light sensor.
    Pergunte ao FixBot
    Comentar
  34. iPhone 15 Screen Replacement, Peel up the ambient light sensor cable: passo 34, imagem 1 %32 iPhone 15 Screen Replacement, Peel up the ambient light sensor cable: passo 34, imagem 2 %32
    • Gently slide an opening pick under the ambient light sensor cable, starting near the sensor and moving towards to the opposite corner until it's free from the screen.
    • If the adhesive doesn't peel up easily, apply more heat.
    Pergunte ao FixBot
    Comentar
  35. iPhone 15 Screen Replacement, Remove the ambient light sensor: passo 35, imagem 1 %32
    • Use a pair of tweezers to lift the ambient light sensor off of the screen.
    Pergunte ao FixBot
    Comentar
  36. iPhone 15 Screen Replacement, Prepare the ambient light sensor: passo 36, imagem 1 %32 iPhone 15 Screen Replacement, Prepare the ambient light sensor: passo 36, imagem 2 %32
    Tesa 61395 Tape
    $2.95
    • Use tweezers to reposition any adhesive that may have covered the ambient light sensor during removal. The adhesive should form a border around the raised white rectangle.
    • If the adhesive was damaged or stayed with the old screen, replace it with a 1 mm wide strip of thin, double-sided tape along its bottom border.
    Pergunte ao FixBot
    Comentar
  37. iPhone 15 Screen Replacement, Place the ambient light sensor: passo 37, imagem 1 %32 iPhone 15 Screen Replacement, Place the ambient light sensor: passo 37, imagem 2 %32
    • Align the ambient light sensor with its recess in the back of the screen.
    • Use a spudger or your finger to press the ambient light sensor into its recess.
    Pergunte ao FixBot
    Comentar
  38. iPhone 15 Screen Replacement, Warm the ambient light sensor: passo 38, imagem 1 %32
    • Use a hair dryer, heat gun, or heated iOpener to soften the adhesive under the ambient light sensor and ambient light sensor cable. It only needs to be warm—not hot.
    Pergunte ao FixBot
    Comentar
  39. iPhone 15 Screen Replacement, Press the ambient light sensor: passo 39, imagem 1 %32 iPhone 15 Screen Replacement, Press the ambient light sensor: passo 39, imagem 2 %32 iPhone 15 Screen Replacement, Press the ambient light sensor: passo 39, imagem 3 %32
    Tesa 61395 Tape
    $2.95
    • Use your finger to press down the ambient light sensor cable.
    • If the ambient light sensor cable isn't sticking, apply a few small pieces of double‑sided tape, like Tesa tape, to the back of the sensor cable.
    Pergunte ao FixBot
    Comentar
  40. iPhone 15 Screen Replacement, Install the ambient light sensor bracket: passo 40, imagem 1 %32 iPhone 15 Screen Replacement, Install the ambient light sensor bracket: passo 40, imagem 2 %32 iPhone 15 Screen Replacement, Install the ambient light sensor bracket: passo 40, imagem 3 %32
    • Use tweezers or your fingers to hook the ambient light sensor bracket over the back of the sensor and set it into place.
    Pergunte ao FixBot
    Comentar
  41. iPhone 15 Screen Replacement: passo 41, imagem 1 %32 iPhone 15 Screen Replacement: passo 41, imagem 2 %32
    • Use a Phillips screwdriver to install the 1.3 mm‑long screw securing the ambient light sensor bracket.
    Pergunte ao FixBot
    Comentar
  42. iPhone 15 Screen Replacement, Orient the adhesive: passo 42, imagem 1 %32 iPhone 15 Screen Replacement, Orient the adhesive: passo 42, imagem 2 %32 iPhone 15 Screen Replacement, Orient the adhesive: passo 42, imagem 3 %32
    • Lay the adhesive next to the phone and use features like cutouts for spring contacts and the front‑facing camera to make sure the adhesive is oriented correctly.
    • Your adhesive may look slightly different.
    Pergunte ao FixBot
    Comentar
  43. iPhone 15 Screen Replacement, Apply the adhesive: passo 43, imagem 1 %32 iPhone 15 Screen Replacement, Apply the adhesive: passo 43, imagem 2 %32 iPhone 15 Screen Replacement, Apply the adhesive: passo 43, imagem 3 %32
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • Use the pull tab to begin peeling the back liner off of the adhesive starting from the bottom, but do not remove the liner all the way.
    • While holding the back liner out of the way, carefully align the exposed edge of the adhesive to the bottom edge of the iPhone's frame.
    Pergunte ao FixBot
    Comentar
  44. iPhone 15 Screen Replacement: passo 44, imagem 1 %32 iPhone 15 Screen Replacement: passo 44, imagem 2 %32 iPhone 15 Screen Replacement: passo 44, imagem 3 %32
    • When the adhesive is aligned, use the flat end of a spudger, or your finger, to press it down firmly along the bottom edge.
