Ir para o conteúdo principal
iPhone 13 mini Taptic Engine Replacement
O que você precisa
  1. iPhone 13 mini Taptic Engine Replacement, Remove the screws: passo 1, imagem 1 %32 iPhone 13 mini Taptic Engine Replacement, Remove the screws: passo 1, imagem 2 %32
    • For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    Pergunte ao FixBot
    Comentar
  2. iPhone 13 mini Taptic Engine Replacement, Mark your opening picks: passo 2, imagem 1 %32 iPhone 13 mini Taptic Engine Replacement, Mark your opening picks: passo 2, imagem 2 %32 iPhone 13 mini Taptic Engine Replacement, Mark your opening picks: passo 2, imagem 3 %32
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Pergunte ao FixBot
    Comentar
  3. iPhone 13 mini Taptic Engine Replacement, Tape over any cracks: passo 3, imagem 1 %32 iPhone 13 mini Taptic Engine Replacement, Tape over any cracks: passo 3, imagem 2 %32 iPhone 13 mini Taptic Engine Replacement, Tape over any cracks: passo 3, imagem 3 %32
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screenuntil the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
    Pergunte ao FixBot
    Comentar
  4. iPhone 13 mini Taptic Engine Replacement, Anti-Clamp instructions: passo 4, imagem 1 %32 iPhone 13 mini Taptic Engine Replacement, Anti-Clamp instructions: passo 4, imagem 2 %32 iPhone 13 mini Taptic Engine Replacement, Anti-Clamp instructions: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Pergunte ao FixBot
    Comentar
  5. iPhone 13 mini Taptic Engine Replacement: passo 5, imagem 1 %32 iPhone 13 mini Taptic Engine Replacement: passo 5, imagem 2 %32 iPhone 13 mini Taptic Engine Replacement: passo 5, imagem 3 %32
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Pergunte ao FixBot
    Comentar
  6. iPhone 13 mini Taptic Engine Replacement: passo 6, imagem 1 %32 iPhone 13 mini Taptic Engine Replacement: passo 6, imagem 2 %32 iPhone 13 mini Taptic Engine Replacement: passo 6, imagem 3 %32
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Pergunte ao FixBot
    Comentar
  7. iPhone 13 mini Taptic Engine Replacement, Heat the bottom edge: passo 7, imagem 1 %32
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone until the screen is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
    Pergunte ao FixBot
    Comentar
  8. iPhone 13 mini Taptic Engine Replacement, Apply a suction handle: passo 8, imagem 1 %32
    • If you're using a single suction handle, apply it to the bottom edge of the phone, as close to the edge as possible.
    Pergunte ao FixBot
    Comentar
  9. iPhone 13 mini Taptic Engine Replacement, Insert an opening pick: passo 9, imagem 1 %32 iPhone 13 mini Taptic Engine Replacement, Insert an opening pick: passo 9, imagem 2 %32 iPhone 13 mini Taptic Engine Replacement, Insert an opening pick: passo 9, imagem 3 %32
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • Insert an opening pick into the gap under the screen's plastic bezel.
    • Make sure to insert the pick between the plastic bezel and the metal frame. If you insert the pick between the glass screen and the plastic bezel, you'll damage your screen.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    Pergunte ao FixBot
    Comentar
  10. iPhone 13 mini Taptic Engine Replacement, Separate the bottom adhesive: passo 10, imagem 1 %32 iPhone 13 mini Taptic Engine Replacement, Separate the bottom adhesive: passo 10, imagem 2 %32 iPhone 13 mini Taptic Engine Replacement, Separate the bottom adhesive: passo 10, imagem 3 %32
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
    Pergunte ao FixBot
    Comentar
  11. iPhone 13 mini Taptic Engine Replacement, Heat the right edge: passo 11, imagem 1 %32 iPhone 13 mini Taptic Engine Replacement, Heat the right edge: passo 11, imagem 2 %32
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) until the screen is slightly too hot to touch.
    Pergunte ao FixBot
    Comentar
  12. iPhone 13 mini Taptic Engine Replacement, Separate the right adhesive: passo 12, imagem 1 %32 iPhone 13 mini Taptic Engine Replacement, Separate the right adhesive: passo 12, imagem 2 %32 iPhone 13 mini Taptic Engine Replacement, Separate the right adhesive: passo 12, imagem 3 %32
    • Slide the opening pick around the bottom right corner and along the right edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, and don't force it through unheated sections of adhesive, or it may slip and damage internal components.
    • Leave the pick in the top right corner before continuing.
    Pergunte ao FixBot
    Comentar
  13. iPhone 13 mini Taptic Engine Replacement, Heat the top edge: passo 13, imagem 1 %32
    • Use a hair dryer to heat the top edge of the iPhone until the screen is slightly too hot to touch.
    Pergunte ao FixBot
    Comentar
  14. iPhone 13 mini Taptic Engine Replacement, Separate the top adhesive: passo 14, imagem 1 %32 iPhone 13 mini Taptic Engine Replacement, Separate the top adhesive: passo 14, imagem 2 %32 iPhone 13 mini Taptic Engine Replacement, Separate the top adhesive: passo 14, imagem 3 %32
    • Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the top sensors.
    • Leave the pick in the top left corner before continuing.
    Pergunte ao FixBot
    Comentar
  15. iPhone 13 mini Taptic Engine Replacement, Heat the left edge: passo 15, imagem 1 %32 iPhone 13 mini Taptic Engine Replacement, Heat the left edge: passo 15, imagem 2 %32
    • Use a hair dryer to heat the left edge of the iPhone until the screen is slightly too hot to touch.
