Ir para o conteúdo principal
Toshiba Satellite c650d Hard Drive Replacement
Brenna Callahan
Brenna Callahan e um outro colaborador
Última atualização em December 21, 2022
10 - 15 minutos
Fácil
After powering the computer up, if it appears that your profile has been deleted or you get messages about the system detecting a ‘critical error’, then there may be a problem with the hard drive. Following the instructions in this guide will allow you to remedy this problem by replacing the hard drive.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Toshiba Satellite c650d Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Unplug the laptop and turn it off.
    • Flip the laptop upside down.
    • Locate the battery on the underside of the laptop.
  2. Toshiba Satellite c650d Hard Drive Replacement: passo 2, imagem 1 %32
    • Push the two latches away from the battery.
  3. Toshiba Satellite c650d Hard Drive Replacement: passo 3, imagem 1 %32 Toshiba Satellite c650d Hard Drive Replacement: passo 3, imagem 2 %32
    • Slide the battery away from the laptop.
    • Locate the serial number on the battery to order a replacement.
  4. Toshiba Satellite c650d Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32 Toshiba Satellite c650d Hard Drive Replacement, Hard Drive: passo 4, imagem 2 %32
    • Remove the one 5.0mm Philips #0 screw that holds down the panel covering the hard drive.
  5. Toshiba Satellite c650d Hard Drive Replacement: passo 5, imagem 1 %32
    • Pull off the panel.
  6. Toshiba Satellite c650d Hard Drive Replacement: passo 6, imagem 1 %32
    • Remove the one 3.0mm Philip's #0 screw holding the hard drive in place.
  7. Toshiba Satellite c650d Hard Drive Replacement: passo 7, imagem 1 %32
    • Slide the hard drive out.
Conclusão
Brenna Callahan
Membro desde: 10/21/15
868 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015 Membro de UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G2
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 2,751
