Ir para o conteúdo principal
iPad 6 Wi-Fi Logic Board Replacement
O que você precisa
  1. iPad 6 Wi-Fi Logic Board Replacement, Heat the left edge: passo 1, imagem 1 %32
    • Heat an iOpener and apply it to the left edge of the device for two minutes.
  2. iPad 6 Wi-Fi Logic Board Replacement, Screen removal information: passo 2, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement, Screen removal information: passo 2, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement, Screen removal information: passo 2, imagem 3 %32
    • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
    • Front camera
    • Antennas
    • Display cables
  3. iPad 6 Wi-Fi Logic Board Replacement, Anti-Clamp instructions: passo 3, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement, Anti-Clamp instructions: passo 3, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement, Anti-Clamp instructions: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  4. iPad 6 Wi-Fi Logic Board Replacement: passo 4, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 4, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 4, imagem 3 %32
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPad 6 Wi-Fi Logic Board Replacement: passo 5, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 5, imagem 2 %32
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  6. iPad 6 Wi-Fi Logic Board Replacement, Insert an opening pick: passo 6, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement, Insert an opening pick: passo 6, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement, Insert an opening pick: passo 6, imagem 3 %32
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
    • Insert an opening pick into the gap between the digitizer and the frame.
    I had a screen that was lightly cracked, and when I pulled up on the glass it cracked even further and made a mess of my removal. So, I would recommend taping cracks even if you can get suction so that you don’t induce even more cracks.
    Andrew Dixon - Responder
    I actually had a really badly cracked digitizer. Using the suction cup did nothing but shatter the digitizer more. I intentionally drove a flat head screw driver into the digitizer to reveal the recess in the body where they are showing the opening-pick. Working around the edge, the glass shattered. You still need to be careful at all of spots noted in step 2.
    Do not go under the digitizer more than the 1 mm along the sides or 3-4 mm at the corners as shown in step 29 using the flat grey ring around the edge for a reference. Direct all of your tool force into the body to prevent slipping into critical parts.
    The antennas at either side of the home button were the trickiest part as they were thin and slightly attached to the digitizer. I would recommend using a plastic tool for these parts if you are having to 'scrape' the glass off of the tabs of the antenna.
    adoller - Responder
  7. iPad 6 Wi-Fi Logic Board Replacement, Separate the left adhesive: passo 7, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement, Separate the left adhesive: passo 7, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement, Separate the left adhesive: passo 7, imagem 3 %32
    • Insert a second opening pick into the gap you just created.
    • Slide the pick toward the bottom-left corner of the device to separate the adhesive.
    • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
    • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
  8. iPad 6 Wi-Fi Logic Board Replacement: passo 8, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 8, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 8, imagem 3 %32
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
  9. iPad 6 Wi-Fi Logic Board Replacement: passo 9, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 9, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 9, imagem 3 %32
    • Slide the first opening pick towards the top-left corner of the device to separate the adhesive.
    • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
  10. iPad 6 Wi-Fi Logic Board Replacement, Heat the top edge: passo 10, imagem 1 %32
    • Heat an iOpener and apply it to the top edge of the device for two minutes.
    How do you heat the iopener?
    Steve Passmore - Responder
  11. iPad 6 Wi-Fi Logic Board Replacement, Separate the top left adhesive: passo 11, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement, Separate the top left adhesive: passo 11, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement, Separate the top left adhesive: passo 11, imagem 3 %32
    • Rotate the pick around the top-left corner of the device to separate the adhesive.
  12. iPad 6 Wi-Fi Logic Board Replacement, Separate the top adhesive: passo 12, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement, Separate the top adhesive: passo 12, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement, Separate the top adhesive: passo 12, imagem 3 %32
    • Slide the opening pick along the top edge of the device, stopping just before you reach the front camera.
    • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
  13. iPad 6 Wi-Fi Logic Board Replacement: passo 13, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 13, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 13, imagem 3 %32
    • Pull the pick out until only the tip is between the digitizer and the frame.
    • Slide the pick above the front camera to separate the adhesive.
    • Leave the pick near the right side of the front camera before continuing.
  14. iPad 6 Wi-Fi Logic Board Replacement: passo 14, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 14, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 14, imagem 3 %32
    • Re-insert the pick and slide it towards the top-right corner of the device to completely separate the top adhesive.
    • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
  15. iPad 6 Wi-Fi Logic Board Replacement, Heat the right edge: passo 15, imagem 1 %32
    • Heat an iOpener and apply it to the right edge of the device for two minutes.
  16. iPad 6 Wi-Fi Logic Board Replacement, Separate the top right adhesive: passo 16, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement, Separate the top right adhesive: passo 16, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement, Separate the top right adhesive: passo 16, imagem 3 %32
    • Rotate the pick around the top-right corner of the device to separate the adhesive.
  17. iPad 6 Wi-Fi Logic Board Replacement, Separate the right adhesive: passo 17, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement, Separate the right adhesive: passo 17, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement, Separate the right adhesive: passo 17, imagem 3 %32
    • Insert a new opening pick and slide it to the middle of the iPad's right edge.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding once you reach three inches from the bottom of the iPad.
    There are sensitive display/digitizer cables no less than five inches from the bottom edge of the iPad. Insert the pick further down than this, or deeper than 1mm beyond this point and you risk irreparably damaging these cables.
