Ir para o conteúdo principal
Untracked Bifold Door Pin Replacement
Catelyn Carpenter
Catelyn Carpenter e um outro colaborador
Última atualização em May 6, 2020
10 minutos
Fácil
A bifold door that has come off its tracking can be a frustrating occurrence. This particular guide references a bifold door that depends on a plastic pin which is secured into the tracking above the door. Using this step-by-step process will help you replace the pin at the top of the door, reinsert it into the track, and get it back to functioning properly.
Before using this guide, check to see if the pin has fallen out and is damaged, or if the pin just needs to be put back into the tracking. We have provided links in Step 5 to where a new pin can be purchased, but in some cases the pin can be reused if it isn’t damaged or warped.
  1. Untracked Bifold Door Pin Replacement, Bifold Door Pin: passo 1, imagem 1 %32
    • Stand on a small ladder or step stool to get a better view of the top of the door.
  2. Untracked Bifold Door Pin Replacement: passo 2, imagem 1 %32
    • Locate the pin at the top of the door.
  3. Untracked Bifold Door Pin Replacement: passo 3, imagem 1 %32
    • Remove the current pin with pliers.
  4. Untracked Bifold Door Pin Replacement: passo 4, imagem 1 %32 Untracked Bifold Door Pin Replacement: passo 4, imagem 2 %32
    • Clean the top of the door using cleaning spray and a rag. This will help remove any dust or wood fragments left behind.
    • I used Meyer's spray, but any household cleaning spray will work just fine.
  5. Untracked Bifold Door Pin Replacement: passo 5, imagem 1 %32
    • Replace old pin with new pin using the pliers to place into the hole at the top of the door.
    • You can purchase a new pin at either Ace Hardware or Home Depot.
  6. Untracked Bifold Door Pin Replacement: passo 6, imagem 1 %32
    • Push the pin all the way in by using a hammer.
    • No excessive force is needed. Gently tap the pin with the hammer until it is secured.
  7. Untracked Bifold Door Pin Replacement: passo 7, imagem 1 %32
    • Line up the newly placed pin with the door's tracking.
    • Push the door down slightly and then lift it back up to align it with the track.
  8. Untracked Bifold Door Pin Replacement: passo 8, imagem 1 %32
    • Secure the pin within the tracking using the pliers.
  9. Untracked Bifold Door Pin Replacement: passo 9, imagem 1 %32
    • When completed, the bifold doors should close and be positioned within the tracking.
Conclusão
Catelyn Carpenter
Membro desde: 01/16/20
169 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 32
Duração total: 1,720
