Ir para o conteúdo principal
iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement
O que você precisa
  1. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, iPad Pro 9.7" Opening Procedure: passo 1, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, iPad Pro 9.7" Opening Procedure: passo 1, imagem 2 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, iPad Pro 9.7" Opening Procedure: passo 1, imagem 3 %32
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  2. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 2, imagem 1 %32
    • The following steps involve using an iOpener to soften the adhesive holding the front panel assembly in place. When using the iOpener, be sure to heat it in the microwave for no more than 30 seconds.
    • Handling it by the tabs on either end, place a heated iOpener over the top edge of the iPad.
    • Let the iOpener sit on the iPad for two minutes to soften the adhesive securing the front panel to the rest of the iPad.
  3. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 3, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 3, imagem 2 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 3, imagem 3 %32
    • While the iPad looks uniform from the outside, there are delicate components under certain portions of the front glass. To avoid damage, only heat and pry in the areas described in each step.
    • As you follow the directions, take special care to avoid prying in the following areas:
    • Home Button
    • Front Facing Camera
    • Main Camera
  4. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Anti-Clamp instructions: passo 4, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Anti-Clamp instructions: passo 4, imagem 2 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Anti-Clamp instructions: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Anti-Clamp
    $24.95
    Comprar
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Elevate the iPad enough for the Anti-Clamp's arms to rest above and below the screen.
    • Pull the blue handle towards the hinge to disengage opening mode.
    • Position the suction cups near the top edge of the iPad—one on the front, and one on the back.
    • Push down on the cups to apply suction to the desired area.
    • If you find that the surface of your device is too slippery for the Anti-Clamp to hold onto, you can use packing tape to create a grippier surface.
  5. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 5, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 5, imagem 2 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 5, imagem 3 %32
    • Push the blue handle away from the hinge to engage opening mode.
    • Turn the handle clockwise until you see the cups start to stretch.
    • Make sure the suction cups remain aligned to each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  6. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 6, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 6, imagem 2 %32
    • Place a suction cup over the iPad's front-facing camera and press down to create a seal.
    • To get the most leverage, place the suction cup as close to the edge as possible without going past the edge of the display.
  7. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 7, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 7, imagem 2 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 7, imagem 3 %32
    • Firmly pull up on the suction cup to create a small gap between the front panel and the rear case.
    • Do not pull too hard or you may shatter the glass.
    • Once you've opened a sufficient gap, insert an opening pick into the gap to prevent the adhesive from resealing.
  8. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 8, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 8, imagem 2 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 8, imagem 3 %32
    • Slide the pick along the edge of the display, towards the headphone jack.
    • If there is still a considerable amount of resistance when sliding the opening pick, repeat the iOpener heating procedure and apply additional heat.
    • Don't insert the pick past the bezel into the display area, or you will damage it.
    • A good rule of thumb is to never insert the opening pick more than a quarter inch into the iPad.
  9. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 9, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 9, imagem 2 %32
    • Insert a second opening pick by the front-facing camera.
  10. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 10, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 10, imagem 2 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 10, imagem 3 %32
    • Slide the second pick along the top edge of the iPad, towards the Sleep/Wake Button.
  11. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 11, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 11, imagem 2 %32
    • Insert a third pick by the front-facing camera.
  12. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 12, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 12, imagem 2 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 12, imagem 3 %32
    • Bring the right opening pick down and around the top right corner of the iPad.
  13. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 13, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 13, imagem 2 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 13, imagem 3 %32
    • Bring the left opening pick around the top left corner of the tablet.
  14. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 14, imagem 1 %32
    • Reheat the iOpener and lay it over the right edge of the display to loosen the adhesive underneath.
  15. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 15, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 15, imagem 2 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 15, imagem 3 %32
    • Slide the right opening pick roughly halfway down the display.
  16. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 16, imagem 1 %32
    • Reheat the iOpener and apply heat to the left side of the iPad.
  17. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 17, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 17, imagem 2 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 17, imagem 3 %32
    • Slide the left-hand opening pick about halfway down the edge of the display.
  18. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 18, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 18, imagem 2 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 18, imagem 3 %32
    • Slide the opposite opening pick down to the bottom right corner of the iPad.
    • If necessary, reheat the adhesive on the right edge to loosen the display assembly.
  19. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 19, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 19, imagem 2 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 19, imagem 3 %32
    • Slide the left-hand opening pick down the edge of the display until you reach the corner.
