Ir para o conteúdo principal
Toshiba Satellite e205 Wireless Card Replacement
Tyler
Tyler
Última atualização em January 2, 2023
30 minutos
Moderado
Guia colaborativo
O que você precisa
Ferramentas
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. Toshiba Satellite e205 Wireless Card Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite e205 Wireless Card Replacement, Battery: passo 1, imagem 2 %32
    • With the battery away from you, slide the locking clips out.
    • The left clip stays, the right clip is spring loaded.
    • Slide the battery away from you.
  2. Toshiba Satellite e205 Wireless Card Replacement, Keyboard: passo 2, imagem 1 %32
    • Use a spudger to carefully pry up the keyboard screw cover.
  3. Toshiba Satellite e205 Wireless Card Replacement: passo 3, imagem 1 %32
    • Remove the two screws securing the keyboard to the chassis.
  4. Toshiba Satellite e205 Wireless Card Replacement: passo 4, imagem 1 %32
    • Carefully tilt the keyboard towards you and release the ribbon cables.
    • Use a spudger if needed to release the latch. The latch slides out.
    • The keyboard is now free and can be set aside.
  5. Toshiba Satellite e205 Wireless Card Replacement, Bottom Cover: passo 5, imagem 1 %32
    • Remove the five black screws
    • Remove the one silver screw
  6. Toshiba Satellite e205 Wireless Card Replacement: passo 6, imagem 1 %32
    • Flip the laptop over so the bottom is facing up.
    • Using a spudger, remove the seven rubber inserts.
    • The feet only go in one location on the bottom of the laptop, so save yourself some time and track where they go.
  7. Toshiba Satellite e205 Wireless Card Replacement: passo 7, imagem 1 %32
    • Remove the six silver screws.
    • Remove the one black screw.
  8. Toshiba Satellite e205 Wireless Card Replacement: passo 8, imagem 1 %32 Toshiba Satellite e205 Wireless Card Replacement: passo 8, imagem 2 %32
    • Stand the laptop up on end.
    • Remove the two rubber inserts from the back of the laptop. One insert is on each side of the laptop.
  9. Toshiba Satellite e205 Wireless Card Replacement: passo 9, imagem 1 %32 Toshiba Satellite e205 Wireless Card Replacement: passo 9, imagem 2 %32
    • Remove the two screews.
  10. Toshiba Satellite e205 Wireless Card Replacement: passo 10, imagem 1 %32
    • Carefully work a spudger in the crack at the back of the laptop and separate the small rubberized section from the bottom of the laptop.
  11. Toshiba Satellite e205 Wireless Card Replacement: passo 11, imagem 1 %32
    • Remove the four screws.
    • Disconnect the black wireless antenna lead.
  12. Toshiba Satellite e205 Wireless Card Replacement: passo 12, imagem 1 %32
    • The bottom of the laptop is now ready to lift off.
    • Carefully work a spudger around the seam of the laptop separating the bottom from the rest of the laptop.
    • There is a data connection at the front of the laptop that needs to be disconnected.
    • Use a spuder to carefully disconnect the wire from the motherboard. Once this is free the bottom will come off.
  13. Toshiba Satellite e205 Wireless Card Replacement, Wireless Card: passo 13, imagem 1 %32 Toshiba Satellite e205 Wireless Card Replacement, Wireless Card: passo 13, imagem 2 %32
    • Locate the wireless card.
    • Remove the white antenna lead.
    • Remove the single screw.
    • Lift the card up from the edge with the screw, and pull out.
Conclusão
Tyler
Membro desde: 06/19/12
5.031 Reputação
Autoria de 16 guias
Equipe
TechForce Membro de TechForce
Business
2 Membros
Autoria de 29 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 397
