Ir para o conteúdo principal
Woven Darning with a Speedy Weave
O que você precisa
  1. Woven Darning with a Speedy Weave, Intro to woven darning: passo 1, imagem 1 %32 Woven Darning with a Speedy Weave, Intro to woven darning: passo 1, imagem 2 %32 Woven Darning with a Speedy Weave, Intro to woven darning: passo 1, imagem 3 %32
    • Structure - Woven darning is a repair technique that involves interweaving perpendicular threads or yarns to create a small woven patch.
    • Repair Use - Woven darning is used on small holes where yarn is missing or the area is worn thin and the resulting gap needs to be filled or reinforced. Despite being a woven technique, its used on both woven and knit garments.
    • This tutorial outlines a specific technique where rows of stitches are laid on top of the fabric utilizing a device that expedites the weaving process. If you don't have a Speedy Weave, refer instead to the Woven Darn a Hole in a Knit tutorial.
  2. Woven Darning with a Speedy Weave, Intro to the Speedy Weave: passo 2, imagem 1 %32 Woven Darning with a Speedy Weave, Intro to the Speedy Weave: passo 2, imagem 2 %32 Woven Darning with a Speedy Weave, Intro to the Speedy Weave: passo 2, imagem 3 %32
    • The vertical threads in a woven patch or piece of fabric are called the warp and the horizontal threads are called the weft.
    • Weaving Rig: The metal weaving rig holds the warp yarns in place and helps speed up the weaving process by lifting and lowering alternating warp threads.
    • Warp Hooks: Each metal hook in the weaving rig moves side to side to lift and lower the warp threads while weaving.
    • Base Disk: The wooden base disk provides a smooth surface to work on, and prevents accidentally weaving through multiple layers at once.
  3. Woven Darning with a Speedy Weave, Assess the damage: passo 3, imagem 1 %32 Woven Darning with a Speedy Weave, Assess the damage: passo 3, imagem 2 %32 Woven Darning with a Speedy Weave, Assess the damage: passo 3, imagem 3 %32
    • Locate the damage.
    • This repair type is meant for small to medium holes approximately 1 inch by 1 inch (~25 mm by ~25 mm) or less in size.
    • For the most invisible repair, choose a yarn or thread of similar weight, color, and materiality.
    • In this tutorial thick embroidery thread is used because the repair is to a mesh backpack pocket. On a knit garment such as a sweater, yarn would be a better choice.
    • Draw a square around the hole about 1/4 inch (~6 mm) bigger than the damage on all sides.
  4. Woven Darning with a Speedy Weave, Set the darning base disk: passo 4, imagem 1 %32 Woven Darning with a Speedy Weave, Set the darning base disk: passo 4, imagem 2 %32 Woven Darning with a Speedy Weave, Set the darning base disk: passo 4, imagem 3 %32
    • Place the circular base disk directly beneath the hole so only one layer of fabric lays over it.
    • Center the disk, with the rounded side up, under the marked damage area.
    • Without overstretching, place the rubber band around the disk, over the fabric, securing them together. The drawn square shouldn't be twisted.
  5. Woven Darning with a Speedy Weave, Set the weaving rig: passo 5, imagem 1 %32 Woven Darning with a Speedy Weave, Set the weaving rig: passo 5, imagem 2 %32 Woven Darning with a Speedy Weave, Set the weaving rig: passo 5, imagem 3 %32
    • Place the metal weaving rig in the crease at the top of the disk. Secure another rubber band around all pieces to hold the weaving rig to the disk.
    • Push the warp hooks up until the tips of the hooks are at a 90 degree angle from the fabric surface, standing exactly upright.
    • A warp hook should align on the left and right sides with the marked square. Adjust the hooks until they align properly.
  6. Woven Darning with a Speedy Weave, Create the warp: passo 6, imagem 1 %32 Woven Darning with a Speedy Weave, Create the warp: passo 6, imagem 2 %32 Woven Darning with a Speedy Weave, Create the warp: passo 6, imagem 3 %32
    • Thread an embroidery needle with a length of embroidery thread no longer than 32 inches (~81 cm). Don't knot the thread.
    • The eye size of the embroidery needle should be large enough to accommodate the yarn, but not much larger.
    • Make a horizontal stitch about 1/4 inch (~6 mm) long with the needle emerging at the bottom right corner of the drawn square. Pull the thread through until there's a short tail, about 1 inch (~25 mm) long.
    • Wrap the thread around the far right warp hook.
    • Pull the thread taught. Maintain even tension, but don't pull tight enough that the fabric pulls or the hole begins to close.
    • The darning will look the best if these lines align with the knit rows of the garment.
  7. Woven Darning with a Speedy Weave, Continue the warp: passo 7, imagem 1 %32 Woven Darning with a Speedy Weave, Continue the warp: passo 7, imagem 2 %32 Woven Darning with a Speedy Weave, Continue the warp: passo 7, imagem 3 %32
    • Make a small horizontal stitch at the bottom of the square, to the left of the initial stitch.
    • The ideal gap between each vertical thread is the same as the width of the thread.
    • Wrap the thread around the second warp hook.
    • Continue this process until the warps cover the entire width of square or the thread begins to run out (stop when there's approximately 2 inches (~5 cm) left and see the next step).
  8. Woven Darning with a Speedy Weave, Start a new thread length: passo 8, imagem 1 %32 Woven Darning with a Speedy Weave, Start a new thread length: passo 8, imagem 2 %32
    • If your remaining yarn nears 2 inches (~5 cm) in length, finish the section by taking a stitch beside the last bottom stitch and piercing the needle to surface 1/4 inch (~6 mm) below the square. Then start a new length of thread and continue the process.