    Pergunte ao FixBot
    Comentar
  16. iPhone 13 mini Taptic Engine Replacement, Separate the left adhesive: passo 16, imagem 1 %32 iPhone 13 mini Taptic Engine Replacement, Separate the left adhesive: passo 16, imagem 2 %32 iPhone 13 mini Taptic Engine Replacement, Separate the left adhesive: passo 16, imagem 3 %32
    • There are delicate cables along the left edge of your iPhone. Don't insert your pick deeper than 2 mm here, as you may damage the cables.
    • Rotate your pick around the top left corner of the screen.
    • Slide your pick to the bottom left corner of the screen to separate the adhesive.
    • If you're having trouble separating the adhesive, reheat the left edge.
    Pergunte ao FixBot
    Comentar
  17. iPhone 13 mini Taptic Engine Replacement, Remove the suction cup(s): passo 17, imagem 1 %32
    • Pull on the small nub on the suction cup to remove it from the front panel.
    Pergunte ao FixBot
    Comentar
  18. iPhone 13 mini Taptic Engine Replacement, Open the iPhone mini: passo 18, imagem 1 %32 iPhone 13 mini Taptic Engine Replacement, Open the iPhone mini: passo 18, imagem 2 %32
    • Rotate your iPhone so the right edge faces you.
    • Open the iPhone by swinging the display up from the right side, like the front cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
    Pergunte ao FixBot
    Comentar
  19. iPhone 13 mini Taptic Engine Replacement, Unscrew the battery and display connector cover: passo 19, imagem 1 %32
    Magnetic Project Mat
    $19.95
    • Remove the 1.2 mm-long Y000 screw securing the battery and display connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
    Pergunte ao FixBot
    Comentar
  20. iPhone 13 mini Taptic Engine Replacement, Remove the cover: passo 20, imagem 1 %32 iPhone 13 mini Taptic Engine Replacement, Remove the cover: passo 20, imagem 2 %32
    • Use a pair of tweezers to remove the battery and display connector cover.
    Pergunte ao FixBot
    Comentar
  21. iPhone 13 mini Taptic Engine Replacement, Disconnect the battery and the OLED display cable: passo 21, imagem 1 %32 iPhone 13 mini Taptic Engine Replacement, Disconnect the battery and the OLED display cable: passo 21, imagem 2 %32 iPhone 13 mini Taptic Engine Replacement, Disconnect the battery and the OLED display cable: passo 21, imagem 3 %32
    • Use a spudger to pry the battery and OLED panel cable connectors up from their sockets on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Pergunte ao FixBot
    Comentar
  22. iPhone 13 mini Taptic Engine Replacement, Unscrew the front sensor connector cover: passo 22, imagem 1 %32
    • Remove the three screws (securing the front sensor assembly cover):
    • One PH000 1.4 mm-long screw
    • One Y000 1.8 mm-long screw
    • One Y000 1.2 mm-long screw
    Pergunte ao FixBot
    Comentar
  23. iPhone 13 mini Taptic Engine Replacement, Remove the cover: passo 23, imagem 1 %32 iPhone 13 mini Taptic Engine Replacement, Remove the cover: passo 23, imagem 2 %32
    • Use a pair of tweezers to remove the front sensor assembly connector cover.
    Pergunte ao FixBot
    Comentar
  24. iPhone 13 mini Taptic Engine Replacement, Disconnect the front sensors: passo 24, imagem 1 %32 iPhone 13 mini Taptic Engine Replacement, Disconnect the front sensors: passo 24, imagem 2 %32
    • Use a spudger to disconnect the front sensor assembly cable connector.
    Pergunte ao FixBot
    Comentar
  25. iPhone 13 mini Taptic Engine Replacement, Remove the display assembly: passo 25, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  26. iPhone 13 mini Taptic Engine Replacement, Unscrew the Taptic Engine: passo 26, imagem 1 %32
    • Remove the three Phillips screws (securing the Taptic Engine):
    • One 1.5 mm-long screw
    • One 2.1 mm-long screw
    • One 1.9 mm-long screw
    Pergunte ao FixBot
    Comentar
  27. iPhone 13 mini Taptic Engine Replacement, Remove the cover: passo 27, imagem 1 %32 iPhone 13 mini Taptic Engine Replacement, Remove the cover: passo 27, imagem 2 %32
    • Use a pair of tweezers to remove the Taptic Engine connector cover bracket.
    Pergunte ao FixBot
    Comentar
  28. iPhone 13 mini Taptic Engine Replacement, Disconnect the Taptic Engine: passo 28, imagem 1 %32 iPhone 13 mini Taptic Engine Replacement, Disconnect the Taptic Engine: passo 28, imagem 2 %32
    • Use a spudger to disconnect the Taptic Engine flex cable by prying it straight up from its socket.
    Pergunte ao FixBot
    Comentar
  29. iPhone 13 mini Taptic Engine Replacement, Unscrew the standoff screw: passo 29, imagem 1 %32
    • Remove the 3 mm-long standoff screw.
    Pergunte ao FixBot
    Comentar
  30. iPhone 13 mini Taptic Engine Replacement, Remove the Taptic Engine: passo 30, imagem 1 %32 iPhone 13 mini Taptic Engine Replacement, Remove the Taptic Engine: passo 30, imagem 2 %32
    • Use a pair of tweezers to remove the Taptic Engine.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow the above steps in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 13 mini Answers community for help.
6 outras pessoas executaram este guia.
Adriana Zwink
Membro desde: 12/18/19
67.597 Reputação
Autoria de 167 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 27.554 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 14
Últimos 7 dias: 103
Últimos 30 dias: 393
Ao todo: 12,218