  20. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 20, imagem 1 %32
    • Use the iOpener to apply heat to the bottom edge of the iPad.
  21. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 21, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 21, imagem 2 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 21, imagem 3 %32
    • Bring the right-hand opening pick around the bottom corner of the iPad.
  22. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 22, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 22, imagem 2 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 22, imagem 3 %32
    • Repeat for the left-hand pick.
    • Reheat and reapply the iOpener as needed.
  23. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 23, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 23, imagem 2 %32
    • Remove the right-hand opening pick at the bottom of the iPad.
  24. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 24, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 24, imagem 2 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 24, imagem 3 %32
    • Slide the left-hand opening pick along the bottom edge of the display, then remove it from the bottom right corner of the iPad.
    • Be very careful to not insert the pick more than a quarter inch into the display to avoid damaging the Home Button and display cables underneath.
  25. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Slice through the remaining adhesive: passo 25, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Slice through the remaining adhesive: passo 25, imagem 2 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Slice through the remaining adhesive: passo 25, imagem 3 %32
    • Use picks to ensure most of the adhesive has been cut through on the top, left, and bottom sides.
    • Twist the top and bottom picks to separate the display assembly from the rear case.
    • Do not attempt to remove the display—it is still attached to the rear case.
  26. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 26, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 26, imagem 2 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 26, imagem 3 %32
    • Swing the display assembly towards the right of the case, using the right edge as a hinge.
    • As you move the display assembly, make sure that the display ribbon cable is not being stressed.
    • Continue swinging the display assembly until it lays flat next to the rear case.
  27. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Disconnect the battery: passo 27, imagem 1 %32
    • Use a Phillips screwdriver to remove the eleven 1.3 mm screws securing the EMI shield.
  28. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 28, imagem 1 %32
    • Apply a heated iOpener to the EMI shield on the logic board for one minute.
  29. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 29, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 29, imagem 2 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 29, imagem 3 %32
    • Lift the logic board EMI shield, starting at the edge nearest the top of the iPad.
    • Slowly peel the EMI shield up from the logic board.
    • This takes a bit of force due to the many tiny clips securing the shield, and the shield may deform slightly. That's okay—try to keep the deformation to a minimum, and it will lay flat when reinstalled and screwed down.
    • Remove the logic board EMI shield.
  30. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 30, imagem 1 %32
    • Use a Phillips driver to remove the 1.7 mm-long screw securing the battery connector.
  31. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 31, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 31, imagem 2 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 31, imagem 3 %32
    • If the EMI shield has any sharp protrusions after removal, you should flatten them before reinstalling the shield.
    • Squeeze the sharp protrusion with a pair of pliers to flatten it.
    • Repeat the process for all sharp protrusions along the edges of the EMI shield.
  32. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Battery connector information: passo 32, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Battery connector information: passo 32, imagem 2 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Battery connector information: passo 32, imagem 3 %32
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
  33. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Disconnect the battery: passo 33, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Disconnect the battery: passo 33, imagem 2 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Disconnect the battery: passo 33, imagem 3 %32
    • Be careful when you isolate the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage.
    • Ensure that the iFixit logo on the battery blocker is facing up.
    • Slide the battery blocker underneath the left side of the logic board's battery connector at a 35 degree angle.
    • The battery blocker's right prong should slide between the left side of the logic board's battery connector and the battery's contact pads. The left prong should slide under the logic board.
    • Don't push the battery blocker underneath the connector or logic board with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, refer to the next step for information on loosening the logic board. You can also try using a playing card to disconnect the battery instead.
    • The battery blocker or playing card should slide under the logic board without encountering any blockages. After insertion, they should rest at a 15 degree angle.
    • Leave the battery blocker in place as you work.
  34. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Logic board adhesive information: passo 34, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Logic board adhesive information: passo 34, imagem 2 %32
    • If the battery blocker doesn't easily slide under the logic board, follow these steps to partially loosen the logic board from the frame:
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol under the logic board to the left and right of the battery connection.
    • Wait one minute for the isopropyl alcohol to weaken the adhesive under the logic board.
    • Try to insert the battery blocker. If the logic board doesn't easily lift up, apply a few more drops of isopropyl alcohol.
    • This doesn't apply when using the playing card method to disconnect the battery because the playing card is only inserted between the battery connector and the battery contact pads.
