Ir para o conteúdo principal
iPhone "L-Shaped" Battery Adhesive Strips Replacement
O que você precisa
  1. iPhone "L-Shaped" Battery Adhesive Strips Replacement, iPhone Battery Adhesive Strips: passo 1, imagem 1 %32 iPhone "L-Shaped" Battery Adhesive Strips Replacement, iPhone Battery Adhesive Strips: passo 1, imagem 2 %32
    • Before you begin, it's a good idea to test-fit your new battery in the iPhone.
    • This works best after reinstalling the speaker and Taptic Engine. Refer to the guide you used to remove your old battery.
    • Make sure the battery connector lines up correctly with its socket on the logic board.
    • Be careful not to touch the Face ID camera and sensor hardware along the top edge of the iPhone (the "notch" area).
  2. iPhone "L-Shaped" Battery Adhesive Strips Replacement: passo 2, imagem 1 %32 iPhone "L-Shaped" Battery Adhesive Strips Replacement: passo 2, imagem 2 %32
    • If your test-fit looks good, take the battery back out and place it face-down on your work surface (with the connector contacts facing up).
    • If your battery came with new adhesive strips already installed, skip to Step 7.
    • If you have a two-cell battery, make sure the cells are aligned as they would be when installed in the iPhone.
  3. iPhone "L-Shaped" Battery Adhesive Strips Replacement: passo 3, imagem 1 %32 iPhone "L-Shaped" Battery Adhesive Strips Replacement: passo 3, imagem 2 %32 iPhone "L-Shaped" Battery Adhesive Strips Replacement: passo 3, imagem 3 %32
    • Peel off the blue plastic liner from your new set of adhesive strips, and discard it.
    • Some strips have a single large blue liner, while others have a two-piece liner. Either way, peel it all off.
    • Once the adhesive is exposed, be careful not to touch it.
  4. iPhone "L-Shaped" Battery Adhesive Strips Replacement: passo 4, imagem 1 %32 iPhone "L-Shaped" Battery Adhesive Strips Replacement: passo 4, imagem 2 %32
    • Once the adhesive sticks to the battery, you can't peel it off or reposition it—if you make a mistake, you'll have to start over with fresh adhesive strips.
    • Double-check the orientation of the adhesive strips, and make sure your battery is still lying face-down (with the connector contacts facing up).
    • Carefully position the adhesive strips over the battery, and stick them in place as shown.
    • Place the strips slightly off-center, very close to the long edge of the battery.
    • The black pull tabs at each end should protrude equally far over the top and bottom edges of the battery.
  5. iPhone "L-Shaped" Battery Adhesive Strips Replacement: passo 5, imagem 1 %32 iPhone "L-Shaped" Battery Adhesive Strips Replacement: passo 5, imagem 2 %32 iPhone "L-Shaped" Battery Adhesive Strips Replacement: passo 5, imagem 3 %32
    • Use your fingers or a cloth to press the strips firmly into place on the battery.
    • Press in the center to adhere the black regulatory label to the battery as well.
  6. iPhone "L-Shaped" Battery Adhesive Strips Replacement: passo 6, imagem 1 %32 iPhone "L-Shaped" Battery Adhesive Strips Replacement: passo 6, imagem 2 %32 iPhone "L-Shaped" Battery Adhesive Strips Replacement: passo 6, imagem 3 %32
    • Roll your fingertip along the edges of the battery to stick down the black pull tab at the end of each adhesive strip.
    • Be sure to get all four tabs—three on the bottom edge, and one on the top.
  7. iPhone "L-Shaped" Battery Adhesive Strips Replacement: passo 7, imagem 1 %32 iPhone "L-Shaped" Battery Adhesive Strips Replacement: passo 7, imagem 2 %32 iPhone "L-Shaped" Battery Adhesive Strips Replacement: passo 7, imagem 3 %32
    • Peel off and discard the pink liner, fully exposing the adhesive strips.
  8. iPhone "L-Shaped" Battery Adhesive Strips Replacement: passo 8, imagem 1 %32 iPhone "L-Shaped" Battery Adhesive Strips Replacement: passo 8, imagem 2 %32 iPhone "L-Shaped" Battery Adhesive Strips Replacement: passo 8, imagem 3 %32
    • When installing the battery, be careful not to touch the Face ID camera and sensor hardware along the top edge of the iPhone (the "notch" area).
    • Carefully position the battery and set it into the iPhone.
    • Make sure the battery connector lines up with its socket on the logic board.
    • It's okay to temporarily connect the battery to make sure it lines up correctly, but make certain it's disconnected before reassembling your iPhone.
  9. iPhone "L-Shaped" Battery Adhesive Strips Replacement: passo 9, imagem 1 %32 iPhone "L-Shaped" Battery Adhesive Strips Replacement: passo 9, imagem 2 %32
    • Press the battery firmly onto the adhesive strips to secure it in place.
    • If your battery came with an additional plastic liner on the top, peel it off and discard it before closing up your phone.
Jeff Suovanen
Membro desde: 08/06/13
439.253 Reputação
Autoria de 259 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.410 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 24
Últimos 7 dias: 85
Últimos 30 dias: 407
Duração total: 28,611
