Watch Strap Buckle Replacement
Introdução
Ir para o passo 1Anyone have the time? Broken or corroded buckles prevent the use of watches. Perhaps the metal tongue breaks, preventing you from fastening your watch. Or maybe the bar inside the watch band corrodes and the entire buckle falls off. This guide will walk you through the process of replacing metal buckles in a few easy steps with the help of a spring bar tool. This guide is applicable to all types and parts of the metal buckle. To order the correct size buckle refer to the manufacturing site of your watch to begin this replacement!
O que você precisa
Peças
Ferramentas
Hold the spring bar tool in your dominant hand and the watch strap with your non dominant hand.
Locate the pointed end of the spring bar.
