Ir para o conteúdo principal
Toto E-Max Fill Valve Disassembly
John Clements
John Clements e 2 outros colaboradores
Última atualização em June 26, 2024
5 - 10 minutos
Fácil
Guia colaborativo
Introdução
Ir para o passo 1
These steps describe how to disassemble a Toto E-Max Fill Valve. Please note that one helpful commenter suggested that they did not need to remove the fill valve from the toilet before flushing it; you can therefore regard the early instructions on removing the fill valve from the toilet as possibly optional.
O que você precisa
  1. Toto E-Max Fill Valve Disassembly, Tank Lid: passo 1, imagem 1 %32 Toto E-Max Fill Valve Disassembly, Tank Lid: passo 1, imagem 2 %32 Toto E-Max Fill Valve Disassembly, Tank Lid: passo 1, imagem 3 %32
    • Lift the tank lid up and away from the toilet tank.
  2. Toto E-Max Fill Valve Disassembly, Shutting off the Water Supply to a Toilet: passo 2, imagem 1 %32 Toto E-Max Fill Valve Disassembly, Shutting off the Water Supply to a Toilet: passo 2, imagem 2 %32
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  3. Toto E-Max Fill Valve Disassembly, Refill Tube: passo 3, imagem 1 %32 Toto E-Max Fill Valve Disassembly, Refill Tube: passo 3, imagem 2 %32 Toto E-Max Fill Valve Disassembly, Refill Tube: passo 3, imagem 3 %32
    • Disconnect the fill valve's rubber refill tube from the top of the overflow tube.
  4. Toto E-Max Fill Valve Disassembly, Draining a Toilet Tank: passo 4, imagem 1 %32 Toto E-Max Fill Valve Disassembly, Draining a Toilet Tank: passo 4, imagem 2 %32
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
  5. Toto E-Max Fill Valve Disassembly, Sponge Drying a Toilet Tank: passo 5, imagem 1 %32 Toto E-Max Fill Valve Disassembly, Sponge Drying a Toilet Tank: passo 5, imagem 2 %32 Toto E-Max Fill Valve Disassembly, Sponge Drying a Toilet Tank: passo 5, imagem 3 %32
    • Use a sponge to soak up and remove any remaining water from the toilet tank.
    • Periodically squeeze the excess water from the sponge.
    This is kind of funny but it worked. I had absolutely no sponges at the house, but had leftover diapers our granddaughter outgrew. I thought outside the box and ended up being impressed with the outcome. I opened up the diapers and placed in the remaining tank water. Viola, it immediately began absorbing the water. I used 4 diapers and it did the trick. Just have a leak proof trash bag on hand. No sponge, no bucket, no mess!
    Jody Broussard - Responder
  6. Toto E-Max Fill Valve Disassembly, Supply Tube: passo 6, imagem 1 %32 Toto E-Max Fill Valve Disassembly, Supply Tube: passo 6, imagem 2 %32 Toto E-Max Fill Valve Disassembly, Supply Tube: passo 6, imagem 3 %32
    • Place a bucket under the supply tube to catch any dripping water.
    • Turn the coupling nut on the supply tube clockwise until it releases from the threaded shank on the bottom of the tank.
  7. Toto E-Max Fill Valve Disassembly, Fill Valve: passo 7, imagem 1 %32 Toto E-Max Fill Valve Disassembly, Fill Valve: passo 7, imagem 2 %32
    • Using an adjustable wrench, turn the locknut on the threaded shank counter-clockwise until it becomes loose.
  8. Toto E-Max Fill Valve Disassembly: passo 8, imagem 1 %32 Toto E-Max Fill Valve Disassembly: passo 8, imagem 2 %32 Toto E-Max Fill Valve Disassembly: passo 8, imagem 3 %32
    • Turn the locknut counter-clockwise until it releases from the threaded shank.
  9. Toto E-Max Fill Valve Disassembly: passo 9, imagem 1 %32 Toto E-Max Fill Valve Disassembly: passo 9, imagem 2 %32
    • Lift the entire fill valve out of the tank.
    • When installing a new valve, be sure to adjust the float so that the water line stops one inch below the overflow tube.
  10. Toto E-Max Fill Valve Disassembly, Valve: passo 10, imagem 1 %32
    • This is our friend the Toto E-Max Fill valve. Unfortunately, she is leaking. Specifically, the shutoff is incomplete, so water continues to flow even after the float is fully lifted.
  11. Toto E-Max Fill Valve Disassembly, Remove Top Cap: passo 11, imagem 1 %32
    • The next step is to remove the green top cap. It's held on by tabs, light flexing should allow you to remove it.
  12. Toto E-Max Fill Valve Disassembly, Remove the valve lever: passo 12, imagem 1 %32
    • Here is the valve lever[*]. We need to remove it. It's held in by two pegs. Each one is attached to a flexible tang. use a thin blade or screwdriver to push each tang in, while gently lifting the lever.
    • [*} I have no idea if this is the right name.
  13. Toto E-Max Fill Valve Disassembly, Continue removing valve lever: passo 13, imagem 1 %32
    • Here we see one peg released. Note that I'm applying very gentle lifting pressure, not prying it upward.
  14. Toto E-Max Fill Valve Disassembly, Release one end of valve lever: passo 14, imagem 1 %32
    • Valve lever released! You are a champion. BTW, I made up the name "valve lever". I hope you're not laughing at me.
  15. Toto E-Max Fill Valve Disassembly, Release other end of valve lever: passo 15, imagem 1 %32
    • This is the other end of the valve lever. You should be able to easily release it from the green collar.
  16. Toto E-Max Fill Valve Disassembly, Remove the collar: passo 16, imagem 1 %32
    • Next, gently pop off the green collar that links the valve lever to the threaded float lift shaft.
  17. Toto E-Max Fill Valve Disassembly, Disconnect float pole from top cap: passo 17, imagem 1 %32 Toto E-Max Fill Valve Disassembly, Disconnect float pole from top cap: passo 17, imagem 2 %32
    • Gently snap the white float pole out of the jaws of the top cap. When you do this, the float assembly will drop.
  18. Toto E-Max Fill Valve Disassembly, Rotate valve cover: passo 18, imagem 1 %32
    • Rotate the valve cover an eighth of a turn counter-clockwise to release it.
  19. Toto E-Max Fill Valve Disassembly, Admire valve seal: passo 19, imagem 1 %32 Toto E-Max Fill Valve Disassembly, Admire valve seal: passo 19, imagem 2 %32
    • Yay! We got to the valve seal. Clean it off or replace it, and reverse steps to reassemble.
    This is the only instruction I found that helped me understand how to disassemble, thank you! If you are trying to fix the valve, leave it in place in your tank; once you get to the last image above , you need to flush it out by placing a cup upside down over this, turn your water supply back on and run it for about 30 seconds. Turn water supply off , reassemble in reverse order, turn supply on and if you were lucky like me the float will do its job! - Laura
    Laura Wallace - Responder
Conclusão
5 outras pessoas executaram este guia.
John Clements
Membro desde: 11/05/17
618 Reputação
Autoria de 2 guias
2Comentários do guia
Thank you! I did not expect to find a guide for a Toto toilet repair on a (mainly) electronics site, but here it is!
It worked perfectly when my toilet started running continuously on a Saturday evening.
I was able to take everything apart without even removing it from the tank, so it was a 15min fix!
Thank you!
Graham Allen - Responder
Red rubber flapper that covers the water hole doesn't line up when flushed. Replaced it, tried to adjust the chain. Still same, lands too far to left amd water continues to leak into bowl.
Toilet Questioner - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 78
Ao todo: 2,746
