Ir para o conteúdo principal
Wooden Deck Floorboard Replacement
O que você precisa
  1. Wooden Deck Floorboard Replacement, Floorboard: passo 1, imagem 1 %32
    • Identify a floorboard that must be replaced.
    • Floorboards that have been damaged by dry rot are often soft and spongy. There may also be black fungus evident on the wood and any paint on the floorboard will have become damaged.
  2. Wooden Deck Floorboard Replacement: passo 2, imagem 1 %32
    • Measure the length of the floorboard to determine the size of the replacement floorboard.
  3. Wooden Deck Floorboard Replacement: passo 3, imagem 1 %32 Wooden Deck Floorboard Replacement: passo 3, imagem 2 %32
    • Place the end of your crowbar within the crack next to the floorboard and pry it out.
    • Caution: Ensure that you are wearing safety gloves, steel-toed boots, and safety glasses during this step to prevent injury.
  4. Wooden Deck Floorboard Replacement: passo 4, imagem 1 %32 Wooden Deck Floorboard Replacement: passo 4, imagem 2 %32
    • Using a pen or pencil, mark your replacement board at the length determined during Step 2. Using a lumber saw, cut the replacement board to its desired size.
    • WARNING: Ensure that you are wearing safety glasses, and do not wear any loose fitting clothing, jewelry, or gloves during this step.
  5. Wooden Deck Floorboard Replacement: passo 5, imagem 1 %32 Wooden Deck Floorboard Replacement: passo 5, imagem 2 %32
    • Using a pen or pencil, make a marking to identify where the deck's support beams lie below the replacement board.
  6. Wooden Deck Floorboard Replacement: passo 6, imagem 1 %32 Wooden Deck Floorboard Replacement: passo 6, imagem 2 %32
    • Using a hammer and wood nails, secure the replacement board to the support beams below.
    • For this specific replacement board, 3 x 2 1/2" wood nails were used to secure the board to each of the support beams.
Conclusão
You may repeat these steps for any additional floorboards.
Navdeep Singh
Membro desde: 09/21/20
133 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 203