    Three inches is much too far down this side of the iPad to use picks.
    rcrandall85 - Responder
  18. iPad 6 Wi-Fi Logic Board Replacement, Heat the bottom edge: passo 18, imagem 1 %32
    • Heat an iOpener and apply it to the bottom edge of the device for two minutes.
  19. iPad 6 Wi-Fi Logic Board Replacement, Separate the bottom left adhesive: passo 19, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement, Separate the bottom left adhesive: passo 19, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement, Separate the bottom left adhesive: passo 19, imagem 3 %32
    • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
    • Don't fully rotate the pick around the corner, as you may damage the antenna.
    • Leave the pick in the bottom-left corner before moving to the next step.
  20. iPad 6 Wi-Fi Logic Board Replacement, Separate the bottom adhesive: passo 20, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement, Separate the bottom adhesive: passo 20, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement, Separate the bottom adhesive: passo 20, imagem 3 %32
    • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
    • Slide the pick over the antenna, stopping just before the home button.
    • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
    • Leave the pick to the left of the home button before continuing.
  21. iPad 6 Wi-Fi Logic Board Replacement: passo 21, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 21, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 21, imagem 3 %32
    • Insert an opening pick into the gap you just created.
    • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
    • Only insert the pick up to 1 mm to avoid damaging the right antenna.
  22. iPad 6 Wi-Fi Logic Board Replacement: passo 22, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 22, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 22, imagem 3 %32
    • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
    • Leave the pick to the right of the home button before continuing.
  23. iPad 6 Wi-Fi Logic Board Replacement, Heat the right edge: passo 23, imagem 1 %32
  24. iPad 6 Wi-Fi Logic Board Replacement: passo 24, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 24, imagem 2 %32
    • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with a pick. Don't be afraid to stop and reheat.
    • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
    • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
  25. iPad 6 Wi-Fi Logic Board Replacement: passo 25, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 25, imagem 2 %32
    • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
  26. iPad 6 Wi-Fi Logic Board Replacement, Separate the right adhesive: passo 26, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement, Separate the right adhesive: passo 26, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement, Separate the right adhesive: passo 26, imagem 3 %32
    • While supporting the digitizer, slide an opening pick between the two display cables to separate the last of the adhesive.
  27. iPad 6 Wi-Fi Logic Board Replacement: passo 27, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 27, imagem 2 %32
    • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
    • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
    • Be mindful of the display cables when reassembling the device. Make sure they are folded properly underneath the LCD screen to prevent any damage.
    While reassembling, REALLY make sure the display cables and the home button cable won't be folded / bent while closing the digitizer. I'm not exactly sure what I did, but I broke the home button and touch ID since I bent the home button cable to the point that it broke. These ribbon cables are SUPER fragile.
    op_ - Responder
  28. iPad 6 Wi-Fi Logic Board Replacement, LCD: passo 28, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement, LCD: passo 28, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement, LCD: passo 28, imagem 3 %32
    • Remove any tape obscuring the LCD screws.
  29. iPad 6 Wi-Fi Logic Board Replacement: passo 29, imagem 1 %32
    • Remove the four Phillips #00 4.3 mm screws securing the LCD.
    Both of the iPad 6th gen models i have seen so for (note they were cellular also) had the LCD secured with a grey silicone kind of adhesive in each corner under the screws. So you can’t just lift the LCD as you normally would after removing screws, it would break. I found you could pick at the corner closest to the rear camera easiest, slightly lift that corner and gently separate the other side next to the headphone jack. Then while supporting the LCD , lever the other end free with a up-and-down motion making slight progress each time.
    Anvil Electronics - Responder
    I found the same thing on my 32GB wifi only ipad. Was unable to lift the screen off once I’d removed the screws so followed the instructions above and gently prized the screen up from the top left-hand screw bracket and it came away. Then moved onto the top right hand one.
    mann134 - Responder
    One YouTube video said to dig all that glue out. I didn’t and it seems to not hurt to leave it there but you do have to break free from it.
    Robin - Responder
    On my iPad 6, there were small rubber tabs covering the two screws on the front camera side. I carefully held them out of place with tweezers while unscrewing the screws.
    Martin Winter - Responder
  30. iPad 6 Wi-Fi Logic Board Replacement: passo 30, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 30, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 30, imagem 3 %32
    • Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
    • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers. There may be glue around the screw holes that needs to be cut with a knife.
    • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
    • Be gentle and keep an eye on the LCD cables as you flip the display over.
    • Lay the LCD on its face to allow access to the display cables.
    • Set the LCD down on a soft, clean, lint-free surface.
    When you replace the LCD be sure to make sure it is screwed in fully. It is easy not, especially on the cornet where the digitizer cables are. The LCD is very sensitive and if you bend it then it can stop working. I was just pressing the digitized in place at the end of a repair and the screen was covered in white lines.
    hugh - Responder
    I have no idea of what the logic board looks like !!!
    HenryFMora - Responder
  31. iPad 6 Wi-Fi Logic Board Replacement, Battery connector information: passo 31, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement, Battery connector information: passo 31, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement, Battery connector information: passo 31, imagem 3 %32
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
  32. iPad 6 Wi-Fi Logic Board Replacement: passo 32, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 32, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 32, imagem 3 %32
    • Remove the single 2.3 mm Phillips #000 screw securing the battery connector to the logic board.
    • To reduce the risk of a short, you can use a battery isolation pick to disconnect the battery.
    • Slide the battery blocker underneath the logic board's battery connector at a 35 degree angle.
