Ir para o conteúdo principal
Trek 4300 Bicycle Kickstand Replacement
Emily OConnor
Emily OConnor e 3 outros colaboradores
Última atualização em January 11, 2015
5 minutos
Moderada
The kickstand has three parts: a bracket, a bolt, and the stand. To replace the kickstand the bracket and bolt will need to be removed to allow for the removal of the stand.
  1. Trek 4300 Bicycle Kickstand Replacement, Loosen Bracket: passo 1, imagem 1 %32 Trek 4300 Bicycle Kickstand Replacement, Loosen Bracket: passo 1, imagem 2 %32
    • Flip the bike over so it is balanced and resting on the handlebar and the bike seat.
    • Using a socket screwdriver with a hex adapter, loosen the bolt that is holding the kickstand and bracket in place.
    • This may require a moderate amount of strength. Make sure you have the proper hex adapter as to not strip the bolt.
  2. Trek 4300 Bicycle Kickstand Replacement, Remove the kickstand: passo 2, imagem 1 %32 Trek 4300 Bicycle Kickstand Replacement, Remove the kickstand: passo 2, imagem 2 %32
    • Once the bolt is loose, unscrew it the rest of the way by hand.
    • Remove the bolt. There should now be three separate pieces: the bolt, the bracket, and the kickstand.
    • Make sure to note the position of the bracket before you remove the bolt completely
Conclusão
To replace the new kickstand, follow these instructions in reverse order.
Emily OConnor
Membro desde: 10/13/14
500 Reputação
Autoria de 4 guias
Equipe
Clemson, Team 3-2, Benson Fall 2014 Membro de Clemson, Team 3-2, Benson Fall 2014
CLEM-BENSON-F14S3G2
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 2,974
