Ir para o conteúdo principal
Umbrella Stretcher to Rib Joint Repair
Rodrigo Soliva
Rodrigo Soliva e um outro colaborador
Última atualização em September 13, 2024
15 - 25 minutos
Moderada
A really windy day can break an umbrella. In some cases, a joint will break, disconnecting the stretcher from the rib. You will be using a needle and thread in order to replicate the function of the joint that held the stretcher and the rib together. In addition, this guide will also cover how to sew a small rip on the canopy.
  1. Umbrella Stretcher to Rib Joint Repair, Umbrella Stretcher to Rib Joint Repair: passo 1, imagem 1 %32 Umbrella Stretcher to Rib Joint Repair, Umbrella Stretcher to Rib Joint Repair: passo 1, imagem 2 %32
    • Take the broken part of the stretcher to rib joint.
    • Realign it with the rib assembly.
  2. Umbrella Stretcher to Rib Joint Repair: passo 2, imagem 1 %32
    • Take the needle and carefully pass it through one of the holes as seen in the picture.
    • Then pull it back to the same side you went through.
  3. Umbrella Stretcher to Rib Joint Repair: passo 3, imagem 1 %32
    • Take the needle and pass it under the stretcher (not through the middle).
  4. Umbrella Stretcher to Rib Joint Repair: passo 4, imagem 1 %32
    • Position the needle so that it faces the second hole from the same side you just went through in step 3.
    • Take the needle and pass it through the second hole.
    • Then position the needle so that it faces the first hole from the same side you just went through.
  5. Umbrella Stretcher to Rib Joint Repair: passo 5, imagem 1 %32 Umbrella Stretcher to Rib Joint Repair: passo 5, imagem 2 %32
    • Repeat steps 2-4 until the two pieces are held tightly together.
    • Tie a knot to secure it.
    • Refer to step six if the rib punctured the canopy.
  6. Umbrella Stretcher to Rib Joint Repair: passo 6, imagem 1 %32 Umbrella Stretcher to Rib Joint Repair: passo 6, imagem 2 %32
    • It is easier to sew when the canopy is closed
    • Take the hole, hold each end and pull outward into a line.
    • Make sure that it is in line with the umbrella canopy seam.
    • Take the needle and thread and form a hemming stitch (see Step 7).
  7. Umbrella Stretcher to Rib Joint Repair: passo 7, imagem 1 %32 Umbrella Stretcher to Rib Joint Repair: passo 7, imagem 2 %32 Umbrella Stretcher to Rib Joint Repair: passo 7, imagem 3 %32
    • Begin with a threaded needle and start the stitch at one end of the hole and pull the needle all the way until just before the thread runs out.
    • Then loop back around and go through again.
    • Repeat until you reach the other end.
    • You can form the stitch multiple times to make it more secure.
Conclusão
The umbrella is fixed now, you may now use the umbrella freely.
Rodrigo Soliva
Membro desde: 10/26/17
182 Reputação
Autoria de 1 guia
Equipe
2 comentários
I have a problem with the auto lock, it's a knight bridge umbrella, when i retract it, it doesn't lock in place, can it be fixed or replace the handle in case it's totally eroded?
kamec 01 - Responder
I have 2 umbrellas which have both snapped at the hole. Is there a way this technique or a version of it can be used to repair them?
Jenny - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 30
Últimos 30 dias: 122
Duração total: 13,466