    • Don't push the battery blocker underneath the connector with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery instead.
    • The battery blocker or playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at a 15 degree angle.
    • Leave the battery blocker in place as you work.
    If you insert a regular pick without a gap then you can damage this connector and will need a new motherboard. If in doubt just insert into the left corner enough to raise it a tiny bit. Arguably, if you are not sure, then it is safer just power off and don’t power back on until everything is fully connected. A photo of how this connector looks with its cover off would really help for people that have not seen this type of battery connector before. You just need to get it to lift a tiny bit, Do not try to slide anything under the contacts….
    hugh - Responder
    I bumped this darn thing several times, it was twisted and skewed making me freak out but the iPad still works. I am thinking you should pull it out and put the screw back in right after the LCD is removed. Then use it again just before putting the LCD screen back in. The pick is sticking out there waitng to be be bumped.
    Robin - Responder
    Hi Robin,
    Unfortunately, there is no easy way to pull the battery connector out of the logic board. If you try to pry this connector off, you will irreparably damage it. The easiest solution is to insert the battery blocker in-between to cut the power.
    Arthur Shi -
    The battery isolation pick or battery blocker is an outdated way of isolating the battery, as you risk damaging the battery pins underneath the logic board.
    So what is the new method?
    Wil Thieme - Responder
    This is my question as well. Seems like this phrase contradicts the instructions. Confusing. Any reply?
    Melissa Hoffman -
    We are currently working on a better isolation procedure! In the meantime, I’ve updated the warning to hopefully clarify the issue.
    Arthur Shi -
    Why do you need to “To reduce the risk of a short”? There does not seem to by any risk of a “short” in this process. I can see other reasons for disconnecting the battery. I am an electrical engineer so I would appreciate a professional grade answer to this question.
    Rumboogy - Responder
    I’ll give it a shot!
    When you remove the screw, it doesn’t disconnect the battery, as the connector uses spring contacts to touch the battery pads.
    If you leave the battery connected, it leaves the logic board energized. As there are many exposed traces and SMT components on the logic board, there is a chance that you accidentally bridge a trace with a metal tool, resulting damage. In addition, the display connector contains tiny pins, and the pinout is such that if you pry the connector from an energized logic board, there is a chance that a voltage rail pin may accidentally touch something it shouldn’t, blowing out the backlight circuitry.
    Arthur Shi -
    My battery was dead when i did the repair. Did not really need to perform this step
    Igor Kapitanker - Responder
    Take a waterproof playing card, cut out the shape of the battery blocker and slide that under. Battery blocked and pins not at risk of damage. Got that from a YouTube video made by a microsolder repair tech fixing the damage caused by jamming a blocker in between the contacts.
    Melody Fraysier - Responder
    Thanks for the tip Melody! I’ve updated the instructions to include the playing card method.
    Arthur Shi -
    I could not for the life of me get the playing card in there, but my iPad was turned off, so I decided to ‘risk’ a short, instead of potentially damaging the battery connectors by jamming the card in there as hard as possible. My repair went fine, no short, however I realized AFTER closing everything up that I forgot to put the battery screw back in. Really hoping this doesn’t become an issue long term, because I don’t want to pry this brand new screen off just to put the battery in.
    Janie Hughes - Responder
    Let us know! I wasn't able to use the screw again after removing the battery blocker. Now my iPad turns off and on every so many minutes and when it restarts it's 1% and then shows actual charge.
    Martin Hinojosa -
    When you come to screw this back together, do not overestimate how little force it takes to strip the thread on this #000 screw. I did, and I now I can't screw this back down and have the problem where the iPad restarts every 3 mins 20 sec after you turn it on due to a poor connection here. I've used card to pack this out so the LCD puts a little clamping force on the terminal once you screw it back in, but it's not really enough so the iPad still suddenly restarts occasionally.
    Rory Condon - Responder
    I use a small screwdriver and pry underneath that brown bracket from the top edge by the camera (with the elongated metal cover removed of course) all the way before the battery, then lift up just enough for me to unhinged the battery out of the secure post. I don't know why Apple has to go through ALL THIS just to connect the battery since there is a small screw AND ADHESIVE securing it anyway. Nonetheless the whole job (replacing the lcd screen and battery was a major pain in the neck!
    80s Guy - Responder
  33. iPad 6 Wi-Fi Logic Board Replacement: passo 33, imagem 1 %32
    • Remove the three 1.4 mm Phillips #000 screws from the display cable bracket.
    I believe these are also Phillips #00, not Phillips #000.
    Kevin Chatterton II - Responder
    I lost a 1.4mm screw where can I buy these small screws and how big are they? 1.4mm x? flared or flat head
    ferdinando.gregis@gmail.com - Responder
    Is this part important? It seems like I lost it.
    Will - Responder
    You don't have to remove any of this when replacing the battery but doing so will make the job easier and can prevent from accidentally knocking the adjacent cables.
    80s Guy - Responder
  34. iPad 6 Wi-Fi Logic Board Replacement: passo 34, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 34, imagem 2 %32
    • Use the flat end of a spudger to gently pry the display cable bracket straight up from the logic board.
    • The display cable connector is adhered to the underside of the bracket, so don’t push the spudger too far under the bracket, or you may damage the connector.
  35. iPad 6 Wi-Fi Logic Board Replacement: passo 35, imagem 1 %32
    • Remove the LCD.
