Introdução
The Taptic Engine produces your iPhone's vibration and haptic feedback functions. Follow this guide to remove and/or replace the Taptic Engine in an iPhone 11 Pro Max.
O que você precisa
Power off your iPhone before beginning disassembly.
Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
Ferramenta utilizada nesse passo:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the iPhone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
Skip the next three steps.
Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
Insert an opening pick into the gap.
Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
Pull on the small nub on the suction cup to remove it from the front panel.
Open the iPhone by swinging the display up from the left side, like the back cover of a book.
Lean the display against something to keep it propped up while you're working on the phone.
Ferramenta utilizada nesse passo:Magnetic Project Mat$19.95
Remove two 1.3 mm long Y000 screws securing the battery cover bracket.
Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
Use a Y000 driver to remove six 1.3 mm screws securing the logic board cover bracket.
Use a spudger or a fingernail to disconnect the OLED panel cable connector.
Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
Use a spudger or a fingernail to disconnect the digitizer cable connector.
Use a Y000 driver to remove the four 1.2 mm screws securing the lower battery connector cover.
Use a spudger to disconnect the lower battery flex cable by prying it straight up from its socket.
Use a spudger to disconnect the Taptic Engine flex cable by prying it straight up from its socket.
Ferramenta utilizada nesse passo:Standoff Screwdriver for iPhones$5.49
Remove the three screws securing the Taptic Engine:
One 2.0 mm-long Y000 screw
One 1.6 mm-long Y000 screw
One 4.0 mm-long standoff screw
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 11 Pro Max Answers community for help.
6 outras pessoas executaram este guia.
