Ir para o conteúdo principal
Ukulele Tuning Pegs Replacement
Seth Talkington
Seth Talkington e 3 outros colaboradores
Última atualização em May 26, 2020
6 minutos
Fácil
All musical instruments have to undergo repairs at points throughout their useful life. In this case, broken tuning pegs on a ukulele affect the tuning of the strings and therefore cause its sound to lose accuracy.
This guide describes how to fasten new tuning pegs to the fret board of a ukulele. Skills needed are basic motor skills and ability to use a screwdriver. New tuning pegs can be purchased online or in your local music store.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Ukulele Tuning Pegs Replacement, Tuning Pegs: passo 1, imagem 1 %32 Ukulele Tuning Pegs Replacement, Tuning Pegs: passo 1, imagem 2 %32 Ukulele Tuning Pegs Replacement, Tuning Pegs: passo 1, imagem 3 %32
    • Place the ukulele on a flat surface.
    • Completely unwind the string connected to the broken tuning peg by turning the black knob clockwise.
  2. Ukulele Tuning Pegs Replacement: passo 2, imagem 1 %32 Ukulele Tuning Pegs Replacement: passo 2, imagem 2 %32
    • Place the ukulele string in between your index finger and thumb.
    • Pull the ukulele string from the hole on the tuning peg.
  3. Ukulele Tuning Pegs Replacement: passo 3, imagem 1 %32 Ukulele Tuning Pegs Replacement: passo 3, imagem 2 %32 Ukulele Tuning Pegs Replacement: passo 3, imagem 3 %32
    • Turn the ukulele over, and note the placement of the screws attaching the tuning pegs to the head of the ukulele.
    • Using the PH00 screwdriver, turn the first screw counter clockwise to loosen.
  4. Ukulele Tuning Pegs Replacement: passo 4, imagem 1 %32 Ukulele Tuning Pegs Replacement: passo 4, imagem 2 %32
    • Using the PH00 screwdriver, turn the second screw counter clockwise to loosen.
    • Set the screws aside to use for later.
  5. Ukulele Tuning Pegs Replacement: passo 5, imagem 1 %32 Ukulele Tuning Pegs Replacement: passo 5, imagem 2 %32 Ukulele Tuning Pegs Replacement: passo 5, imagem 3 %32
    • Place the tuning peg knob in between your thumb and index finger.
    • Pull the old tuning peg completely off the ukulele.
  6. Ukulele Tuning Pegs Replacement: passo 6, imagem 1 %32 Ukulele Tuning Pegs Replacement: passo 6, imagem 2 %32 Ukulele Tuning Pegs Replacement: passo 6, imagem 3 %32
    • Have the new tuning peg clean and ready to replace the old tuning peg.
    • Place the new tuning peg onto the hole in the fret board.
    • Make sure the two holes that the two screws came out of are lined up to the two holes on the back of the fret board.
  7. Ukulele Tuning Pegs Replacement: passo 7, imagem 1 %32 Ukulele Tuning Pegs Replacement: passo 7, imagem 2 %32 Ukulele Tuning Pegs Replacement: passo 7, imagem 3 %32
    • Place one of the screws onto the PH00 screwdriver tip.
    • Line up the screw to a hole in the tuning peg and tighten by turning the PH00 screwdriver clockwise.
  8. Ukulele Tuning Pegs Replacement: passo 8, imagem 1 %32 Ukulele Tuning Pegs Replacement: passo 8, imagem 2 %32 Ukulele Tuning Pegs Replacement: passo 8, imagem 3 %32
    • Place the other screw onto the PH00 screwdriver tip.
    • Line up the screw to the remaining hole and tighten it by turning the PH00 screwdriver clockwise.
    • Tighten screws just until the screws are no longer loose. If you over tighten the screws, you might crack the wood.
  9. Ukulele Tuning Pegs Replacement: passo 9, imagem 1 %32 Ukulele Tuning Pegs Replacement: passo 9, imagem 2 %32 Ukulele Tuning Pegs Replacement: passo 9, imagem 3 %32
    • Turn the ukulele on its side.
  10. Ukulele Tuning Pegs Replacement: passo 10, imagem 1 %32 Ukulele Tuning Pegs Replacement: passo 10, imagem 2 %32 Ukulele Tuning Pegs Replacement: passo 10, imagem 3 %32
    • Insert the string into the hole of the tuning peg
    • Continue holding the string, and turn the black knob of the tuning peg counter-clockwise until the string is correctly tuned.
  11. Ukulele Tuning Pegs Replacement: passo 11, imagem 1 %32
    • Enjoy your refurbished ukulele.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Seth Talkington
Membro desde: 02/25/20
193 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team S2-G3, Andersen Winter 2020 Membro de UC Davis, Team S2-G3, Andersen Winter 2020
UCD-ANDERSEN-W20S2G3
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 10
Últimos 30 dias: 33
Duração total: 3,747