  36. iPad 6 Wi-Fi Logic Board Replacement, Front Panel Assembly: passo 36, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement, Front Panel Assembly: passo 36, imagem 2 %32
    • Remove any tape covering the home button ribbon cable connector.
  37. iPad 6 Wi-Fi Logic Board Replacement: passo 37, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 37, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 37, imagem 3 %32
    • Use the flat end of a spudger to flip the tab on the home button ribbon cable ZIF connector upward.
    • Carefully pull the home button ribbon cable straight out of the ZIF connector.
    I'm confused about the home flex cable connector required for the 6th generation iPad. It was my understanding that this model required an 18 pin connector. But these excellent pictures clearly show a 14 pin connector, just like the one for the first generation iPad Air AKA the iPad 5. I know this is not the primary focus of this guide, but can anyone clarify this for me?
    Bonnie Baxter - Responder
    I did the whole repair but this part is the problem HELP !!! I unlocked it but it took me 1 hour to carefully pull out the HOME BUTTON RIBBON CABLE. It finally came out with tweezers but now I CAN'T GET IT BACK IN and as a result my touch I.D. won't activate. It seems there was a tiny bit of black tape overlapping the connector on the ribbon which I carefully cut off exposing only the connector on the ribbon itself but how the heck does it slide in before you lock it. It seems easy on Youtube videos but mine just doesn't slide in with hand or with tweezers. OR in fact is there another connector that controls the TOUCH I.D. ???
    Just a guy - Responder
    Failed this step- broke the connector. If I try this again, I'd be inclined try to remove the home button from the front panel without unplugging it. Everything else seems to work fine.
    Sandy Kilday - Responder
    I too failed this step. Needed some up close pics of how this works. Now what do I do the connector on the board is broken?
    Ronald Hays - Responder
  38. iPad 6 Wi-Fi Logic Board Replacement: passo 38, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 38, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 38, imagem 3 %32
    • Use a the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
    • During reassembly, make sure that these connectors are completely seated in their sockets, or you may encounter display issues.
    Where can I get a good used motherboard for a A1954 iPad 6 gen everywhere I look, there sold out ?...
    Trent Weaver - Responder
  39. iPad 6 Wi-Fi Logic Board Replacement: passo 39, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 39, imagem 2 %32
    • Carefully peel the home button ribbon cable up off of the adhesive holding it to the rear case.
    If you can make sure to not pull on the home button side, i would leave out this step. i replaced two displays so far, on the first i removed it, but left it connected on the second attempt. worked like a charm
    Tommy Wienert - Responder
  40. iPad 6 Wi-Fi Logic Board Replacement: passo 40, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 40, imagem 2 %32
    Polyimide Tape
    $9.99
    • Remove the front panel assembly.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit panels come with the proper insulation, and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
  41. iPad 6 Wi-Fi Logic Board Replacement, Right Antenna: passo 41, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement, Right Antenna: passo 41, imagem 2 %32
    • Insert a spudger under the antenna cable closest to the edge of the iPad and lift upward to disconnect the antenna cable connector.
    Skip to the step 98 or even 100 if you just need to replace the power button - I think you should even consider this to replace volume buttons. I am fixing mine right now and screwed up the speaker cable. I did follow the instruction but totally missed the cable right below the tape. I proceeded further, but I just realized I didn't have to go through all the troubles. I wish ifixit.com can manage this type of direction clearly so that dis-assembly is minimum.
    msgfromside3 - Responder
    After you replace the Digitizer if you are getting random key presses it is likely to be because Kapton tape has not been applied to the edges of the digitizer. You need to cover the silver strip around the edge of the digitizer with kapton tape before reassembling. Works every time.
    Richard - Responder
    This is my first ipad and when the battery dies, it will be my last, way overrated and no options like memory cards or mini usb ports, and the battery thing is ridiculous,I wish I would have never bought this knowing this stuff , and way over priced.
    Gary - Responder
    It always helps to Google something before buying it. "iPad Air reviews" in Google would have saved you. I just find it funny how in this day and age, people STILL make "purchase mistakes" because they didn't take the time to research the several-hundred-dollar device they are about to commit to purchasing. You should have seen the amounts of research I did before buying my $1,399 Asus G751JY laptop. I'm absolutely pleased with it and am happy I don't deal with issues other people have. Just be weary, buddy. ALWAYS GOOGLE.
    Scott S -
    If you just want to replace the battery, skip to step 99. You can easily get to most sides of the battery without removing all other components. It worked for me. Good luck!
    Thomas Van den Dries - Responder
    I wish I read this comment. Would have saved me a lot of time.
    leo -
    I followed your piece of advice and went to step 99. My new battery works just fine without removing all those components including the logic board - thanks a lot!!
    Charlotte M -
    An important note - as per the comments lower down, you can skip ahead to step 95 (unsticking the battery) just fine if you're just changing the battery, but after you've unstuck the battery you will need to go back to step 88 and soften the logic board adhesive so you can pry it up about a cm and lift the battery terminal up and over the post to remove it. I didn't realise the post was there, and broke off a piece of the original battery terminal that got stuck under the logic board. This prevented a good connection with the new battery, and caused random restarts after I put everything back together until I realised and went back to recover it.
    Rory Condon -
    Don’t skip to 99 because you need to remove the logic board.
