Ir para o conteúdo principal
Wooden Chair Slat Replacement
Veronica Shedd
Veronica Shedd e 3 outros colaboradores
Última atualização em June 20, 2024
50 minutos - 2 horas
Moderada
Do you have a chair with a broken slat? A broken chair slat can be dangerous for its sharp protrusions, as well as weakening the structural integrity of the chair.
This guide involves removing the broken slat piece and replacing it with a new part. Replacing the broken part of the slat improves safety and comfort, and is cheaper and more environmentally friendly than disposing of the chair entirely.
This repair requires the use of a saw. Always exercise caution when using sharp tools.
  1. Wooden Chair Slat Replacement, Slat: passo 1, imagem 1 %32 Wooden Chair Slat Replacement, Slat: passo 1, imagem 2 %32 Wooden Chair Slat Replacement, Slat: passo 1, imagem 3 %32
    • Saw off the broken chair slat piece(s).
  2. Wooden Chair Slat Replacement: passo 2, imagem 1 %32 Wooden Chair Slat Replacement: passo 2, imagem 2 %32
    • Remove the broken piece from the chair.
    • Sand down the chair where the piece was removed.
  3. Wooden Chair Slat Replacement: passo 3, imagem 1 %32 Wooden Chair Slat Replacement: passo 3, imagem 2 %32 Wooden Chair Slat Replacement: passo 3, imagem 3 %32
    • Measure a wooden dowl similar in size to the chair slat.
    • Mark the measurement on the wooden dowel with a marker.
    • Cut the wooden dowel directly on the marked line.
  4. Wooden Chair Slat Replacement: passo 4, imagem 1 %32 Wooden Chair Slat Replacement: passo 4, imagem 2 %32 Wooden Chair Slat Replacement: passo 4, imagem 3 %32
    • Sand the sawed-off end of the dowel.
    • Apply wood stain to the dowel piece to match the chair's color.
    • Apply wood stain following the direction of the wood grain.
  5. Wooden Chair Slat Replacement: passo 5, imagem 1 %32 Wooden Chair Slat Replacement: passo 5, imagem 2 %32 Wooden Chair Slat Replacement: passo 5, imagem 3 %32
    • Let the wood stain dry.
    • Add wood glue to the top of the new slat piece.
    • Add wood glue to the base of the chair.
  6. Wooden Chair Slat Replacement: passo 6, imagem 1 %32 Wooden Chair Slat Replacement: passo 6, imagem 2 %32 Wooden Chair Slat Replacement: passo 6, imagem 3 %32
    • Insert the new slat piece into the missing space.
    • Add the clamp to keep it in place for at least 30 minutes.
  7. Wooden Chair Slat Replacement: passo 7, imagem 1 %32 Wooden Chair Slat Replacement: passo 7, imagem 2 %32
    • Let the slat piece dry for at least 24 hours.
    • The chair is then ready for use.
Linha de Chegada
Veronica Shedd
Membro desde: 04/22/24
145 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 2-4, Whithaus Spring 2024 Membro de UC Davis, Team 2-4, Whithaus Spring 2024
UCD-WHITHAUS-S24S2G4
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 19
Duração total: 232
