Ir para o conteúdo principal
Yamaha APX-6N Guitar Strings Replacement
Benjamin
Benjamin e 3 outros colaboradores
Última atualização em December 15, 2023
30 minutos - 1 hora
Fácil
Fotos de ação
Precisa de mais images
Introdução
Ir para o passo 1
This guide will teach you how to remove old or damaged strings from a Yamaha APX-6N guitar. It will also teach you how to put the new strings on properly and tie knots at the bridge and head so the strings stay in place.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. Yamaha APX-6N Guitar Strings Replacement, Guitar strings: passo 1, imagem 1 %32
    • Loosen the guitar strings by turning the tuning pegs counter clockwise.
  2. Yamaha APX-6N Guitar Strings Replacement: passo 2, imagem 1 %32
    • To avoid injury, assure strings are loosened before cutting.
    • Once the strings are loose, cut them using the wire cutters.
    • After strings have been cut, remove them by pulling them out of the tuners and the bottom of the bridge.
  3. Yamaha APX-6N Guitar Strings Replacement: passo 3, imagem 1 %32 Yamaha APX-6N Guitar Strings Replacement: passo 3, imagem 2 %32
    • Insert the end of the string through the middle of the bridge until four inches comes through.
    • Wrap the short end of the string around the long end, making a loop.
    • Put the short end of the string through the loop around three to four times.
    • Pull both ends of the string until the knot is tight.
  4. Yamaha APX-6N Guitar Strings Replacement: passo 4, imagem 1 %32 Yamaha APX-6N Guitar Strings Replacement: passo 4, imagem 2 %32
    • Insert the end of the string into the hole on the correct tuning peg.
    • Pull the end over the tuning peg and loop under the string. Then push the end of the string under the loop.
    • Put the end of the string through the loop and pull both ends until the knot is tight.
  5. Yamaha APX-6N Guitar Strings Replacement: passo 5, imagem 1 %32 Yamaha APX-6N Guitar Strings Replacement: passo 5, imagem 2 %32
    • Repeat Step 4 for all other strings. Strings should be placed in the tuning pegs in clockwise order. Refer to string packaging for more details.
  6. Yamaha APX-6N Guitar Strings Replacement: passo 6, imagem 1 %32
    • Turn the tuning pegs clockwise to tighten each string until the string makes a sound when plucked.
    • Do not overtighten the strings! Strings may snap and lead to injury.
  7. Yamaha APX-6N Guitar Strings Replacement: passo 7, imagem 1 %32
    • After all strings have been replaced, tune the guitar to your desired tuning.
    • Check the headstock and the bridge for any loose string ends.
    • If necessary, use the wire cutters to snip off excess string.
    • The ends of the strings are very sharp.
Conclusão
You now have new strings for your guitar!
Benjamin
Membro desde: 05/10/21
145 Reputação
Autoria de 1 guia
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 335