    Cesar Hernandez - Responder
    I have successfully replaced the Battery without removing any components other than the Screen Assembly and LCD. You can skip steps 44 thru 99 by using a spudger as a wedge to lift & hold the Logic Board high enough to lift the battery contact over the post that holds it in place… this will save you a lot of time and frustration and makes the repair sooo much easier.
    firestormmedia -
    My goal was to replace the battery. As some suggested I skipped some steps. I did Step 46 and left out 47 to 100. But I think Step 46 can be skipped too. iFixit probably does not recommend skipping these steps because it is riskier to bend the batteries and damage them. But if you work carefully enough and make sure the adhesive has been softened well, you should be fine. It was no problem for me. It saved me quite some time. (I will write a comment in Step 102 to help you get the batteries out without Steps 46-100.)
    marcelflueeler - Responder
  42. iPad 6 Wi-Fi Logic Board Replacement: passo 42, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 42, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 42, imagem 3 %32
    • There are two large pieces of tape wrapped around the right antenna cable, securing it to the rear case.
    • Peel the tape up from the rear case.
    • While peeling the antenna tape up, leave it in place on the antenna cable to aid with reassembly.
    You may partially skip steps 46 to 100, as it is not really mandatory to remove all those parts in order to remove the logic board and the battery.
    Pierre-Aurélien - Responder
  43. iPad 6 Wi-Fi Logic Board Replacement: passo 43, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 43, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 43, imagem 3 %32
    • The antenna cable is anchored to the speaker with a small metal bracket. The bracket is permanently crimped to the antenna and adhered to the speaker enclosure.
    • Carefully insert an opening pick between the speaker enclosure and the antenna cable bracket.
    • Slide the pick toward the home button to cut the adhesive.
    • Push the bracket away from the speaker until it clears the tape underneath.
    The pick was not thin enough but the razor worked.
    Moon & Snow - Responder
    In my view there is a few destructive steps here. I have been able to remove this entire assembly by lifting only the adhesive tape anchoring it to the back without touching this fine metal bracket as touched in in Step 46 & 63 or tearing the foam in Steps 48 & 65 on both the left & right sides. Remove the screws as in Step 47 & 57 and the one’s either side of the charging port in 64 & 71. Once removed, the only thing securing these to the rear is adhesive tape. Lift the tape and walk the units out by nudging them from side to side.
    Neil Cross - Responder
    Thanks. Made the whole next chunk much simpler :)
    Sarah Ybarra -
  44. iPad 6 Wi-Fi Logic Board Replacement: passo 44, imagem 1 %32
    • Remove the following Phillips #000 screws securing the right antenna:
    • One 2.3 mm screw
    • Two 1.4 mm screws
    I would strongly advise not to follow this step and following ones: removing the 2 Wi-Fi antennas is not required for complete disassembly of the motherboard and battery, and you may potentially destroy your antennas: I scrupulously and foolishly followed this tutorial step by step and now I have severe Wi-Fi problems on my iPad because one of the 2 antennas has been damaged during the process (and by reading all the comments on this page you'll see that I'm not the only one to have this issue...).
    => As someone else already mentioned it in the comments, just skip most of these steps and go directly to something like step 79.
  45. iPad 6 Wi-Fi Logic Board Replacement: passo 45, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 45, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 45, imagem 3 %32
    • Insert the flat end of a spudger between the antenna and the speaker assembly.
    • Slide the spudger toward the home button to cut the foam adhesive securing the antenna.
    Este paso es innecesario, ya que con solo quitar los tornillos es suficiente, no hace falta despegar la goma espuma que mantiene la antena de la bocina.
    Anthony Aguilar - Responder
    tout a fais il n'est pas nécessaire de décoller l'antenne du haut-parleur ! Il faut juste enlever les vis et continuer le démontage du haut-parleur en laissent l'antenne fixer a lui !!!
    dordetivan - Responder
    Faire de même pour le deuxième haut-parleur !
  46. iPad 6 Wi-Fi Logic Board Replacement: passo 46, imagem 1 %32
    • Remove the right antenna from the iPad.
  47. iPad 6 Wi-Fi Logic Board Replacement, Right Speaker: passo 47, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement, Right Speaker: passo 47, imagem 2 %32
    • Insert a spudger under the left antenna cable and lift upward to disconnect the antenna cable connector.
  48. iPad 6 Wi-Fi Logic Board Replacement: passo 48, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 48, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 48, imagem 3 %32
    • There are five pieces of tape wrapped around the left antenna cable covering the right speaker cable connector.
    • Fold the antenna cable out of the way.
    What can I do if I accidentally peel
    off the speaker ribbon from both
    speaker connecters? Can I get a replacement part?
    mike - Responder
    This step was not very well explained. It fails to mention the speaker cable attached on to the tape. This caused the speaker cable to be torn since it is so thoroughly attached to the tape. Guide made no mention that it was under there or that you should be careful about it. Not even the usual remove the tape gently they just tell you to rip it right off no problem. Not sure how this was missed when the guide was so thorough about this beforehand.
    Holden Bott - Responder
    Approx. 3/4 of an inch past the bend in the cabling underneath the tape lies the right speaker cable. Beyond this point proceed with extreme caution. Delicate cables and ZIF connectors underneath the tape will be torn or damaged if they aren't separated from the underside of the insulation tape first. Use fingernails or thin-edged tools.
    An update to this would be nice. Will the Ipad work with a broken spaker cable? Is it possible to get replacement part? Maybe this step should be rewritten.
    Nathaniel Johnson - Responder
  49. iPad 6 Wi-Fi Logic Board Replacement: passo 49, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 49, imagem 2 %32
    • A bend in the speaker cable makes it difficult to peel the tape up from the end.
