TotalPond Pond Pump Throttling Valve Replacement
Introdução
Ir para o passo 1The throttling valve adjusts the rate at which water flows out of the pump. To replace this part, follow the steps below.
Turn the throttling valve counterclockwise until it is fully detached from the pump.
