Ir para o conteúdo principal
Knot Thread to the Fabric (2 Ways)
O que você precisa
  1. Knot Thread to the Fabric (2 Ways), Secure knot type 1: passo 1, imagem 1 %32 Knot Thread to the Fabric (2 Ways), Secure knot type 1: passo 1, imagem 2 %32 Knot Thread to the Fabric (2 Ways), Secure knot type 1: passo 1, imagem 3 %32
    • On the backside of the fabric, make a very small stitch.
    • Pull the thread through, leaving a short tail of approximately 1/2 inch (~13 mm) to 1 inch (~25 mm).
    • Make another small stitch in the same area. Leave the needle piercing the fabric without pulling it all the way through.
  2. Knot Thread to the Fabric (2 Ways): passo 2, imagem 1 %32 Knot Thread to the Fabric (2 Ways): passo 2, imagem 2 %32 Knot Thread to the Fabric (2 Ways): passo 2, imagem 3 %32
    • Take the thread that's emerging from the stitch and wrap it around the needle.
    • Wrap the thread around the needle a second time.
    • Push the wrapped threads down towards the base of the needle where it's emerging from the fabric.
  3. Knot Thread to the Fabric (2 Ways): passo 3, imagem 1 %32
    • Pull the needle through the loops and pull the thread tight. The knot will lay flush with the fabric.
    • This video shows how to start a stitch with secure knot type 1.
    • This video shows how to end a stitch with secure knot type 1.
  4. Knot Thread to the Fabric (2 Ways), Secure knot type 2: passo 6, imagem 1 %32 Knot Thread to the Fabric (2 Ways), Secure knot type 2: passo 6, imagem 2 %32
  5. Knot Thread to the Fabric (2 Ways): passo 7, imagem 1 %32 Knot Thread to the Fabric (2 Ways): passo 7, imagem 2 %32
    • Make another small stitch in the same area, across the first stitch.
    • Pull the thread through but don't pull it tight, leaving a small loop.
  6. Knot Thread to the Fabric (2 Ways): passo 8, imagem 1 %32 Knot Thread to the Fabric (2 Ways): passo 8, imagem 2 %32
    • Thread the needle through the loop that was created in the previous step.
    • Gently pull the needle through the loop without pulling the thread tight, keeping the thread loop intact.
  7. Knot Thread to the Fabric (2 Ways): passo 9, imagem 1 %32 Knot Thread to the Fabric (2 Ways): passo 9, imagem 2 %32
    • Thread the needle through the loop again in the same direction as the previous step.
    • Pull the thread tight to secure the knot. The knot will lay flush against the fabric.
    • This video shows how to start a stitch with secure knot type 2.
    • This video shows how to end a stitch with secure knot type 2.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Clara Redwood
Membro desde: 11/12/24
2.544 Reputação
Autoria de 18 guias
Equipe
Patagonia Membro de Patagonia
Community
17 Membros
Autoria de 168 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 34
Últimos 30 dias: 115
Ao todo: 487