    • Instead, grip the tape just under the speaker and peel it down, away from the edge of the case.
    • Be careful with your tweezers—only grab and peel the tape, and not the cable beneath.
  50. iPad 6 Wi-Fi Logic Board Replacement: passo 50, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 50, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 50, imagem 3 %32
    • Peel the tape toward the home button to uncover the speaker cable connector.
  51. iPad 6 Wi-Fi Logic Board Replacement: passo 51, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 51, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 51, imagem 3 %32
    • Use the pointed end of a spudger to flip up the retaining flap on the right speaker cable connector.
    • Slide the speaker cable straight out of its ZIF connector.
  52. iPad 6 Wi-Fi Logic Board Replacement: passo 52, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 52, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 52, imagem 3 %32
    • Remove the tape holding the speaker to the rear case.
  53. iPad 6 Wi-Fi Logic Board Replacement: passo 53, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 53, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 53, imagem 3 %32
    • Carefully peel the LCD buffer tape up off of the rear case.
  54. iPad 6 Wi-Fi Logic Board Replacement: passo 54, imagem 1 %32
    • Remove the 2.2 mm Phillips #000 screw securing the speaker to the rear case.
  55. iPad 6 Wi-Fi Logic Board Replacement: passo 55, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 55, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 55, imagem 3 %32
    • Insert a fingernail or the flat end of a spudger in the groove in the speaker housing, near the corner of the rear case.
    • Pull the speaker down, away from the corner of the case.
    It is really not necessary to remove either speakers for a logic board swap.
    sergeymkl - Responder
  56. iPad 6 Wi-Fi Logic Board Replacement: passo 56, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 56, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 56, imagem 3 %32
    • Use a spudger to help pull the speaker out from under the edge of the rear case.
    • Remove the right speaker from the iPad.
    When did you remove the blocker after installing the battery blocker? No photos with blockers after this procedure.
    Prof.Sakamoto - Responder
  57. iPad 6 Wi-Fi Logic Board Replacement, Upper Component Cable Bracket: passo 57, imagem 1 %32
    • Remove the three 1.4 mm Phillips #000 screws securing the upper component cable bracket.
  58. iPad 6 Wi-Fi Logic Board Replacement: passo 58, imagem 1 %32
    • Remove the upper component cable bracket.
    • If you have the Wi-Fi/Cellular model, your iPad will look slightly different and will require the removal of two additional screws to access components covered by this bracket.
  59. iPad 6 Wi-Fi Logic Board Replacement, Logic Board: passo 59, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement, Logic Board: passo 59, imagem 2 %32
    • There are two remaining pieces of tape securing the left antenna cable to the rear case.
  60. iPad 6 Wi-Fi Logic Board Replacement: passo 60, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 60, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 60, imagem 3 %32
    • Push the bracket away from the speaker until it is clear of the tape underneath.
  61. iPad 6 Wi-Fi Logic Board Replacement: passo 61, imagem 1 %32
    • Remove the following Phillips #000 screws:
    • Two 1.4 mm screws
    • One 2.3 mm screw
    I didn’t need to take the left antenna and speaker out. If you just get the wire and tape out of the way so you can unplug the speaker flex cables and take out the lightning connector, then you should still be able to get the logic board out. the left speaker isn’t in the way at all.
    Reed Deemer - Responder
  62. iPad 6 Wi-Fi Logic Board Replacement: passo 62, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 62, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 62, imagem 3 %32
  63. iPad 6 Wi-Fi Logic Board Replacement: passo 63, imagem 1 %32
    • Remove the left antenna from the iPad.
  64. iPad 6 Wi-Fi Logic Board Replacement: passo 64, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 64, imagem 2 %32
    • Remove the tape covering the left speaker cable connector.
    Pulled out the connector doing this step. Best to hold down cable while pulling tape.
    doug - Responder
  65. iPad 6 Wi-Fi Logic Board Replacement: passo 65, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 65, imagem 2 %32
    • Use the pointed end of a spudger to flip up the retaining flap on the left speaker cable connector.
  66. iPad 6 Wi-Fi Logic Board Replacement: passo 66, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 66, imagem 2 %32
  67. iPad 6 Wi-Fi Logic Board Replacement: passo 67, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 67, imagem 2 %32
  68. iPad 6 Wi-Fi Logic Board Replacement: passo 68, imagem 1 %32
  69. iPad 6 Wi-Fi Logic Board Replacement: passo 69, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 69, imagem 2 %32
    • Gently fold the left speaker ribbon cable up so that it will clear the battery when you slide the speaker enclosure out.
  70. iPad 6 Wi-Fi Logic Board Replacement: passo 70, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 70, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 70, imagem 3 %32
  71. iPad 6 Wi-Fi Logic Board Replacement: passo 71, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 71, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 71, imagem 3 %32
    • Remove the left speaker from the iPad.
  72. iPad 6 Wi-Fi Logic Board Replacement: passo 72, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 72, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 72, imagem 3 %32
    • Use the flat end of a spudger to disconnect the front-facing camera connector from the logic board.
    • Pry up only on the connector—not on the socket itself.
    • Fold the front-facing camera cable out of the way.
    • There is a bit of conductive adhesive between the gold-colored cable contacts. Be sure to apply pressure to readhere these contacts during reassembly.
  73. iPad 6 Wi-Fi Logic Board Replacement: passo 73, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 73, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 73, imagem 3 %32
    • Use the flat end of a spudger to disconnect the rear-facing camera connector from the logic board.