    • For more advanced weaves with multiple colors, use this technique to end the thread after each block of color.
  9. Woven Darning with a Speedy Weave, Finish the warp: passo 9, imagem 1 %32 Woven Darning with a Speedy Weave, Finish the warp: passo 9, imagem 2 %32
    • After looping the thread over the leftmost warp hook, place the tip of the needle through the bottom left corner of the drawn square.
    • Resurface the needle 1/4 inch (~6 mm) away. Pull the thread taught and trim the thread tail to approximately 2 inches (~5 cm).
  10. Woven Darning with a Speedy Weave, Create the weft: passo 10, imagem 1 %32 Woven Darning with a Speedy Weave, Create the weft: passo 10, imagem 2 %32 Woven Darning with a Speedy Weave, Create the weft: passo 10, imagem 3 %32
    • Starting 1/4 inch (~6 mm) from the bottom right corner, take a horizontal stitch and emerge directly above the first warp stitch.
    • Flip all warp hooks to the right. This will raise every other thread to make a channel for the needle to pass through.
    • Slide the needle through the channel to weave the thread through the warp threads. This will be easiest done close to the warp hooks.
    • Finish each weft thread to the left side of the weaving by taking a small vertical stitch. Similarly to securing warp stitches, make this stitch so that the gap between each row is the same width as the thread.
  11. Woven Darning with a Speedy Weave, Continue the weft: passo 11, imagem 1 %32 Woven Darning with a Speedy Weave, Continue the weft: passo 11, imagem 2 %32 Woven Darning with a Speedy Weave, Continue the weft: passo 11, imagem 3 %32
    • Use the needle to carefully push the row of thread down to the bottom of the weaving.
    • Flip the warp hooks to the left side of the weaving rig. The opposite warp threads from the previous row should now be lifted. Pass the needle through the channel.
    • Continuing weaving the horizontal wefts from left to right, flipping the warp hooks each time, creating a securing stitch at the end of each pass, and pulling taught.
    • Tamp down each row of thread after making it. Attempt to mimic the tightness or looseness of the original fabric structure.
  12. Woven Darning with a Speedy Weave, Finish the weft: passo 12, imagem 1 %32 Woven Darning with a Speedy Weave, Finish the weft: passo 12, imagem 2 %32 Woven Darning with a Speedy Weave, Finish the weft: passo 12, imagem 3 %32
    • Once the top of the drawn square is reached, pierce the needle in the top corner and emerge 1/4 inch (~6 mm) away.
    • The top of the weaving should be within 1/8 inch (~3 mm) of the warp hooks.
    • Keep the needle threaded and don't cut off the thread.
  13. Woven Darning with a Speedy Weave, Remove the weaving rig: passo 13, imagem 1 %32 Woven Darning with a Speedy Weave, Remove the weaving rig: passo 13, imagem 2 %32 Woven Darning with a Speedy Weave, Remove the weaving rig: passo 13, imagem 3 %32
    • Remove the rubber band from around the weaving rig.
    • Carefully lower the warp hooks by lifting the rear of the weaving rig and remove them from the weaving.
  14. Woven Darning with a Speedy Weave, Secure the warps: passo 14, imagem 1 %32 Woven Darning with a Speedy Weave, Secure the warps: passo 14, imagem 2 %32 Woven Darning with a Speedy Weave, Secure the warps: passo 14, imagem 3 %32
    • Secure the upper loops of the warp yarns by tacking down the top of each loop.
    • This stitch will mimic a whip stitch.
    • After the last tack stitch, trim the tail of the thread to about 2 inches (~4 cm).
  15. Woven Darning with a Speedy Weave, Finishing: passo 15, imagem 1 %32 Woven Darning with a Speedy Weave, Finishing: passo 15, imagem 2 %32 Woven Darning with a Speedy Weave, Finishing: passo 15, imagem 3 %32
    • Flip over the fabric.
    • With an empty needle, pull all the tails of thread to the back of the fabric.
  16. Woven Darning with a Speedy Weave, Tie off the thread: passo 16, imagem 1 %32 Woven Darning with a Speedy Weave, Tie off the thread: passo 16, imagem 2 %32
    • Tie off all these loose thread tails, ensuring that all sections are taught but not overly tight.
    • For extra security, thread each end into the needle and knot it off using one of the techniques from Knot Thread to the Fabric (2 Ways).
  17. Woven Darning with a Speedy Weave, Quality check: passo 17, imagem 1 %32
    • Carefully steam away chalk or pen markings.
    • Make sure there are no tucks or puckers in the surface of the fabric.
    • Ensure that the hole is fully covered and the patch secures all sides of damaged area.
    • YARN/THREAD LENGTH: A short length of yarn or thread may require frequent stops and restarts and can be prone to unthreading. Conversely, an overly long length can lead to tangling. An ideal yarn length is approximately 16 inches (~41 cm) when doubled, or 32 inches (~81 cm) in total.
    • LOOSE WARP LOOP: If a warp loop falls off, carefully replace it on the original hook, maintaining tension.
    • TAMPING DOWN ROWS: Tamping down each weft line after weaving is vital to maintaining even and accurate results.
    • CROOKED PATCH: Starting and stopping the weaving outside of the marked square will result in a crooked final patch. Warp yarns tacked down unevenly from the top horizontal edge will also result in a crooked final patch.
Linha de Chegada
Sabrina K
Membro desde: 12/18/24
806 Reputação
Autoria de 4 guias
Equipe
Patagonia Membro de Patagonia
Community
17 Membros
Autoria de 168 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 28
Últimos 30 dias: 87
Ao todo: 334