  35. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Remove the display bracket screws: passo 35, imagem 1 %32
    • Use a Phillips screwdriver to remove the three 1.3 mm Phillips screws securing the display cable bracket.
  36. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Remove the bracket: passo 36, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Remove the bracket: passo 36, imagem 2 %32
    • Remove the display cable bracket.
  37. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Disconnect the display assembly: passo 37, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Disconnect the display assembly: passo 37, imagem 2 %32
    • Use the flat end of the spudger to disconnect the display assembly connector from the motherboard socket.
  38. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 38, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 38, imagem 2 %32
    • Repeat the previous step for the two remaining connectors.
  39. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Remove the display assembly: passo 39, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Remove the display assembly: passo 39, imagem 2 %32
  40. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Disconnect the right antenna: passo 40, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Disconnect the right antenna: passo 40, imagem 2 %32
    • Use the flat end of a spudger to disconnect the right antenna's coaxial connector from its socket.
    • To reinstall, hold the connector in place and gently press straight down. The connector will “snap” into its socket.
  41. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Disconnect the left antenna: passo 41, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Disconnect the left antenna: passo 41, imagem 2 %32
    • Use the flat end of a spudger to disconnect the left antenna's coaxial connector from its socket.
  42. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Lift the antenna cables: passo 42, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Lift the antenna cables: passo 42, imagem 2 %32
    • Use the flat end of a spudger to lift the bundled left and right antenna cables away from the frame.
    • Be careful not to puncture the battery with the spudger.
    • The sticker bundling the antenna cables together is lightly adhered to the frame.
  43. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Remove the adhesive: passo 43, imagem 1 %32
    • Use a pair of tweezers to remove the adhesive that was securing the bundled antenna cables to the frame.
    • Take care not to damage the antenna cables with the sharp tips on the tweezers.
    • During reassembly, apply pre-cut adhesive to the bundled antenna cables to secure them to the frame.
  44. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Separate the antenna cables: passo 44, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Separate the antenna cables: passo 44, imagem 2 %32
    • Use a pair of tweezers to peel up the sticker bundling the left and right antenna cables together.
  45. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 45, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 45, imagem 2 %32
    • Peel the right antenna cable off of the sticker.
  46. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Lift up the first sticker: passo 46, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Lift up the first sticker: passo 46, imagem 2 %32
    • Use a pair of tweezers to lift up the small sticker next to the lower right speaker securing the left antenna cable to the frame.
  47. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Detach the second sticker: passo 47, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Detach the second sticker: passo 47, imagem 2 %32
    • Use a pair of tweezers to detach the large left antenna cable sticker near the lower right speaker.
  48. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Lift up the third sticker: passo 48, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Lift up the third sticker: passo 48, imagem 2 %32
    • Use a pair of tweezers to lift the left antenna and its third sticker away from the Lightning port area of the frame.
  49. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Detach the foam spacer: passo 49, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Detach the foam spacer: passo 49, imagem 2 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Detach the foam spacer: passo 49, imagem 3 %32
    • Use the pointed end of a spudger to detach the foam spacer adhered to the fourth left antenna cable sticker.
  50. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Remove the foam spacer: passo 50, imagem 1 %32
    • Remove the foam spacer from the fourth left antenna cable sticker.
  51. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 51, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 51, imagem 2 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement: passo 51, imagem 3 %32
    • Use a pair of tweezers to lift up the fourth left antenna cable sticker.
  52. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Remove the three screws: passo 52, imagem 1 %32
    • Remove the three Phillips screws securing the left antenna cable and bracket:
    • One 1.2 mm screw
    • Two 1.2 mm screws
  53. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Detach the left antenna bracket: passo 53, imagem 1 %32 iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Detach the left antenna bracket: passo 53, imagem 2 %32
    • Use an opening pick to detach the left antenna bracket from the frame.
    • The left antenna bracket is adhered to the frame with a thin foam adhesive piece.
    • If the thin foam adhesive piece isn't sufficiently tacky during reassembly, apply a few strips of pre-cut adhesive under the bracket to secure it to the frame.
  54. iPad Pro 9.7" Left Wi-Fi/Bluetooth Antenna Replacement, Remove the left antenna: passo 54, imagem 1 %32
    • Remove the left antenna from the frame.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Pro 9.7" Answers community for help.
Kyle Smith
Membro desde: 02/01/21
41.020 Reputação
Autoria de 123 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 41
Duração total: 813