    Pergunte ao FixBot
    Comentar
  45. iPhone 15 Screen Replacement: passo 45, imagem 1 %32 iPhone 15 Screen Replacement: passo 45, imagem 2 %32 iPhone 15 Screen Replacement: passo 45, imagem 3 %32
    • Continue peeling the back liner off of the adhesive while pressing the adhesive into place along the edges of the iPhone's frame.
    • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
    • If your adhesive is misaligned and you don't have another set handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive, but keep in mind that your iPhone's water resistance will be compromised until you install new adhesive.
    Pergunte ao FixBot
    Comentar
  46. iPhone 15 Screen Replacement, Press the adhesive into place: passo 46, imagem 1 %32 iPhone 15 Screen Replacement, Press the adhesive into place: passo 46, imagem 2 %32 iPhone 15 Screen Replacement, Press the adhesive into place: passo 46, imagem 3 %32
    • Make sure the liner is aligned properly by checking that all spring contacts and the front-facing camera are in their cutouts. If they aren't, remove the adhesive and start over with a new sheet.
    • Use the flat end of a spudger to press the adhesive firmly into place all around the iPhone.
    • Be careful not to press on the camera, spring contacts, or other internal components.
    Pergunte ao FixBot
    Comentar
  47. iPhone 15 Screen Replacement, Remove the top liner: passo 47, imagem 1 %32 iPhone 15 Screen Replacement, Remove the top liner: passo 47, imagem 2 %32
    • Insert the point of a spudger under the top liner's hole at the bottom of the frame.
    • Pry up to separate the liner from the frame—enough to grip it with your fingers.
    • Your pull tab may be in a different location. Make sure you're pulling the full-size top liner, not the thin liners under it.
    Pergunte ao FixBot
    Comentar
  48. iPhone 15 Screen Replacement: passo 48, imagem 1 %32 iPhone 15 Screen Replacement: passo 48, imagem 2 %32 iPhone 15 Screen Replacement: passo 48, imagem 3 %32
    • Peel back the top liner and remove it.
    Pergunte ao FixBot
    Comentar
  49. iPhone 15 Screen Replacement, Prop up the screen: passo 49, imagem 1 %32
    • Prop the screen up along the left edge of the iPhone frame, using a box or similar sturdy object to support the screen.
    Pergunte ao FixBot
    Comentar
  50. iPhone 15 Screen Replacement, Connect the screen: passo 50, imagem 1 %32 iPhone 15 Screen Replacement, Connect the screen: passo 50, imagem 2 %32
    • Use the flat end of a spudger or your finger to connect the screen and front sensor press connectors.
    Pergunte ao FixBot
    Comentar
  51. iPhone 15 Screen Replacement: passo 51, imagem 1 %32 iPhone 15 Screen Replacement: passo 51, imagem 2 %32 iPhone 15 Screen Replacement: passo 51, imagem 3 %32
    • Insert the top of the screen connector cover into its slot in the frame and lay it over the press connector.
    Pergunte ao FixBot
    Comentar
  52. iPhone 15 Screen Replacement: passo 52, imagem 1 %32 iPhone 15 Screen Replacement: passo 52, imagem 2 %32 iPhone 15 Screen Replacement: passo 52, imagem 3 %32
    • Insert the front sensor connector cover into its slot in the frame at a 90‑degree angle vertically.
    • Lay the cover over the press connector.
    Pergunte ao FixBot
    Comentar
  53. iPhone 15 Screen Replacement, Install the cover screws: passo 53, imagem 1 %32 iPhone 15 Screen Replacement, Install the cover screws: passo 53, imagem 2 %32
    • Use a tri-point Y000 driver to install the two 0.9 mm‑long screws securing the front sensor connector and screen connector covers.
    Pergunte ao FixBot
    Comentar
  54. iPhone 15 Screen Replacement, Remove the final adhesive liners: passo 54, imagem 1 %32 iPhone 15 Screen Replacement, Remove the final adhesive liners: passo 54, imagem 2 %32
    • As you remove the liners in this step, the adhesive will be fully exposed. Make sure nothing touches the exposed adhesive.
    • Use a spudger, or your fingers, to separate the pull tabs at the bottom right corner of the frame.
    Pergunte ao FixBot
    Comentar
  55. iPhone 15 Screen Replacement: passo 55, imagem 1 %32 iPhone 15 Screen Replacement: passo 55, imagem 2 %32 iPhone 15 Screen Replacement: passo 55, imagem 3 %32
    • Remove the narrow liner covering the adhesive along the right and top edges of the frame.
    Pergunte ao FixBot
    Comentar
  56. iPhone 15 Screen Replacement: passo 56, imagem 1 %32 iPhone 15 Screen Replacement: passo 56, imagem 2 %32 iPhone 15 Screen Replacement: passo 56, imagem 3 %32
    • Remove the liner along the bottom edge of the frame.