    • Fold the rear-facing camera cable out of the way.
  74. iPad 6 Wi-Fi Logic Board Replacement: passo 74, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 74, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 74, imagem 3 %32
    • Use the flat end of a spudger to disconnect the headphone jack connector from the logic board.
    • Newer iPad units have a loop of tape connecting this connector to its socket on the the logic board. This tape must be cut in order to disconnect the headphone jack.
    • Fold the headphone jack cable out of the way.
    Note for others. On this connector, i have some tape keeping it down, it's rather difficult to remove without ripping it. So i ripped the tape to remove it.
    justin Booras - Responder
    "Ripping" the tape seems ill-advised. A sharp ceramic craft paper cutting knife or the very tip of a fine-tip Exacto blade work well. Once the tape is cut on one side, the blade slides through it like it's nothing. Zero force required.
    Be careful not to insert a blade too far or it may come into contact with conductive components.
  75. iPad 6 Wi-Fi Logic Board Replacement: passo 75, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 75, imagem 2 %32
    • Use the flat end of a spudger to disconnect the microphone cable connector from the logic board.
  76. iPad 6 Wi-Fi Logic Board Replacement: passo 76, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 76, imagem 2 %32
    • Remove any tape covering the upper button assembly cable connector.
  77. iPad 6 Wi-Fi Logic Board Replacement: passo 77, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 77, imagem 2 %32
    • Use the pointed end of a spudger to flip up the retaining flap on the upper button assembly cable connector.
  78. iPad 6 Wi-Fi Logic Board Replacement: passo 78, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 78, imagem 2 %32
    • Slide the upper button assembly cable straight out of its ZIF connector.
  79. iPad 6 Wi-Fi Logic Board Replacement: passo 79, imagem 1 %32
    • Remove the two 3.3 mm Phillips #000 screws securing the Lightning port.
    • To find these screws, hold the iPad vertically and look down at the Lightning port.
    NOTE for others who might miss this: this picture is looking down, out the bottom of the iPad. There are four other screws near the lightning port, two for the speakers and two for the port. You see these four easily, looking down at the battery and motherboard. These two are additional to those, and perpendicular to them. Both pairs of lightning port screws, one set perpendicular to the other, must be removed.
    Where did the battery blocker go? It was introduced in step 35. Nowhere has it been said it can be removed . . . yet it is now absent in this picture. I took it out when I got to steps 93-96.
    Randy Burgess - Responder
    Yes this is a deceptive image as the battery and connector strap seem to be missing. Hold your iPad vertically and look down at the lightning port and you’ll see these hidden screws.
    Rusty - Responder
    Thanks for your comment! I’ll add a note in the step.
    Arthur Shi -
  80. iPad 6 Wi-Fi Logic Board Replacement: passo 80, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 80, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 80, imagem 3 %32
    • In the next steps, you will use an iOpener to apply heat to the rear case of the iPad to soften adhesive holding the logic board in place.
    • As you reheat and place the iOpener in each of the indicated locations, leave it in place for at least a minute to soften the adhesive through the rear case.
    • The adhesive is in the form of six pieces of black foam tape—refer to this step as you work at heating and prying to keep track of where each piece is located.
    Thread a piece of dental floss under the tip of the logic board. Be careful when rounding the corner not to snag any ribbon cables. This easily released the foam tape up to the battery connector.
    ROBERT MORELLA - Responder
    Les 2 images suivantes sont contradictoires. elles donnent l'impression de devoir enlever la carte mère.
    Humair - Responder
    @totoy Effectivement, cela peut-être perturbant, mais ces images servent de référence et expliquent où se trouvent les six morceaux d'adhésif qu'il va falloir décoller au cours des étapes suivantes pour retirer la carte mère.
    Claire Miesch -
  81. iPad 6 Wi-Fi Logic Board Replacement: passo 81, imagem 1 %32
    • Place a heated iOpener over the rear-facing camera end of the iPad, and let it sit for at least a minute to soften the adhesive through the rear case.
    • More time won't hurt, but you may need to reheat your iOpener and reapply it if you leave it on the rear case for too long.
  82. iPad 6 Wi-Fi Logic Board Replacement: passo 82, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 82, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 82, imagem 3 %32
    • As you complete the next few steps, prying adhesive securing the logic board in place, always start by testing gently to see if the adhesive is softened. If not, reheat the iOpener and reapply it to the back of the rear case.
    • Carefully insert an opening pick under the logic board, between the front-facing camera and the battery.
    • Slide the pick toward the front-facing camera connector, and stop at the bend in the logic board.
  83. iPad 6 Wi-Fi Logic Board Replacement: passo 83, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 83, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 83, imagem 3 %32
    • Slide an opening pick under the logic board from the front-facing camera to the rear facing camera.
  84. iPad 6 Wi-Fi Logic Board Replacement: passo 84, imagem 1 %32
    • Place a heated iOpener along the bottom edge of the iPad.
    • Again, let the iOpener sit for at least a minute to soften the adhesive through the rear case.
  85. iPad 6 Wi-Fi Logic Board Replacement: passo 85, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 85, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 85, imagem 3 %32
    • The Lightning connector cable is stuck to the case with some adhesive. To detach the adhesive you will be sliding an opening pick between the cable and the case. Be very careful not to cut the Lightning connector cable itself.
    • Insert an opening pick under the Lightning cable where it meets the logic board.
    • Slide the pick down and around the bend in the cable.
