Toshiba Tecra 8200 Hard Drive Replacement
5 minutos
Fácil
Introdução
Vá para o passo 1If your Toshiba Tecra 8200 is running slowly or you are unable to save documents, your hard drive may need replacement.
O que você precisa
Locate the hard drive panel.
Remove the single screw labeled F4 by using a Philips size #00 screwdriver.
Save the screw, as it will be needed for reassembly.
Remove the panel, exposing the hard drive.
Quase terminado!
Linha de Chegada
