Ir para o conteúdo principal
iFixit Digital Multimeter Fuse Replacement
O que você precisa
  1. iFixit Digital Multimeter Fuse Replacement, Turn off your multimeter: passo 1, imagem 1 %32 iFixit Digital Multimeter Fuse Replacement, Turn off your multimeter: passo 1, imagem 2 %32
    • Turn off your multimeter.
    • Disconnect the probes from your multimeter.
    Pergunte ao FixBot
    Comentar
  2. iFixit Digital Multimeter Fuse Replacement, Loosen the cover edges: passo 2, imagem 1 %32 iFixit Digital Multimeter Fuse Replacement, Loosen the cover edges: passo 2, imagem 2 %32 iFixit Digital Multimeter Fuse Replacement, Loosen the cover edges: passo 2, imagem 3 %32
    • Use your fingers to pull and loosen the cover lip out of its groove along the right edge of the multimeter.
    • Pry and loosen the cover from the bottom right corner of the multimeter.
    Pergunte ao FixBot
    Comentar
  3. iFixit Digital Multimeter Fuse Replacement: passo 3, imagem 1 %32 iFixit Digital Multimeter Fuse Replacement: passo 3, imagem 2 %32 iFixit Digital Multimeter Fuse Replacement: passo 3, imagem 3 %32
    • Repeat the procedure to loosen the cover from the left edge of the multimeter.
    Pergunte ao FixBot
    Comentar
  4. iFixit Digital Multimeter Fuse Replacement: passo 4, imagem 1 %32 iFixit Digital Multimeter Fuse Replacement: passo 4, imagem 2 %32
    • Pull the bottom of the cover away from the multimeter to loosen it.
    Pergunte ao FixBot
    Comentar
  5. iFixit Digital Multimeter Fuse Replacement, Remove the cover: passo 5, imagem 1 %32 iFixit Digital Multimeter Fuse Replacement, Remove the cover: passo 5, imagem 2 %32 iFixit Digital Multimeter Fuse Replacement, Remove the cover: passo 5, imagem 3 %32
    • Grasp the sides of the cover near the top to hold it in place.
    • Grasp the bottom edge of the multimeter and pull it out at a shallow angle to remove it from the cover.
    • During reassembly, follow this guide to properly clip the cover back in place.
    Pergunte ao FixBot
    Comentar
  6. iFixit Digital Multimeter Fuse Replacement, Unfasten the case screws: passo 6, imagem 1 %32
    • Use a Phillips screwdriver to remove the four 9.6 mm‑long case screws.
    Pergunte ao FixBot
    Comentar
  7. iFixit Digital Multimeter Fuse Replacement, Separate the case: passo 7, imagem 1 %32 iFixit Digital Multimeter Fuse Replacement, Separate the case: passo 7, imagem 2 %32
    • Grasp the front and back halves of the multimeter and pull to separate the two halves.
    Pergunte ao FixBot
    Comentar
  8. iFixit Digital Multimeter Fuse Replacement, Remove the fuse: passo 8, imagem 1 %32 iFixit Digital Multimeter Fuse Replacement, Remove the fuse: passo 8, imagem 2 %32 iFixit Digital Multimeter Fuse Replacement, Remove the fuse: passo 8, imagem 3 %32
    • Use a spudger or your fingers to pry the fuse out of its holder.
    • Remove the fuse.
    Pergunte ao FixBot
    Comentar
Conclusão
For more information on how to use your iFixit multimeter, check out this page.
Arthur Shi
Membro desde: 01/03/18
338.301 Reputação
Autoria de 851 guias
Equipe
iFixit Membro de iFixit
Staff
122 Membros
Autoria de 26.617 guias
1Comentário do guia
Are these old images? I notice the board looks different from the one shown in the video on iFixit channel. Seems like an older revision. Are all multimeters the new revision now, or is it random which one you could get?
StereoBucket - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 33
Últimos 30 dias: 137
Ao todo: 569