  86. iPad 6 Wi-Fi Logic Board Replacement: passo 86, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 86, imagem 2 %32
    • Continue to slide the opening pick under the cable, stopping before the cable bends to the Lightning connector.
    • Move slowly and carefully. If the opening pick does not slide easily, apply more heat and try again. If you use excessive force, you will likely slip and sever the Lightning connector cable.
  87. iPad 6 Wi-Fi Logic Board Replacement: passo 87, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 87, imagem 2 %32
    • Finally, slide the opening pick between the battery and the Lightning connector itself to separate the last of the adhesive underneath the cable.
    There are two screws holding the lightning connector to the rear case, I didn’t see them in this guide. I recommend removing them before you attempt to remove the lightning connector, otherwise you’ll look like an idiot struggling with it for around 1/2 an hour like I just did.
    Will Young - Responder
    I had this problem too!!
    Jocelyn Hall -
    Will Young is correct. The two extra screws are horizontal - they are in addition to the vertical screws mentioned in step 82.
    @usablethought AFAIK there are only two screws securing the actual port to the chassis. You can tell by looking at the part—there are only two screw holes. Those additional screws can be left in place, as shown in the photos. At least, that was my experience. If you’re working on a different model, then of course you may need to improvise—the instructions are only for the model indicated.
    Jeff Suovanen -
  88. iPad 6 Wi-Fi Logic Board Replacement: passo 88, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 88, imagem 2 %32
    • Pull the Lightning connector straight out of its recess in the rear case.
    there were two screws holding the lightening connector in place on my iPad
    Nate Czupinski - Responder
    Yep! In this guide those screws are removed in Step 82, but you can remove them at any point prior to taking out the Lightning connector.
    Jeff Suovanen -
    CAUTION - there are two ‘hidden’ screws holding the lightning port that face the battery. Hold the iPad vertically and look down to see them. I almost broke the cable trying to remove it thinking it was just stubborn adhesive. Yes its mentioned at Step 82 but its a confusing illustration and easily overlooked.
    Rusty - Responder
  89. iPad 6 Wi-Fi Logic Board Replacement: passo 89, imagem 1 %32
    • Place a heated iOpener on the left side of the rear case, where the logic board is adhered.
    • Let the iOpener sit for at least a minute to soften the adhesive through the rear case.
  90. iPad 6 Wi-Fi Logic Board Replacement: passo 90, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 90, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 90, imagem 3 %32
    • Insert a plastic opening tool in the rectangular gap in the upper area of the logic board, and pry the logic board up from the rear case.
    • While keeping the opening tool underneath the logic board, slide it down the length of the gap to free the upper end of the logic board from the adhesive.
  91. iPad 6 Wi-Fi Logic Board Replacement: passo 91, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 91, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 91, imagem 3 %32
    • Pry up the logic board at the lower edge of the rectangular gap, near the EMI shield.
    • Lift the end of the logic board slowly. If you encounter significant resistance, stop prying and reapply the iOpener.
  92. iPad 6 Wi-Fi Logic Board Replacement: passo 92, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 92, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 92, imagem 3 %32
    • Slide an opening pick under the logic board between it and the battery.
    • Slide the pick from the base to the center of the logic board to cut the adhesive.
    • Take care not to cut the battery with the opening pick; a punctured battery can be very dangerous. If you encounter resistance, reheat and reapply the iOpener.
  93. iPad 6 Wi-Fi Logic Board Replacement: passo 93, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 93, imagem 2 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 93, imagem 3 %32
    • Slide the pick up the length of the logic board.
    • Once the adhesive has been cut, pry the battery side of the logic board upward off of the rear case.
    Don't touch the small components which are under the motherboard !!! If you do it your iPad is definitively dead.
    Easy Repair - Responder
  94. iPad 6 Wi-Fi Logic Board Replacement: passo 94, imagem 1 %32 iPad 6 Wi-Fi Logic Board Replacement: passo 94, imagem 2 %32
    • Continue to lift the logic board along the edge nearest the battery, until you can get an opening pick against the far edge of the logic board.
    • Cut any adhesive holding the outer edge of the logic board to the rear case.
  95. iPad 6 Wi-Fi Logic Board Replacement: passo 95, imagem 1 %32
    • Remove the logic board from the iPad.
    Nice guide, thank you, very helpful. There would be no way to guess where the glue stripes are located and a couple of connectors are very difficult to spot. I don't see any need to remove the antennas and the speakers though, they are not really an obstacle to remove the board and can be left in place. The lightning connector is secured in place by two other two horizontal screws which are not shown in the guide.
    Thanks again !
    arbaman - Responder
    Technically, you are correct. But those screws are holding a bracket-like piece for the lightning connecter to screw into- which if you think about it, it wouldn't be considered apart of the lightning port (or at least that's what i think). Not trying to start an argument, as this comment is old, but yeah.
    Kaz -
    This is a bear of a job, and I wouldn’t have had any hope of completing it without this guide. THANK YOU for all your hard work!!!!
Conclusão
11 outras pessoas executaram este guia.
Arthur Shi
Membro desde: 01/03/18
283.132 Reputação
Autoria de 587 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.541 guias
2 comentários
where can I buy a logic board?
beautysmistress - Responder
I needed to replace the charger port for an iPad 6. This guide, plus a youtube vid on how to replace the charger port helped me achieve this last night.
Thanks for the detailed instructions!!!
Comentar
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 49
Últimos 30 dias: 266
Ao todo: 19,151
