Ir para o conteúdo principal
Toshiba Tecra Z50-A RAM Replacement
Luis Juen Baez
Luis Juen Baez e 3 outros colaboradores
Última atualização em March 22, 2023
5 minutos
Fácil
Introdução
Ir para o passo 1
RAM, or random access memory, is short-term storage for your Toshiba Tecra Z50-A. RAM is used by your processor for immediate use as needed, unlike long-term like files written to a hard disk drive. If your computer has slowed considerably or you’re looking for a boost, replacing/upgrading the RAM is a fairly simple and inexpensive first step. The Toshiba Tecra A50–A laptop comes standard with 8GB of RAM and can be upgraded to a maximum of 16GB with its two (DDR3) slots.
O que você precisa
Ferramentas
Exibir mais…
  1. Toshiba Tecra Z50-A RAM Replacement, Back Panel: passo 1, imagem 1 %32
    • Turn off the laptop.
    • Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
    • Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba Tecra Z50-A RAM Replacement: passo 2, imagem 1 %32
    • Lift up back panel using your hands and remove it from the rest of the laptop.
  3. Toshiba Tecra Z50-A RAM Replacement, Battery: passo 3, imagem 1 %32
    • Lift the plastic covering over the battery plug.
  4. Toshiba Tecra Z50-A RAM Replacement: passo 4, imagem 1 %32
    • Pull the wired cable up towards the top of the laptop to disconnect it from its socket on the motherboard.
  5. Toshiba Tecra Z50-A RAM Replacement: passo 5, imagem 1 %32
    • Remove the single 2 mm screw from the corner of the laptop using a Phillips #0 screwdriver.
  6. Toshiba Tecra Z50-A RAM Replacement: passo 6, imagem 1 %32
    • Remove the three 3 mm screws from the battery using a Phillips #0 screwdriver.
  7. Toshiba Tecra Z50-A RAM Replacement: passo 7, imagem 1 %32
    • Lift up on the battery with your hands and remove it from the laptop.
  8. Toshiba Tecra Z50-A RAM Replacement, RAM: passo 8, imagem 1 %32
    • Pull the two retention clips outwards.
  9. Toshiba Tecra Z50-A RAM Replacement: passo 9, imagem 1 %32 Toshiba Tecra Z50-A RAM Replacement: passo 9, imagem 2 %32 Toshiba Tecra Z50-A RAM Replacement: passo 9, imagem 3 %32
    • Pull up on the RAM module at a 45 degree angle.
Conclusão
Uma outra pessoa concluiu este guia.
Luis Juen Baez
Membro desde: 10/25/21
585 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 2-4, Sinclaire Fall 2021 Membro de UMass Dartmouth, Team 2-4, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G4
3 Membros
Autoria de 21 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 30
Ao todo: 488