    Pergunte ao FixBot
    Comentar
  57. iPhone 15 Screen Replacement: passo 57, imagem 1 %32 iPhone 15 Screen Replacement: passo 57, imagem 2 %32 iPhone 15 Screen Replacement: passo 57, imagem 3 %32
    • Without letting the screen touch the adhesive, hold the screen over the phone so you can access the final liner along the left edge of the phone.
    • Use a pair of tweezers or your fingers to remove the final liner along the left edge of the phone.
    Pergunte ao FixBot
    Comentar
  58. iPhone 15 Screen Replacement, Place the screen: passo 58, imagem 1 %32 iPhone 15 Screen Replacement, Place the screen: passo 58, imagem 2 %32 iPhone 15 Screen Replacement, Place the screen: passo 58, imagem 3 %32
    • Lay the screen straight down onto the frame and press until the clips engage.
    • Press around the perimeter of the screen to engage all clips.
    Pergunte ao FixBot
    Comentar
  59. iPhone 15 Screen Replacement, Heat the screen: passo 59, imagem 1 %32 iPhone 15 Screen Replacement, Heat the screen: passo 59, imagem 2 %32
    • To help the adhesive bond, apply heat to the edges of the screen using an iOpener, hair dryer, or heat gun until it's hot to the touch.
    • If you have screen vise clamps, use them to strengthen the bond of your new adhesive. If not, keep reading for more ways to secure the screen.
    Pergunte ao FixBot
    Comentar
  60. iPhone 15 Screen Replacement, Press the screen: passo 60, imagem 1 %32 iPhone 15 Screen Replacement, Press the screen: passo 60, imagem 2 %32 iPhone 15 Screen Replacement, Press the screen: passo 60, imagem 3 %32
    • To evenly compress your iPhone and strengthen the bond of the screen to the frame, you need to account for the camera bump.
    • If you have the box your iPhone came in, take the lid and place it on a flat surface.
    • If you don't have your original box, skip this step for an alternate method.
    • Place your iPhone screen-side-up in the lid of your box with the camera bump in its recess.
    • Find something close to the size of your iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
    • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
    Pergunte ao FixBot
    Comentar
  61. iPhone 15 Screen Replacement: passo 61, imagem 1 %32 iPhone 15 Screen Replacement: passo 61, imagem 2 %32
    • If you don't have the original box for your iPhone, follow the next three steps for another method to evenly compress the screen.
    • Place the iPhone screen-side-down on a soft, flat surface.
    • Apply tape to the back glass to protect its finish.
    Pergunte ao FixBot
    Comentar
  62. iPhone 15 Screen Replacement: passo 62, imagem 1 %32 iPhone 15 Screen Replacement: passo 62, imagem 2 %32 iPhone 15 Screen Replacement: passo 62, imagem 3 %32
    • Place evenly spaced layers of coins or similarly thick objects on the tape along the edges of the back glass.
    • Stack them to a consistent height taller than the camera bump.
    Pergunte ao FixBot
    Comentar
  63. iPhone 15 Screen Replacement: passo 63, imagem 1 %32
    • Stack multiple books or other heavy objects on your iPhone.
    • The coins may leave an impression on the bottom object, so don't use anything valuable.
    Pergunte ao FixBot
    Comentar
  64. iPhone 15 Screen Replacement, Install the pentalobe screws: passo 64, imagem 1 %32 iPhone 15 Screen Replacement, Install the pentalobe screws: passo 64, imagem 2 %32
    • Use a P2 pentalobe driver to install the two 7.7 mm‑long screws on either side of the charging port.
    Pergunte ao FixBot
    Comentar
Conclusão
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
22 outras pessoas executaram este guia.
Clay Eickemeyer
Membro desde: 09/19/22
104.680 Reputação
Autoria de 472 guias
Equipe
Guide Team Membro de Guide Team
Staff
10 Membros
Autoria de 18.390 guias
11Comentários do guia
Is it safe to remove the screen of Iphone 15 or even 14 without disconnecting the battery? Thank you.
Laurentiu.P - Responder Compartilhar
Hi Laurentiu,
In the case of the iPhone 15 series and the iPhone 14 vanilla models, their design is intentional so that you may replace the screen without disconnecting the battery. To mitigate any ESD-related risks, don't use any metal prying tools, use ESD-safe tools, and discharge and shut down your device before opening it up. Read more about ESD here.
Good luck!
Clay Eickemeyer - Responder Compartilhar
Ok, I got you, thank you very much. So it doesn't matter if we change the screen and battery is still unplugged, even if we use lcd or led screen, if we use the right tools.
This may not be true for all devices, but Apple devices are quite robust. You should have no problem swapping a screen out on an iPhone 15. Just make sure that the press connectors are fully connected, since the insulating foam around the sockets may prevent them from laying flush!
Why is iPhone 15 Screen Replacement not sold in Canada?
SirDropsphonealot - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 162
Últimos 7 dias: 1,485
Últimos 30 dias: 4,907
Ao todo: 95,969
